OT - Need to build a temporary ramp
Joe in a Cleveland suburb
Hello.
I need to build a temporary ramp off my back door this weekend for one of my elderly Golden Retrievers. She is almost 14 years old, is now blind (glaucoma), and her hips are getting tired. Steps are getting hard for her I need to do this and get her used to it before the bad weather sets in. I built one a few years ago for another Golden that lost a leg due to bone cancer. His cancer battle didn't last long though and I took it down. What I built before was pretty crude. I want to do a little better this time.
Below is a crude image/drawing of what I want to do. I've noted my questions on it and hope some of you can offer some suggestions.
The brown parts are what I want to add. It will completely cover the steps.
The ramp part needs to be about 16' long with the least amount of angle to make it easy to walk on. I have lots of 4x4's laying around to use for supports and so on.
I will add supports and a railing as needed not shown in the image.
The steps are PT lumber and anchored to the house - I don't know how I didn't build them but they are solid.
I basically want to add a platform that will sit on the second step from the top and support it with the 4x4's.
I don't know what methods should be used to attach it and not sure how to figure some of the angles.
Where the ramp meets the driveway, I don't know how best to figure out that angle either.
Keep in mind, this is for temporary use and not for people traffic. Well, one person would be helping guide the dog.
Thanks in advance for any suggestions/advice.
Joe
Re: OT - Need to build a temporary ramp
Kneale Brownson
Kneale Brownson
I'd lag (or bolt if you can get to the backside) a 4X4 to the riser below the landing as the top anchor, leaving enough space to allow for lagging the outside 4X4 support to the anchor.
I'd use the railing (I presume that's the purpose of the brown parts on the other side of the steps) uprights to support that side of the ramp. I'd also want that railing system to angle with the steps so the handrail is at a consistent level from the treads.
Lay the supporting 4X4s in place and scribe the angles you need. They will be very acute at the pavement level. That's what I did when I made a wheelchair ramp for my dad years ago.
A friend who did a similar project for the dog used carpeting on the top of the ramp to give the dog a better grip sensation.
Galen Vetterick
For your platform I would use 2 x6 for the perimeter frame and block the weight on the second step. You probably would not need it secured to the step. Even a 2 x8 notched to set on the step. This will give you more depth to secure railing post to the face frame. Allows depth to block under the ramp conection also. You would not need the extra supports to the other steps. A diagonal brace from the top right post to lower left post of your outer support legs to take thrust from ramp and for stability. 4x4 for a 16 foot long ramp would need at least a midspan support to the ground or again use 2x8 for a deeper member to attach the railing.
Just ideas.
Re: 16 degrees
Lynn Baker
Tan angle= 37"/(16' x 12"per')=0.1927
arctan .1927 = 10.9 degrees
Lynn
Larry in nw ohio
What Galen said, support it from the first or second step and I really don`t think you need to connect it to the steps. It`s probably going to be heavy enough that you will not need to bolt it to the house. If you think you need to, you can always do it after you see how it works. No use to connect it if you don`t need to. Good luck with your puppy. Sorry to hear about the problem. Larry
temporary ramp (long, slightly random response)
The risers are often rather thin stock, and not fastened in a way that would support a vertical load well. I'd consider resting a support on the second from top step (where your platform starts). However, you might toe-screw through the risers into the stringers to hold them in place. That way, when you remove the platform, the holes you need to repair will be vertical, rather than on the steps, and less prone to welcoming rot into the stair assembly; pressure-treated lumber is, really, treated only for the first fraction of an inch, and holes that penetrate through to the untreated wood encourage rot. You can get some pretty nifty screws at your hardware store. Don't use the cheap #6 deck screws; they're pretty brittle. Step up to the slightly more expensive #9 or #10 screws, which, in addition to being thicker, seem to be tempered better for strength (GRK is, in my limited experience, The Brand To Get, but other brands will work; just that the GRKs drive more easily).
We have finally come to recognize in our family that "temporary" means "probably no more than ten years," and I tend to build even the temporary stuff as well as I can. So remember to treat the cuts on your wood, particularly the cuts on the underside of the ramp's supports where they touch the ground.
Attaching the top of your ramp: bolt (3/8" or lags if the framing doesn't lend itself to bolts) a ledger to the uprights on your platform framing just below where the ramp stringers will hit, then toe-screw the stringers to the ledger. You should notch the tops of the stringers such that they sit flat on this ledger. Arrange your platform framing so that there's an upright behind each stringer, and toe-screw the stringers into the uprights as well. If you REALLY want to go first cabin, drill down through the stringers for counterbored lag screws into the ledger, and add a pressure block between the stringers - a 2x4 cut to fit moderately tightly between the stringers, and screwed to both; this will fight against any tendency of the stringers to fall over.
As to getting the angles, I think I'd do it one of two ways: 1) set up the stringer stock with appropriate blocking (really thick shims, in other words) so the top surface parallels what you want in your final layout and then figure out how wide a piece of plywood will equal what you have to remove to get to your final layout. Set this next to the stringers at the top and bottom and use it to draw your layout lines. 2) Same as step one, but guess at an angle, cut it wide of the final line, then repeat step 1 but with thinner shims. I'd probably do #2 if I were doing it.
Fasten the feet of your stringers to the ground somehow. You don't need to worry about uplift too much, but you do want to discourage any tendency to lateral movement.
If you're using 2x stock for the treads on your ramp, use three stringers if the ramp's wider than 36"; if 1x stock, three stringers regardless.
Make sure your platform is laterally braced, especially to resist pressure from the ramp, which will try to knock it over. 1x6 boards from the top of the framing near the ramp to the bottom of the framing opposite should do it; ideal construction would run similar boards back in the other direction, too.
Think long and hard about the uprights for the railing on the ramp; they tend to want to fall over. If you're bolting them to the stringers, put pressure blocks right next to the fastening to tie the stringers together, and arrange your bolts so you can tighten them again later. I think it's still current code that the railing be 36" to 39" above the ramp at any point, measured vertically.
Incidentally, your stairs violate current code in California and probably elsewhere (I think California uses one of the national codes in this area), which (the code) calls for a three foot by three foot landing outside any door before the stairs/ramps start. This is a safety thing, separating the act of getting outside and shutting the door (or opening to go in) from the act of going up and down. If you own the house, you might consider whether your ramp idea is a good one in the long term, too, for the landing as much as for the ramp.
Oh, final thought that I wish someone had said to me at various times when I was building steps (never tried a ramp): remember that your treads have thickness, and allow for this in layout of the ramp stringers.
Gary Smyth
A good surface will be essential. You being smack dab in the lake snow belt consider some sort of snow reduction option. A rough surface that freezes easily will not help. Don't use the heated cable unless there is protection from electrical worry.
You are of course correct , 10 degrees
Bill Tindall
Not sure what I incorrectly mashed on calculator the first time, but a recalculation on the trusty slide rule yielded the correct answer.
How one can cut this angle will make an interesting discussion.
Cutting angles
"How one can cut this angle will make an interesting discussion."
I'm, like most of us, a hybrid woodworker. If I were using 4x4 stringers, as Joe said he is, I'd lay out my cut on both sides and hit them with a circular saw; or hit the first side with a circular saw and finish the cut with a handsaw. Either way, some cleanup might be needed: rasp, chisel, etc.
Jim Pugh
Joe, I just took down a large ramp a few months ago and have all of the 3/4 4x8 treated plywood. It's yours if you want it. I live south of Elyria just off of rt 10/20. jpugh@oh.rr.com
Jesse Cloud
Couple of thoughts...
If the ramp is temporary, I would be concerned with safety, but not codes so much.
I built one a few years ago that used plywood gussets for support and it worked well.
There are lots of plans on the internet, just google wheelchair ramp plans.
I'm sure you already are on this page, but don't spec it just for dogs. If its there, people will use it too.
Gary Camp, Bend Oregon
As far as your angles go. I'd forget angles and grab my trusty framing square. Your stringers are really no different than a rafter with about a 3 (3.08) : 16 pitch. If you are not practiced with a framing square. the booklet that comes with one will explain it better than I. or I sure there are hundreds of sites that will explain how to use the square to make your plumb cut and seat cut. It's kinda fun, and you may learn or refresh a skill
glc
Larry in nw ohio
Bill The easy way to get the angle on the end, is to set your board where it is suppose to be and get a thin board the lenght of the part that will be in contact with the ground and lay it against the part on the ground and trace aginst your board and you have your angle, unless I`m missing something. Larry
