Need Magnetic White Board stock
Roy
I need stock for making slant boards for a small private school with special needs children. The material needs to have the characteristics of a white board and the ability to stick small magnetic objects on it. I've searched the Internet and my local lumber supplies with no luck. I've made some with 1/8" melamine but the magnetic objects don't stick on them.
Any ideas where I can purchase this type of material or easily make some myself?
Re: Need Magnetic White Board stock
Re: Need Magnetic White Board stock *LINK*
Dave Paine
I do not know of a source, but Lee Valley sells both a magnetic paint, used as an undercoat.
I did a quick search and found a supplier of White board paint.
http://www.whiteyboard.com/products/all-products/white-dry-erase-paint.html?gclid=CL3hvKnhua4CFQRN4Aodtmbc9g
I hope these are compatible for you.
http://www.leevalley.com/US/wood/page.aspx?p=52114&cat=1,250,43298
Have you contacted local sheet metal shops? It's possible that they can get sheet metal that's appropriately painted; if not, they may be able to advise you.
When our kids were little, before white boards, I attempted to make a two-sided easel, painting on one side and blackboard on the other. It turns out that brush application of blackboard paint makes for a lumpy blackboard. If you're going to whittle your own boards by painting sheet metal, then (a) get sheet metal with a very smooth surface, and (b) spray the paint.
Joanne in Point Pleasant, PA
Try here.
https://www.schooloutfitters.com/catalog/default/cPath/CAT384_CAT37?N=100037+1000500&s_kwcid=TC|6210|magnetic%20dry%20erase%20board||S|p|6610957217
Roy
Thanks for the suggestion. I'll give this a go.
Roy
This has some possibilities but the cost is rather high for just testing. I'll give the vendors a call to see if they will offer a sample or at least a refund if this doesn't work. Thanks.
Roy
I found this site while using Google but they don't sell just the board stock and tearing down the finished product is cost prohibitive. Thanks for the suggestion.
I have a friend who buys stuff at freight auctions and resells it. Occasionally he buys a pile of "flat stuff" that sometimes includes the white magnetic boards shown in the school supply site above. He is near Richmond, VA. Where are you? I could check with him and see if he has any now and put the two of you together. His supply is completely random. His prices are usually quite reasonable.
Roy
I'm located in San Diego. If he's will to cut them, shipping wouldn't be out of the picture.
I will check with him and let you know. What size do you want and how many?
Have you checked ebay and the like?
Gary Smyth
A quick search starts small boards at $46 on "Buy It Now". Shipping extra. Not knowing the sizes and how many you need means you will have to look through all offered.
Re: Have you checked ebay and the like?
Roy
I checked eBay but I could only find finished products. I'm wanting to cut stock to a finish size of approximately 12"x18" to get the best yield. From what I saw I couldn't yield enough of this size to make the purchase worthwhile. Thanks for you suggestion.
Roy, I checked with my friend who sells these things as he gets them. Sadly he has none right now and even worse, he threw out two boards that were cracked out of his last batch about a week ago. Had we known you were out there, we could have cut them down to 12" by 18" and sent them to you. He MAY have some more next week. How many do you want? How big a hurry are you in?
Roy
I need 20 to 30 and am in no hurry. Thanks for your help.
I will let you know what he/we come up with. If he gets some more boards I will let you know and I will probably be the one cutting them down to size.
Frank C
http://www.magnetking.com/#dryerasemagnet
I just received a 2' x 10' piece for 41.00. Quality was good and service was fast.
Thanks,
Frank
Roy
How are you going to attach it to a substrate?
Larry in NW Ohio
I was just finishing up reading my March issue of Pop. Mech. and saw an ad on the last couple of pages for Magnetic Steel Whiteboard and imediately thought of this post. I hope this can work for you. The web address is www.whitewalls.com and the phone is 800-624-4154. Good Luck Larry
Get Ye To The Landfill
George, Oxford, NC
If your location (city, county, whatever) will let you into the landfill, go and cut the sides off of white enameled appliances. That is what I used a few years back to make a couple for grandkids. Cut the pieces big and trim them to size in the shop. I sandwiched the sheet between two sheets of thin plywood and used a saber saw with a metal cutting blade. Free is always good.
George
most landfills off limits
Jerry Gibbs
Back in the day, going to the town dump on Saturday was a fun routine, especially bringing home other's junk. t\They don't let us fill in wetlands anymore (which is good)
fancy dump
Jerry Gibbs
Our town dump was so snooty, that instead of "No Garbage", the sign read "Dump No Putrescible Materials".
Curbside/upstream recycling
Tom Dunlap
Now, you have to do your scavenging at the curb or in the dumpster. Most places will not like you going over the edge to score treasure from dumpsters. Fishing from outside should be OK.
When I worked at a university I would bring home lots of great materials.
Re: Get Ye To The Landfill
Salvage yards may be your best bet for finding appliances, I'm sure they will charge you but probably the cost will be minimal - probably twice the scrap weight value.
My buddy went to an auction today and did not score any white boards. In about two weeks, there is another one. If he scores any I will let you know and find out if you are still interested.
Just don't cut into a refrigerator. Between the flammable insulation and the prospect of cutting into tubes carrying freon...better to use a washer or dryer.
You might ask appliance stores what they do with appliances removed when they install a new one.
