glue out at the corners
eliot d
I've posted before about this, but the plot thickens a bit. I have to glue up a box roughly 1 x 1 x 2 feet, which has mitered edges all around, BEFORE (for a reason of no interest to anyone else) applying any finish to it. I posted here while still thinking that I could apply finish first; and the best advice was to spline the edges, which I did, and use wax paper and some right-angled clamping blocks. But now, on bare wood, I'm worried that I won't have sufficient access to the outside edges ( don't care about inside) to wipe off the glue squeeze-out as it appears. The wood is furniture grade birch plywood; and I want to minimize any glue seeping into the outside surface so that when finishing is applied after glue up, blotching, etc, will be minimized. I plan on doing one edge at a time. Is there some cool way to clamp it up and still have access to the entire edge for wiping off the glue? Can I wax the wood first along the edges? Will it come off easily?
