REAL MILK PAINT
My Grex 23 ga. pinner is having problems
Yonak
Recently it has gotten finicky about operating. I pull the trigger and nothing happens .. just hissing. I tried disconnecting and re-connecting the air supply and changing the air pressure, but sometimes it works and sometimes it doesn't. Has anyone else had this problem and found a solution, or is it time to replace it ? It's not really that old .. probably 3 years, but reasonably heavy usage.
Re: My Grex 23 ga. pinner is having problems
del schisler
Do you put a couple drop's of oil in where the air hose goes on ??? If not this could be the problum. Try that. If not their is a diaphragm that could be bad if air come's out with out the trigger pulled ??
Yonak
Yes, del, I'm diligent about always oiling it after using it. If it's the diaphragm is that repairable ?
Joe Shelton
Yonak, mine is a Senco, not a Grex, but I had the same-sounding problem and it was due to a broken seal at the trigger valve. Many manufacturors supply rebuild kits for such problems. There may be someone on the 'Messages' forum with better insight than mine.
Joe
Uh, sorry. I'm not lost, I'm just
Joe Shelton
temporarily misoriented.
If I'm not back before I get here, somebody pop smoke so I can identify...
Joe
Gotta remember that one, Joe.
Re: My Grex 23ga. pinner is having problems
I have a number of nails guns and have had some of them for thirty years. There is a local shop I take them to to have them rebuilt once in a while. Not sure why I don't do it myself. Perhaps the cost was so reasonable I did not want to bother. Either get a rebuild kit and DIY or take it into a local shop.
del schisler
sure go here and see if you can find the model number. Even if you don't get parts from them you will at least know what is inside. Or order the rebuild kit ? good luck
http://www.ereplacementparts.com/search_result.php?osCsid=c1o8auk447p5pc0feddgernu71
Larry in nw ohio
We had this same thing and sometimes if we would disconnect the hose and then hold the trigger in and then reconnect the hose it would take care of it. If that didn`t work we had to rebuild it. Good Luck. Larry
Thanks everyone
Alan
I had something similar happen earlier this year and it was a bad o-ring. I called Grex and their support was awesome. They sent a new o-ring, talked me through the install and it worked great. One thing I learned was that you shouldn't oil it every time you use it. A lot of the time this problem is related to over oiling. Anyway, good luck.
Yonak
Alan, I called Raymond at Grex technical support and I had the same experience you did. He couldn't have been more helpful. He was on the phone with me for probably 25 minutes helping me examine the problem and the gun. He decided it is an "O" ring and he's sending me a replacement, gratis. Terrific customer support.
