Ash Tree
Ash Tree
Ash Tree
larry in nw ohio
I have an ash tree that I`m trying to save. I had it treated a couple of years ago for the borer and so far it is still leafing out good, but one thing that happened this year is the bark in a couple of spots is coming off, almost looks like a shagbark hickery tree, but in other areas it seems to be tight to the tree like it should be, at least for now. Is this a sign of it`s demise,dieing? Can I do anything for it to help keep it? I`d like to keep it. Thank you Larry
Re: Ash Tree
Re: Ash Tree
roger lance
Can you see little tiny holes in the bark?? That's a sign of the borer. There is a chainsaw operating in the background as I type this....an infested ash tree.
Re: Ash Tree
Re: Ash Tree
larry in nw ohio
I`m sorry I wasn`t real straight, It was infested but the ash borer treatment must have killed them off a couple of years ago when it was treated. But like I said the last two years the tree looked just like it wasn`t infested. But maybe this is what happenes when the borer gets killed off. I hope I can keep it going. Larry
Re: Ash Tree
Re: Ash Tree
Tom Dunlap
Is the bark shedding down to the wood? Or is it coming off in patches/flakes without the cambium showing?
Either way, just pull off the flakes without damaging any healthy bark. The damage has been done.
If the flakes expose the wood it might be from borer damage a while ago. YOu might be able to see the remains of their galleries.
Tom
Re: Ash Tree
Re: Ash Tree
larry in nw ohio
Tom Yes I think the cambium is showing. The bark is coming off in long, about 2-3feetlong and about 6inchs wide, in one place. The rest is smaller and this is happening just on the NW side of the tree, if that makes any difference. The rest of the tree looks real good from what I saw. Larry
Re: Ash Tree
Re: Ash Tree
R Payne
Here's my thoughts
If you had borer then borer is in your area. If it's in your area you could get re-infested. You said you treated a couple of years ago, how long was should that treatment last? A couple of year? Longer? What was the treatment?
A good arborist may be able to tell you if your tree is savable or not (probably at some cost for the examination).
Ron
Re: Ash Tree
Re: Ash Tree
Tom Dunlap
It wouldn't surprise me if it took two seasons to find the bark coming off in patches.
For any tree one of the best treatments is to kill as much turf as you can...to make the trees happy, start at the trunk and go to the property line ;)...and then put down a layer of woods chips. You can find plenty of them. Call any arborist and they'll dump for free...don't pay. If you decide to buy mulch you'll likely get stuff that came from a tub grinder which will be a bit finer.
Be sure to NEVER let the mulch pile against the trunk. Think donuts not volcanoes.
Tom
Re: Ash Tree
Re: Ash Tree
Larry in nw ohio
Itreated a couple of years ago and it would be due again this year if it`s saveable. Larry
Re: Ash Tree
Dale Lenz
Re: Ash Tree
Dale Lenz
Larry: As a forester that does make sick tree calls, I'd interested in what product they used that would last for several years. I only know of a yearly treatment and a spray on that last a few months if that long. Timing of the borers and spray are important and difficult to figure out. This year everything is 3wks+ ahead of most seasonal things.
Re: Ash Tree
Re: Ash Tree
Keith Newton
are you sure it didn't get hit by lightning?
Re: Ash Tree
Tree's age?
Al Stokka - Cambridge, Iowa
Larry,
How old or perhaps how big is the ash tree in question?
Al
Re: Ash Tree
Re: Ash Tree
Larry in nw ohio
Keith Yes, no lightning strikes. Larry
Re: Ash Tree
Re: Tree's age?
Larry in nw ohio
The ash in question is roughly over at least 45 years old. We moved here in 79 and it had a good head start on us at that time. It probably 5-6 inches in dia. at that time. I`m really roughly guessing at that. It is about 17" accross now. The tree has an area about from 26" up to about 6' up where the bark progrssively gets looser to about 8" from side to side that it is falling off and the rest of the tree looks like it should. In that area at about 4' up the bark is very bad, and that area is around 8" side to side and about 2 1/2 feet up. If you followed that let me know what I just said. :\ :D Larry
Re: Ash Tree
We are actively treating for Emerald Ash Borer
Tim Greif - West of Chicago
Our area (chicago suburbs) is presently under attack by the Emerald Ash Borer, which left unchecked, will destroy the ash population. I have begun a program of annual treatment of our ash trees, along with the City's treatment of the ash trees in the parkway. The City uses a soil injection method, whereas I use a perimeter soak using a Bayer product containing Merit (Imidacloprid). I've spoken to a couple arborists who generally agree that the ground soak method works on trees that are smaller than 50-inches circumference. Above that, the tree should be injected directly. The injection method has an advertised life of two years before retreatment. The soil injection and soil soakk method has to be done annually.
I can't comment on your bark situation, but the symptoms of a tree in trouble generally include a die-off of the upper crown growth and also an increase in the appearance of lower trunk area suckers.
There are many communities in our area that have begun an agressive campaign to kill these borers. The die-off of ash trees in the Michigan area was devastating.
Re: Ash Tree
Re: Ash Tree
JNoble
I lost 3 young trees to EAB several years ago, shortly after the initial infestation went rampant in southeast Michigan maybe 8-10 years ago. Our new subdivision street was lined with young ash trees so they were all quickly infested. Several of us treated the trees with good success using a do-it-yourself systemic style Bayer Advanced tree & shrub insect control product which is extremely easy to use but somewhat pricey for treating trees. While it worked well, treatment only lasts a year so if you want to keep your tree(s), expect to treat them annually from now on. In my case I decided that for the cost of treating each tree for 10 years, I could replace them, so after a couple years I let them go and put in another hardwood. Most of my neighbors did the same about 5 years ago. My next door neighbor continued with annual treatments; the tree is still there but nowhere as vibrant as they were before EAB. By the time the bark peels away, the damage is pretty extensive underneath in the active nutrient transport layer. If the damage goes full circle around the circumference of the tree there's probably no saving it. Good luck
