Best plane for a shooting board
Michael Donaldson
Michael Donaldson
I am going to be making a shooting board specifically to trim miters for boxes, I found an article here on WC that covers how to make one, and I feel like I have a pretty good handle on the concept. My question is with which plane to use. I have a #60 1/2, #3, #4, #5C, and am trying to tune up a #7 Dale Lenz sent me (I think I can get it going soon). Shooting miters, I will obviously be trimming end grain, so which plane should I set the board up for?
Re: Best plane for a shooting board
Dale Lenz
Dale Lenz
For shooting wide miters, such as my flag cases, probably not the miters you are thinking about, I like the LN #5 BU, low angle. Took me years to even attempt to shoot miters, you are moving at lighting speed, Mike. Go For IT!!!!
None of those - you have to buy a new plane :b.
I prefer something small, but weighty. The lowest angle you have.
recommendations
Bill Tindall
If you have piles of money LN makes a plane specific for his task.
The most important attribute is weight. You are going to find that it takes a fair amount of force to blast the plane through inch tall lumber. The momentum of a heavy plane aids the task.
Stanley planes are not easy to hold in "shooting" position. The bevel up planes are easier to hold. The massive large sized Lee Valley plane in the low angle, bevel up configuration is a good choice.
For flat molding you are going to need a donkey's ear in addition to a shooting board. The design recommended by the person that makes frames for the museum was easy to make and effective. Search "Donkey's ear" on the hand tool side from a few months ago, or I can send a picture.
Of the ones you list...
John in NM
The #5 or #7 would be best due to weight, the #7 might end up being too big and awkward, I've never tried it. I tend to use a #5, with my thumb behind the frog and hand over the side of it. Ideally a shooting board will work with any plane you have at hand that is large enough to grasp sideways (block plane wouldn't work well).
Guillaume Dery
None of the planes you have mentioned is ideal although you could purpose one. As mentioned in some of the other replies, there are a few things you are looking for in a shooting plane:
1. Mass - you want to build momentum so that this thing moves like a freight train when it hits your end grain.
2. Low angle - again, this has everything to do with the end grain. The recommendation of BU planes is a good one if you don't happen to have the coin laying about for the LN miter plane (or more expensive premium miter planes).
3. Square - This has not yet been mentioned in the responses you had so far but it is a must!. You want the sides to be perfectly square to the sole, else your miters will give you fits. This is hit or miss with the older planes but almost a given with the new quality manufacturers such as Veritas and LN
Of secondary consideration is registration and ease of handling. You want decent registration for the side of the plane when in use. Low sides are a negative here. Ease of handling is also a concern but you can develop technique. The old Stanley shooting planes and the new one by LN have the handle mounted at an angle which makes it a heck of a lot easier to get a decent grip on.
I guess what I am saying in a long-winded fashion is that I would have reservations using any of the planes you mentioned in a shooting board configuration. I would opt in favour of the LV LA BU jack or smoother (or if you are totally flush with funds the awesome LN shooting plane which I lust after). If you must use one of your Stanleys, I would probably go for the 5C to at least get some mass in the equation (just check that your wings are 90 degrees to the sole). The iron gets sharpened absolutely square (not cambered) either way.
All of the above is my own opinion, freely given and probably worth what you paid for it :D
Cheers,
Guillaume
roger lance
If you have the funds, a LV BU Jack would be a good choice (more expensive yet are LN 9 and the ultimate LN 51)....of what you have, the 5 or 7 would be your best choice....it would be nice if the sides and sole of your plane were square but this is not essential in a shooter....what is essential is that the blade be square to the work....so if the plane isn't perfectly square, compensate for that by adjusting the blade....my advise is to make a simple shooting board and use the 5....a little experience will answer many questions for you.
Todd Nebel
I'm saving my dollars for the LN No. 51. In the meantime I use the 60 1/2 with good results.
Jim in N. Va
You should be able to find a Stanley 51 (minus the chute board) for a lot less than the LN version. Mine works great. I don't see I would get any greater functionality from the LN.
