Dado Blades
Dado Blades
Dado Blades
Lynn Reedy
Anybody got any suggestions for a dado blade?
Brand, size or type anything will be appreciated.
Goes on a powermatic table saw..
Thanks
Re: Dado Blades
yes
Bill Tindall
I find them annoying to precisely adjust for width. I saw a Freud demo of a blade that can be more easily adjusted for thickness and if I was buying a new one that would be my choice.
Re: Dado Blades
Re: Dado Blades
roger lance
I'd also recommend Freud....get a set that has a 3/32" cutter which is handy for modern thin plywoods....although I've got a 3 hp cabinet saw which could easily spin a 8" dado, I've been using a 6" set (less expensive) and have not as yet needed a larger capacity than what the 6" provides.
Re: Dado Blades
Re: Dado Blades
Ron Jones
I am well pleased with my DeWalt set. Seems to cut square corners and flat bottoms.
Re: Dado Blades
Re: Dado Blades
BilWil
I have three dado sets. My first was a Craftsman. my second was a Forest, and the one I use now is the Fruend dial a width set. I don't use the craftsman any longer because it isn't carbide. The Forest is fine for those cases where the width is just a matter of mounting the two outside blades and the proper chippers. If I have to start adding spacers it is a real pain. I received the Fruend set for Christmas and I use it exclusively when I have to select a width of dado that isn't just a matter of mounting blades. I would highly recommend it and I am really pleased with it.
Re: Dado Blades
Re: Dado Blades
The big question is - how much do you plan on using the dado blades? Can you justify the cost of the Dial-a-width or expensive dado blades?
I have an inexpensive set of stacked dado blades - the Avenger. Inexpensive knock-off dado blades. They work nicely - with the caveat that it is a PITA to shim and get "unusual" sizes. I keep them in the box - I also have a spreadsheet taped onto the box with the "formulas" for which chippers it takes to get to the usual particular widths.
Oshlun makes a good inexpensive set also.
Re: Dado Blades
Re: Dado Blades
Larry in nw ohio
Lynn I always have to be different. I don`t own a dado, I just use my router. When I need a certain width I usually have it in one swipe of the router, if not I make two passes. Good Luck with whatever you do. Larry
Re: Dado Blades
Have to go with Larry and JL
neal in San Jose
I have a very nice and expensive dado set that I rarely use. It is too fiddly to get the correct width, so I use a router essentially all of the time. I can only think of two times I used it in the last year, and both of those times were when I needed to use a jig to cut an angled dado. I have the added complication of having a SawStop, which means I have to change the brake cartridge as well, but most people don't need to consider this. The $$$ dado blade was a poor tool buying decision on my part; should have gotten the cheapest one I could find.
Re: Dado Blades
Re: Dado Blades
JMOHNIKE
I have two friends, both of them are missing fingers, or parts of due to a wobble dado. I use a cheap stack dado set, which I do no need to use very often. The work for me.
Re: Dado Blades
Re: Dado Blades
AlanWS
I use the Dewalt set (identical to Delta) and find that it works well. It's inexpensive, cuts cleanly with smaller "bat ears" than many, and is precisely machined. That means I can measure stock thickness with calipers, consult a table in the instructions for chippers, then add shims and cut a dado to fit within about +-0.001" without test cuts. To make this quicker, I converted the chipper table into decimal inches to match my calipers.
Re: Dado Blades
Re: Dado Blades
Carol
Ditto on the wobble blade. Dangerous sucker.
I recently bought a Freud 6" with the anti-kickback design for ~$80 for the radial arm saw. Nice set. Worth the $$. IMHO.
Re: Dado Blades
Kneale Brownson
How does it adjust, Bill?
Re: Dado Blades
The trouble with adjustable . . .
Bob Lang
Is that you have to adjust every time, unless you consistently use the same width dado. Marketing people tell you you need to be able to dial in the width of the groove. Why not match the piece going into the groove to a standard size?
There are two parts to the joint, and if you can control the thickness of the piece going into the dado, you don't need fiddly adjustments at all. If I'm working with solid, I mill it to a thickness slightly larger than the dado and take a few swipes off the bottom edge of the end to get it to fit. If it's a man made material, I cut a tongue to a specific thickness (1/2" for example on plywood that is allegedly 3/4" thick) and put that into a 1/2" groove. Two outside cutters are each an eighth + 1/4" worth of chippers and it's done.
To me, that's far easier and cheaper too.
Bob Lang
Re: Dado Blades
My sentiments exactly
We used to use dado sets frequently in plywood case construction, but it was always with a standard size groove, usually 3/8" or 1/4" depending on the thickness of the plywood and the design of the piece. The mating piece got a rabbet that brought the resulting tongue down to exactly the width of the groove. A side benefit of this method is that it results in the butting piece covering the seam between the tongue and groove, where a fully housed joint is visually open.
Dado sets are useful for ripping tongues on boards, because they don't pull out little chips along the surface edges. Apart from that, though, routers with straight bits, spiral bits or slotting cutters (including rabbeting cutters) are preferable, IMO.
Re: Dado Blades
Re: Dado Blades
George Colonel's Workshop-Havertown PA
Good Afternoon Allan,
I've been using an 8 inch Freud Dado #SD208 for years and am completely satisfied.
George
Re: Dado Blades
Re: Dado Blades
John in NM
I have a Systematic set that I got on sale at Woodcraft years ago. Nice set, came with shims though I mostly organize things so that I don't need them. Trouble with shims is the way they hang up on the arbor threads if you're not careful (I prefer to spread them between chippers rather than all after the inside plate - but that's probably over-fussy).
I use it a lot, couldn't make do with a router, even if I could stand the racket :D
