JET Bandsaw Burned Out...electrical question
Ed in NY
I was resawing some 8/4 oak yesterday, same wood I was inquiring about a couple of weeks ago when it bowed as soon as it was resawn, and something I've done many times before, when all of a sudden the bandsaw popped a circuit breaker. It's a JET 14" closed stand bandsaw with a 1HP motor and brand new 3/4" Timberwolf bandsaw blade. I reset the breaker and it started right up and I began to cut again and then the breaker popped again. Then I smelled smoke. I opened the cabinet and the motor was burning hot. So I removed the wood from the blade, reset the breaker and the saw ran fine. I let it run for a minute or so just to be sure. When I came back about 2 hours later it didn't start and the motor was still too hot to touch. I removed the motor and one whole side of the casing was brown! Couldn't believe it. I wasn't bogging down the motor at all and as soon as I saw it slowing a bit, I backed off. I have no idea how this happened. So now I have to order a new motor (for about $250). My question is would I get better performance in the future if I wire the new motor for 220v instead of 115V? I was never really impressed with the cutting performance of this saw but I'm hoping a new motor at 220v will make it somewhat better.
