Tips & Tricks
Tips & Tricks
Tips & Tricks
Pat Evans
Anybody got any tips or tricks for removing galvanized ring shank nails? My nail puller plus my 200+ lbs won't budge them. Crowbar just pulls the heads off. I've started just pulling the boards off leaving the nails behind for later removal, but I was hoping someone had an idea for easier removal.
Re: Tips & Tricks
Tried one of these?
John in NM
I've never yet found a nail one of these guys couldn't pull
Re: Tips & Tricks
Re: Tried one of these?
Pat Evans
That's exactly the nail puller I have. Even a small sledge hammer applied to it wouldn't pull the nails.
Re: Tips & Tricks
Re: Tips & Tricks
roger lance
Pat....an old carpenter technique was to grab the nail between the two claws of the hammer and then roll the hammer sideways and begin to pull the nail....this resulted in damage to the board against which you rolled the hammer....perhaps you will just have to leave the nail in the boards where they've been driven....cut em off flush with a sawszall.
Re: Tips & Tricks
Re: Tips & Tricks
Gary Camp, Bend, Oregon
If you can get a hold on a 1/4" or so this will probablly get 99% of them. One of my neighbors is a framing contractor, he told me about this tool and that it was nearly the best money he'd ever spent on a tool. Lisa and I were re triming our house and adding battens, read LOTS of nail pulling from 2-1/2" 18ga brads to 16d framing nails. It was invaluable, ocassionally we would pull a bard in two, but not very often.
just a very satisfied user.
http://www.nailextractor.com/index.html
Re: Tips & Tricks
Re: Tips & Tricks
Pat Evans
Exposing enough of the nails may be more trouble than it's worth. However, you've shown me a tool I don't own. I may have to buy one.
Re: Tips & Tricks
BarbS
Re: Tips & Tricks
BarbS
Pat, what kind of wood? I've had to do this with pallets, and soaking the wood around the nail helped, but it was often easier to just cut the board at that point.
Re: Tips & Tricks
Re: Tips & Tricks
Pat Evans
The wood is pressure treated pine. I'm dismantling the front deck to replace it and wanted to remove the nails so I didn't have to deal with boards with nails sticking out. However, just prying the boards up and then dealing with the nails seems to be the way to go.
Re: Tips & Tricks
Re: Tips & Tricks
larry in nw ohio
Pat I had to do this a few years ago and had a hard time getting the nails out. After awhile I thought that there had to be a better way and after awhile of messing around I finally came upon an idea that might work. I used a small drill bit and drilled right besides the nail, with a head I would drill at an angle to get along side the nail one or two holes and somtimes three to relieve some grip on the nail and when it would come out a little and the head would come off I would use a vise grip and grab the nail and use it as the head. I never lost the battle after that. Good luck Larry
Re: Tips & Tricks
Another vote for The Extractor
Henry Higginbotham
Some of the best money I've ever spent, too. I think you'd never regret buying one.
However, a long-embedded ringshank nail may be more than anything can reasonably handle. Have you considered just burning the wood off from around the nails? :D
