Have a question? Ask Woody!
Delta DC-33 Thickness Planer Dust hood
Charlie Lenz
Well I just got done makeing a mockup of a Dust Hood for the Planer. It fit pretty nicely for the first one, and certainly good enough that it's what I'm going to go with. Now I'll see if I have the time to start building it from sheet metal this afternoon. It will probably be a couple days before I get it finished up, painted, and then installed. Pictured is the end of the hood where the 4" port will be, in other words it will be a side exhaust.
Re: Delta DC-33 Thickness Planer Dust hood
Larry in nw ohio
Wow Charlie you really do good work. Did you learn to do this kind of things just by doing or was it on a job you worked at. Larry
Re: Delta DC-33 ( Thanks Larry )
Charlie Lenz
Well since you asked, I wasn't really very good in school when I was younger. I did ok in math, and then in about 1974 I took a Mechanical Drafting class in Vancouver, Wash. ( Evergreen High School ) I took an interest in the class and recieved straight A's, but I didn't persued it after High School until a couple years ago when I got sick and tired of breathing dust and cleaning it up. I bought a sheet metal Brake and a few other tools to do this type of work and it's been fun. I wish I had persued this type of work immediately after High School, but I was just another misguided kid. Took a job in a Union Meat Packing plant not because it interested me, but because it was fairly good money for a young kid just out of school. Partying and women were another obstacle. There is a sheet metal shop here intown where I get my materials, I put a bug in their ear occassionally to hire me. The guy even has a WaterJet machine, I'd love to work in a place like that.
Re: Delta DC-33 Nevermind the doorstop
Charlie Lenz
Sitting ontop of the machine, I forgot to take it off before the picture. I placed it there to remind me to install it back on the floor when I move the machine away from its stored location. If I don't, the door with window might hit the hanging wood stove and knock the window out. Anyway, the doorstop isn't some McGyvered addition to the Planer, incase anyone noticed.
Charlie, that looks great. The only thing I would consider changing is to flip it over so it comes off the other side. I see the cord hanging from the other side and it might be better to have the cord and hose on the same side. In my case, the hose comes from one side and the cord from the other. It seems SOMETHING is in the way no matter which side you approach from.
Larry in nw ohio
I mean no insult here but are you sure you aren`t my long lost twin. I swear your life sounds just like mine. No good in school, did pretty good in math, and loved industrial arts. Loved tearing things apart just to see what made it go. Larry
Re: Delta DC-33 ( Thanks Barry )
Charlie Lenz
Oh sure, make me think about it some more. But you do have a point, plus it would be out of the way of the controls on the left side. I'll have to think about that some, good thing I didn't have the metal all layed out and cut yet.
Charlie Lenz
No offense takein Larry. I don't know about being your twin, but I've been known to be lost at times. Before you throw things away do you scavenge every nut and bolt and electrical cord ( especially the molded end three prong ) or whatever else you think might come in handy someday ?
Scavange
Tom Dunlap
"Before you throw things away do you scavenge every nut and bolt and electrical cord ( especially the molded end three prong ) or whatever else you think might come in handy someday ? "
I do! And its saved me many trips to the hardware store at really odd hours too! Saved money too.
Tom
Re: Exactly Tom
Charlie Lenz
If we can remember where it is that we put those parts. It looks like Larry now has two lost twins.
Larry in nw ohio
By golly Charlie you are my brother. I do the same thing. When things break, and I can`t fix it, it comes apart and I grab everything I can if it might come in handy. I have electrical cords w/molded plugs in a drawer. They are handy when I cut through one or tear one somehow, they look better than the ones that come with it. I have fans from microwaves, limit switchs and so on. Its good to finally find you. :D Larry
Re: Exactly Tom
Larry in nw ohio
BINGO anotherfamily member, can`t remember either ;) ;) Larry.
Robby Wright - San Marcos, CA
Charley - I like that hood. Better than the one I made. How are you planning of fastening it to the planer? I just ended up running a couple of screws through the sheet metal.
Re: Delta DC-33 Robby
Charlie Lenz
Thanks Robby. I plan to fasten it probably like you did. Two bolts at the bottom of the hood where the factory dust hood would bolt up, and two screws or machine screws and nylock nuts through the top existing sheet metal blade cover.
Charlie Lenz
I took Barry's suggestion and switch the port over to the right side instead of the left.
Looks good to me. I think you will find it good that they both come from the same side. Wish mine did. One less thing in the way.
Re: Delta DC-33 Planer Dust hood ( Barry )
Charlie Lenz
Thanks for your approval. With the DC-33 planer it's not a huge issue in either direction, the power cord can be run down and under the stand and out any direction, and the controls can be reached from either side. A couple years ago I built a similar dust hood for a Ryobi AP12 lunch box style planer ( shown ) where the direction of the port was more of an issue. This isn't my first dust hood for a thickness planer.
Nice work Charlie...
John in NM
Both look entirely professional
Re: Thankyou John
roger lance
this is the stock Delta dust port on a DC-33.....use a shock cord to hold the dust collection hose out of the way.
Re: Delta DC-33 Dust hood ( Roger )
Charlie Lenz
Hi Roger, I've seen the stock dust hood for the Planer, both in plastic and cast iron. I didn't care for the way it was designed to come straight out the back, and as you point out gets in the way. Thats why I designed the hood that I built to come out the side. As I pointed out earlier, I designed and built a dust hood for a Ryobi AP12 a few years ago with the same side outlet design and it works beautifully. I know that it is nice to keep the older machines looking as stock as possible, I'm a member of the Vintage Machinery website, but if there is room for improvement to a machine without doing irreversable damage to the machine itself, I will do it.
Re: Delta DC-33 Dust hood installed
