Veritas - Innovation in Tools
New project/experiment
Gary Smyth
In the next several weeks I’m looking for a low speed electric motor that is to turn an outdoor weight/ornament. The ornament weighs about 20 lbs. The rpm I want is about 60 to 100 rpm. The motor will be mounted in a box of some sort for the first go around. Eventually it will be housed to be in weather. It will run less than two hours a day. I thought about a washing/dryer machine, a floor buffer, drill press, ½” drill, kitchen mixer, awning motor, but new, these are far more than I want to spend-and, I haven’t had luck yet either. I need something at least second hand and as close to free as I can find. Because of the 20 lb. weight, the motor will need to have some torque. I find a lot of stuff at flea markets so if I know what to look for I will probably be successful for pennies on the dollar. Is there some other motor as an alternative I could look for also? I also have a spare ½ horse motor but it is 1750rpm and I don’t have a clue how I might pulley it to lower the speed. I'm hoping for alternatives and suggestions.
Re: New project/experiment
Jesper, Denmark
Jesper, Denmark
Old Grammophone turntable??
You want what I've seen called a gearmotor, with a built-in gearbox lowering the output speed to what you need (or close enough to pulley down to it). You might look at some of the surplus sites, or deBay.
Robin Corell in Atascadero CA
You might want to look for an old treadmill. Most have high torque dc motors and a variable dc power source along with a ac to dc inverter.
Robin
Yep ... Treadmill
Joe Burke
I was going to suggest the same thing. Do a search for "building a potters wheel" on you tube and you'll get some clips with good ideas. I did just that only yesterday because my daughter is interested in pottery after some school art classes.
I found 2 treadmills on Craigslist in my area for under $100 bucks.
John Verkamp
BBQ rotisserie motor. Can be had cheap or free.
Keith Newton
Gary, I may have something you can use. It is a gear-box from a conveyer, with 80 - 1 ratio. So your 1725 motor with the same size pulley on both would turn 21.5 rpms. Of course, you could go up or down by using different size pulleys on the side in, and off the back side.
It has a 5/8 shaft on the front side, with a variable width pulley, which is broken, and a small chain sprocket on the 3/4" shaft on the back side. That shaft goes all the way through, which I guess would allow for rotation change.
Send me an email, and I will send you a photo, and answer any questions for you.
Cheap variable speed drill from Harbor Freight?
Dick Coers
I have a friend that does prototyping for some food processing machines. His favorite cheap slow speed power units are cheap drills. Mountains of torque! He makes various devices to apply a set force to the switch to set the speed.
PaulSV
Treadmill motors generally are 5000 rpm DC motors with controllers. Turning them at 60 RPM would give very little torque, unless there is significant gear reduction. Treadmills have such gear reduction, but not built in to the motor, and what is there may not be adaptable for the OP's purpose. The motor and gearing used for the incline feature of a treadmill may be more suitable.
A gearmotor will have the gearing built in, and may be easier to adapt to the OP's intended use. You can get a lot of different gear motors relatively cheaply from Surplus Center, here:
http://www.surpluscenter.com/electric.asp?catname=electric
Another cheap possibility would be the motor and built-in gears of an old KitchenAide stand mixer. I am not sure, though, if they are continuous duty motors, suitable for running a few hours at a time.
I've bought there before when
Gary Smyth
I needed a small high volume squirrel cage fan. They used to have a catalog but all I see now is online. Still, I didn't think of these people. Good cue.
Tim Caley
What about a plumber/HVAC guy? They replace furnaces that sometimes still have good motors in them that you could probably get for cheap or free.
Larry in nw ohio
Gary you don not need a big 120v electric motor, your not working with turning a tree. You only turning a 20lb. of something.Surplus center has a couple I just looked at one runs 62 rpm and costs$9 and the othe is$7 and runs75 rpm. They are on page129, and these are only two that I looked at. I would highly suggest one from them unless you can find something else. I delt with these people na few times and are good to deal with. Good luck with your experiment. If you go to the web site look for gearmotor. Larry
Alan in Little Washington (NC)
Be careful of the small gear motors from the Surplus Center- some are about the size of an electric clock motor and do not have enough ooomph for what you need. Depending on the mount, etc. you might need one in the 1/20 hp range.
Overheating???
Joe Burke
I tried using a little gear motor like one shown from Surplus Center (I think that's right) and it overheated pretty quickly and just shut off. The application was a bit different ... it wasn't turning much weight, but it needed to run, probably 8 hours, or overnight.
How do you get past the overheating issue? Or did I simply have a cheap motor?
Re: Overheating???
Joe, if you didn't have a heavy load on a small gear motor and it overheated, I feel sure it was defective. As an Engineer at Emerson Electric (Mallory control division) I worked with millions of small gear drive motors. These were used in Appliance controls (Washers / Diswashers / Dryers etc. They should run continuous / forever without overheating if loaded under or to their rated capacity - believe it or not many of these timers require a pretty high torque motor /gearbox to operate.
Re: Overheating???
Larry in nw ohio
Joe If you think it was a defective motor, call them and tell them about it. They are very good to ork with, at least they were for me. Larry
Ancient History ...
Joe Burke
Thanks guys but that anecdote is from the distant past. I don't even remember where the motor came from but I know for sure it was cheap. I doubt it was bought from a reputable source either!
Interesting to know a good motor is designed to run continuously.
Re: Ancient History ...
I do want to make it clear that there are some motors that may not be designed for continuous service. These are normally special application motors like auto window, seat, convertible top, etc. Also there are some brush type (drills, small household appliances like blenders etc.), that may or may not be continuous rated. This is due to the fact their normal duty cycle for their intended purpose does not require continuous operation. They have the cooling fans necessary for continuous use. Normally however almost all general purpose motor / motor gearbox units are continuous rated - some may run quite hot when in service, it is not rare for a motor to have a 100 degree C rise, This means that in normal operation under normal full load the motor will be 212F hotter than ambient temperature. At 80 F that means you could cook on the motor at 282 Deg F.
The brush type motors due have a much shorter life (usually around 300 hours) while repulse / induction or shade pole motors properly lubricated will run continuously for years.
