Suggestions on a rip Blade for TS?
I have been using a Forrest WWII blade for almost everything and I like it, but the other day I hit a the leg of one of those big a$$ed staples Lowe's leaves pounded into a 2x4 and basically "ripped" it. Who knew you could perfectly slice away half a staple leg length wise and leave the other half in the wood? It did not damage the blade as much as I thought it would, but I need to send it in for service.
So, I need a rip blade to cover for it while it is gone and to add to my arsenal. I'm thinking a thin Kerf 10" blade or maybe I will try Bill's suggestion for an 8" blade. Want one that cuts a flat bottom groove so I can use it for cutting spline slots ont he corners of boxes. What do you think is an excellent blade and is there one available at the Borg or WoodCraft?
Re: Suggestions on a rip Blade for TS?
I like Freud. I prefer the ones at Woodcraft such as the LU84 - but I like combo blades.
Ken Oakley- Sunny St. Cloud, Fla.
I am with JL.
Larry in NW ohio
I am also with JL and Ken, I tried the WW11 blade but I haven`t use it in maybe 2 years. Maybe it`s that the Freud is prettier with the red coating. Acctually I think it cut better. Also on their blades I like the Combination and the thin ripping Blade. I also have an oldridgid gold color combination blade that I like. Larry
Alternative
I have used a full-kerf Systi-matic glue-line (40-tooth) rip for years. It is still my go-to blade. I have it sharpened by Forrest here in NJ. I use a 3hp cabinet saw, however, so I can't comment on how it will do on a contractor's saw.
Robby Wright in San Marcos, CA
Barry - I have the same saw as you, but with a 2 HP motor. I use a full kerf Freud LU84 like the others. It is an inexpensive blade, but cuts well. I routinely go straight from the blade to glue-up.
Another blade that I have recently been using is the Forrest WWII, option 1 blade, which has almost a rip/triple chip grind on it. I use it for fine ripping now, but still go for the Freud when I need to do a lot of ripping on thick wood.
Robby Wright
San Marcos, CA
Robin Corell in Atascadero CA
I have a .150" kerf Amana rip blade with a flat tooth grind that I have been very happy with.
If you have the hp you will get better results with a standard kerf or even a thicker kerf blade.
Robin
Re: full-kerf Systi-matic here also
Charlie Lenz
But I'm not sure if it's even a 40 tooth, it may be a 24 tooth. It works well on my Contractor's table saw with the original Delta 1 1/2 hp motor, Barry basically has the same saw as I do, so it should work ok for him also if he has enough juice going to the saw.
Re: full-kerf Syste-matic here also
I have that saw and added a 2hp Dayton motor about 35 years ago. Its wired on a heavy 220 circuit, so it has plenty of juice. No complaints in that department. I even whipped the dust collection shortage. I have no complaints with the saw at all. It will rip three inch stock when I ask it to, maybe a little slowly, but then I hardly ever rip three inch stock.
Just time to buy a fine quality rip blade.
Re: full-kerf Syste-matic here also ( to Barry )
Charlie Lenz
Barry, I'd be interested to see what you did for dust collection on your saw.
Re: full-kerf Systematic here also ( to Barry )
Charlie, I am sure I over thought the DC on my saw. I would take a picture but its had to see what I did.
I will try to describe it. Think Cereal box. with the left side cut off at a forty five to allow for tilt. This box is about 2" wide 12" front to back and maybe 14" tall, with a hinged dogleg in it, to the left. On the bottom there is an "end boot that matches the 2x12 and has a 4" port sticking toward the front.The reason it sticks toward the front is that puts the blast gate right below the switch. I reach down, hit the switch and open the gate, Its a Long Ranger gate, so it brings the DC on. It resides right beside the front right leg. The reason the assembly is hinged is that when you crank it over to forty five the gate would hit the left leg, but the hinge takes car of that. I also made a crude cover that sits over the cutaway top of the Duct/cereal box and closes it down to about a half inch slot around the blade. That lifts out to change the blade or or dado blades.
This set up is very effective, collecting about 99% of the dust. I added some "hula skirt" brushes to the underside of the throat plate to make it even better. The main one of those fell off because the plate is some sore of pot metal and it oxidised and the epoxy lost its grip. They were a nuisance because they interfere with angling the blade.
I like the Dust gate being right at the switch. It has become natural to turn it on and then start the saw, make the cut, then turn off the saw and close the gate.
I will take pics if you like, but I have tried before and they don't make much sense. Incidentally, I removed the original chute which was little more than a deflector and used its mount to bolt in my duct.
Re: full-kerf Syste-matic here also ( to Barry ) *LINK*
Charilie - I mounted a table top dust collection fitting, formerly called a "Big Gulp" under my Rockwell. The link below is to the one I used, but it used to cost $16: Fits the original stand perfectly. A 90 degree elbow at the bottom, blast gate and you are good to go. Works like a champ, much better than those silly "table saw" plates. Oh, yeah, trim off the screws you fasten it with or you will shred your hands. Just don't drop your arbor nut..... :b
Big Gulp Dust Collection DoDad
Re: Not that I really wanted to bring it up again
Charlie Lenz
I was just curious if Barry ever took any of my Contractor's table saw dust collection advise that I have allready posted here numberous times. Doesn't sound like it.
Charlie, I think I heard about your set up after I did mine. Either way, yours is much too easy. I just had to do it the hardest way I could think of.
Charlie Lenz
Trust me Barry, there wasn't much that was easy about it. In a years time I built two other prototype hoods until I was finally happy with the third and last design. In that years time I also had people questioning the back of the saw being open. Even though I didn't think it was that neccessary, I went back to the drawing board scratching my head, gotta keep everyone happy you know. It's been a rediculously long road.
