roll around cart
roll around cart
roll around cart
clay foster
A roll around cart finally made it to the top of the "to do" for our studio. It's an amalgamation of leftovers from other projects. The top, corner posts, and panels are cedar elm, the frames are mahogany, and the shelves are mostly cherry. The casters came from a stainless steel kitchen cart the neighbors were going to throw away. The kitchen cart is beside the outdoor smoker, grill now. The studio cart nests under a work table, but will be very handy when processing wood between the jointer, planer, bandsaw, and table saw. The middle shelf is adjustable, and I'll probably get some stackable clear plastic bins to put in it.
Re: roll around cart
George Colonel's Workshop-Havertown PA
Good Evening Clay,
It is striking, how nice the disparate wood works together. I especially like the bookmatched cedar, and wonder why it is used so seldom in furniture other than cedar chests. I like it.
George
Joanne in Point Pleasant, PA
That's lovely, Clay. Almost a shame to rough it up in the shop with lumber and stuff. I need to make a similar sized cart for my aunt, perhaps with some drawers instead of shelves. What method did you use to attach the frames to the corner posts?
Carol Reed, Pahrump, NV
Sheesh! Even your shop carts are works of art! I am totally intimidated. Also jealous.
Larry in nw ohio
Clay As others said, that is a great looking cart. It looks better than the things I make for the house. Great Job. Larry
frank ashmore
Very nice Clay.The cedar elm, is that wood actually an elm species?Does it smell like cedar when you cut it?
Re: roll around cart *LINK*
clay foster
It is a species, native to southern states. I think it is called cedar elm because the colors of the wood are very similar to cedar(juniper.) The wood is very hard and tough, and prone to warping when it is worked. I cut a cedar elm board way bigger than I need, give it a few day to warp, cut it closer to final dimensions and let it warp. By the time I cut it to final size, it doesn't move as much. It would probably be good for bent wood. I've bent thin and narrow strips to a half inch radius without breaking.
cedar elm
clay foster
Thanks, Joanne. The frames are glued into dados in the posts.
Re: Nice work Clay
That really looks to good to be used in the shop! I hear you about the warpage. I am just finishing up a cabinet I built out of Red Elm - had the same problems with stability.
Thanks
clay foster
Thanks for the compliments. We spend a lot of time in our studio, so we might as well have nice things to use and look at. I know it will get some dents and scars through the years, but it will still be working long after I'm not.
