Elm
Butch...Mn
Is elm ever used for furniture? What are its pluses or minuses?
Elm
Butch...Mn
You bet
Elm isn't the friendliest wood to work because its grain is interlocked, but it is this interlocked quality that makes it ideal for chair seats. It is also quite beautiful, with a very interesting grain structure when viewed up close. Elm has a large difference between radial and tangential shrinkage, though, so it is more likely to warp than the more commonly used domestic hardwoods, so projects must be planned with this in mind.
Re: Elm
Bill Tindall
Elm was once abundant. The wood is pretty. At least the lumber I had was easy to work. But you will seldom see any old furniture built from elm. These facts suggest a problem. It and beech are among the least stable of the American hardwoods. I have built some things from it. The book shelves and framed screen are doing just fine but a panel in a desk split.
Re: Elm
Keith Newton
While it has some drawbacks, it gets high numbers in others, like tension parallel to the grain. It is one of the hardest to split woods that I've dealt with. I think it is suppose to have good bending properties too.
It is low on decay and insect resistance too.
Re: Elm
My son & I used Elm for all the shelves in his kitchen cabinets we built. I am in process of completing a curio cabinet for SWMBO. However, I think this will be the last project using Elm. It did great for the shelves, but I have had a lot of problems with wood movement after assembly. Had to add a fixed cross shelf to keep the sides parallel. Glass panel doors warped after assembly just enough to cause fitting problems etc. The wood does have a very pretty grain but tends to splinter easily. I actually started this project as a storage cabinet for a back room, my wife saw the assembled cabinet (less the doors) and wanted me to make it into a curio cab. due to the wood beauty.
which elm (no pun intended)
Robin Corell in Atascadero CA
Sorry but your question is a bit open ended. It is like asking if oak is any good. Like oak there are many different types of elm and each has its own charicteristics. Several here have mentioned that it is not very stable and for americam elm I would agree, but I have found that once Chinese elm (ulmas parviflolia) dries it is about as stable as red oak.
My favorite elm is siberian (ulmas pumila) it has wonderful color and often spectacular grain patterns. I have not had any problems with grain movement with it but it does move so you have to be aware of that and allow for the movement rather than trying to limit it.
One of the nice things about elm is that it is very strong and you can use that in your designs. for instance you can make delicately tapered legs and thin delicate rungs rather then big bulky looking things.
Elm can be dificult to work with hand tools and inferior power tools because it encapsulates silica and will dull edge tools. When I had a delta lunch box planer I used to put a 5* bevel on the back side of the blade when I would plane elm other wise after a couple of boards the blades would be toast.
However as dificult as elm can be to cut it sands remarkable well and takes a finish nicely.
Here is a picture of a pair of stools/bench made out of american elm (ulmas americana) It moves a quite a bit in drying but is reasonalble stable once dry.
I have also worked with rock elm (ulmas tomasii) and it is the one that moves the most once dry. It is also very punishing to any tool edges.
All of the elms I have mentioned were found growing in Californa and milled by me with a chainsaw. It is a wood I was not overly fond of the first time I milled it but the more I use it the more I like it.
Robin
Re: Elm *LINK*
Clay Foster
I've used a lot of cedar elm (ulmus crassifolia) that I harvested when I lived in Texas. I think it is called cedar elm because the heart wood is a dark red and the sap wood is white, like ashe juniper, which most Texans call cedar.
The wood is unstable, resistant to power or hand tools, impervious to sand paper, hard as concrete, but very beautiful. It's appearance and abundance are the main reasons I have used it. The only other species available to me there were just as ornery (pecan, bois d'arc) or devoid of aesthetics (hackberry.)
Here's a photo of a shop cart I made from cedar elm. The frames but not the legs are mahogany, as my cedar elm stash is very low.
Re: Elm
Clay,
If you're gonna pack, turn your back on the Lone Star, and camp in the Hoooosier State, you got to be prepared for the change in available trees, man.
('course you could take a road trip. Just for the purposes of restocking your stash, of course)
[nice cart btw]
Re: Elm
Joanne in Point Pleasant, PA
As others have said, it is a little gnarly to work with, but can have spectacular grain. Here's a little tv stand I finished a while ago that is elm and walnut. The elm I have looks good with walnut or cherry.
Here's a closer picture of the grain:
Re: Elm
Yonak
Butch, I agree with others that elm can have quite a showy grain. Here's a mantle clock made with grey elm.
Elm wood warms my heart
Tom Dunlap
Because of Dutch Elm Disease I've sent tons of elmwood through the chipper or to be made into chip mulch. Its sad to know that the beautiful wood isn't used more.
When I see elm, any species, being used I get a warm fuzzy!
Tom
Re: Elm
Stuart Johnson
You posted some photos once of some shop (?) cabinets you made using Cedar Elm that really shows off the wood and more than a little skill.
Re: I used Red Elm (kiln dried local wood)
