1/3 hp motor question
Charlie Lenz
I'll be honest right away and say that I picked up a used Dayton 1/3 hp furnace blower motor from the local heating guys junk pile. It looks in nice condition, I brought it home and wired it up to about a 3ft long 18 gauge three wire cord ( white, black, green ) Pluged it into a power strip, turned it on and it hummed, so I shut it off. Then I turned the arbor, and turned it on and it ran. So I tried it from a dead stop and it ran, the next time it didn't without turning the arbor. When I shut the power off the motor spins down and I hear a click which I know is normal, but it has kind of a grumble before it clicks. Anyway, anyone have any ideas as to if it might be an easy fix or not ? A good cleaning ? Or take it to a motor shop ? Here are the specs for the motor, Belt Drive Motor, Split-Phase, Open Dripproof, 1/3 HP, 1725 RPM, Number of Speeds 1, 115 Volts, 6.6 Full Load Amps, 48Y NEMA Frame, Service Factor 1.35, 60 Hz, Cradle Mount, Ball Bearings, Auto Thermal Protection, Rotation CW/CCW, Ambient 40 C, Insulation Class B, Shaft Diameter 1/2 In, Shaft Length 1 1/2 In, Body Dia 5 5/8 In.
