lift table followup
Carol Reed, Strawberry, AZ
Here is the current edition. It did what I originally wanted it to. But improvements are needed. It will be a very cool shop addition.
Originally, I wanted to use just what was on hand. Thus the large wheels in the back and the 3' swivels in the front, and everything plywood. I also had most of the hardware on hand.
Initial torque was so great I did this:
That's when I added the the 1/4" ply 'webs' on the inner frames. Helped some.
Also I bent doubled plywood on the compression members with the threaded rod. So of to my brother's for a little welding job. And then some HDPE bushings to reduce friction.
The table squishy and wants to bind from side to side going up. My thought is the 1/4" bolts are too small in diameter. The 'hinge' diameter on my car jack is 1" and while it has something to do with the weight issue, I think the diameter also lends itself to the side to side squishiness. I am also thinking some sort of 'guide' to help align it side to side as it goes up.
Comments from the backyard engineering department?
