More PO Bank questions
Bill Tindall
I have the bank dry fit into a case. The case is one piece of lumber mitered and wrapped for grain continuity. To my eye many banks are framed by lumber too thick. However, insetting the bank added some difficulty to the sizing of the case. But with a donkey board and hand plane the pieces could be cut slightly large then planed to fit the face into the rabbit. All that is now done.
The face was cleaned with Brasso and tooth brush but it remains dull and unattractive. If I continue brushing and then coat with Krylon or some other clear coat will it turn out ok? Is there a better cleaning procedure that won't corrode the lock mechanism? What is the best clear coat? What is the best way to cut the coin slot?
Re: More PO Bank questions
Michael Donaldson
Michael Donaldson
If it is made of brass: A good rag, a can of Never Dull, and a lot of time (3-4 hours of continual rubbing) will get it gleaming. Having spent the past 8 years in a sea-going service, I have learned a thing or two about polishing brass, and there is just no fast or easy way around it. I have never thought to clear coat brass.
Coin slot...
John E. in SC
I've made several of these, and cut the coin slot using a router table with stop blocks. Don't try to cut the full thickness with one pass - make multiple small cuts, getting gradually deeper.
James Fox
1. I like a little patina on the doors, so I don't polish everything to a high shine. Depending on how much crud I want/need to take off--I use a mixture of fine sandpaper, 0000 steel wool, Brasso, & sometimes a light touch with a dremel tool with the little sanding buffs in the picture (I'd take the dials off if you use the dremel). I've never put a coating on the doors; however, if you want, you can use spray can lacquer to coat it although it will eventually wear through in places (knowledge acquired from 27 years of experience polishing brass in the military :D ).
2. Before assembly, I mark the location of the brass plate I'm going to use for the coin slot on the top, drill holes big enough for a jig saw blade at the ends of the coin opening, cut between with the jig saw & clean up with a dremel if necessary.
Hope this helps...
James
brass cleaning
Bill Tindall
the brass on this thing is not smooth. It does not show well in the picture but there are rays running across the face. Any kind of abrasive polishing will just get the high spots. I am thinking I will leave the patina on it and just spray with a clear protective coat to keep it from turning green.
Re: brass cleaning
Larry in nw ohio
Bill Is there a reason that they didn`t turn green when they were in the post office? I can`t imagine that they would have cleaned them if they would have turned green. Larry
Bill, not sure how well it would work on the door, but I use Flitz metal cleaner on all my stainless Handguns and brass on muzzle loader. It is a "cleaner" (best I have found) for this purpose. It doesn't contain any acids or abrasives. If the Fritz won't clean it, I would go to my Dremel with the buffing wheel and compound, this wouldn't clean out all the small crevices but would sure polish the surface. Might look better if there was a little "patina" left anyhow.
Bill Tindall
not familiar with product. What kind of place sells it?
Bill - I have been using it for over 20 years - believe I first ran into it at a gun show. Amazon carries it.. http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=Fritz#/ref=nb_sb_noss_1?url=search-alias%3Daps&field-keywords=Flitz&rh=i%3Aaps%2Ck%3AFlitz
PO Box Door Cleaning
Marvin Horn
Made about a hundred of them till I just got tired of cleaning the brass, Best cleaning solution I found was a 50-50 solution of of household ammonia and Coka-Cola. This isn't a joke, it works. Soak for an hour or so then scrub with a toothbrush. For a polished surface you have to then go to one of the polishing compounds, brasso or just plain toothpaste. Tried a house brand cola and it didn't work nearly as well as Coke.
Follow normal safety proceedures for ammonia.
Re: PO Box Door Cleaning
James Fox
I forgot about Coke as a cleaning agent. Used it to clean 75mm Pack Howitzers used in gun salute battery at Ft. Belvoir in '69 & 70. Pour it down the barrel & swab. Amazing how much crud is left from the BIG blanks the guns fired. 91st Engr. Bn....the only Combat Engineer Battalion in the army with a howetzer battery.
Thanks for the jogging the memory, Marvin--I'll give the coke & ammonia a shot :D .
James
Pete in Holland
Contrary to what the Brasso instruction say, you need to use a rag and keep the working end wet with Brasso, and rub firmly, and lots. It isn't so much a chemical process, but a mechanical process of ultra-fine sanding.
An hour or so of work will make that door highlight all the details, the the nooks & crannies left dark for contrast.
If you are not getting anywhere with Brasso, you might be fighting some clear coating that will have to disappear first. Possibly start out with some medium steel wool.
A wire wheel does a quick job, but also tears the brass surface. I only use a wire wheel on raw casting surfaces.
Pete
Larry in nw ohio
Pete I just happen to think, how would a stiff toothbrush work with brasso. Larry
Bill Tindall
Thank you for the information. I prevailed with a tooth brush and Brasso but will try the coke/ammonia next time.
Ammonia alone will be effective but it will likely remove all patina as ammonia plus air will dissolve not only the corrosion but also the brass. I am not sure what if anything the coke does.
Joe Bradshaw
Joe Bradshaw
I have found that KA-Boom works well. take the door apart and let it soak overnight in the mixture. Ka-Boom can be found at Wal-Mart.
