ADVERTISE HERE - FREE TRIAL
Hanging shelves thoughts
Moses Yoder
Moses Yoder
I had this cabinet built for a friend of mine, I just installed it. It's a little over 10 feet long, simple doors with adjustable shelves, a clipped fluted corner. She is interested in some shelves over the cabinet, and I designed some suspended shelving to keep the look clean and simple. See second drawing for the shelves. The render colors are not set up very well, but you get the idea.
First picture is of the cabient that is finished and installed.
The second drawing is part 2 of the project, the shelves above the cabinet. I am interested in feedback on the design, and different ideas if you have them.
Re: Hanging shelves thoughts
Robin Corell in Atascadero CA
Youv'e set it up for something special to go in the middle of al the shelves. In the absence of such a focal point it will make your work will look unfinished. With the right piece of art work or clock it will look spectacular.
Robin
roger lance
Moses....the base cabinet looks great...nice job...a lot of the design questions can depend on what your client intends to place on them...I personally like what you are suggesting providing it suites what she is intending to display. Nice picture by the way.
Yonak
Moses, I realize I'm kind of old-fashioned when it comes to design, but I like to tie shelves together with some kind of frame, with or without backing .. even if the shelves extend beyond the frame .. and it wouldn't have to be square. Since this is apparently in a dining room, it could give it a hutch kind of look. A frame could also help to support the shelves. Just my 2¢ and worth every penny.
Steve Strickland
Steve Strickland
I envision a large mirror with glass shelves. Open for some types of display or enclosed hutch for others. Either one solid mirror or modular with separation if individual pieces need accenting.
Nice work, be hard to go wrong here.
Clint Searl
Clint Searl
IKEA has some just like that.
Clint
Bob Hackett
Hard to give a really good answer unless we know what you plan to put on these shelves and what is being displayed in the center.
If the items going on the shelves were relatively light and you were wanting to display something like art in the center then I`d go for something like slotted oak battens on the wall with tempered glass shelves installed in the slots. Less bulk on the wall, and when lit from above with track or can type spot lights more light to the art and the items on the lower shelves.
My own personal taste goes toward light as possible yet strong strong enough to do the job as far as shelves go. That is unless we`re talking about something like a fireplace mantle or some shelves incorporated with a timber framed house where there are other heavy interior design features to balance visually heavy shelving.
I also like rounded corners on suspended shelves. They hurt less when people walk into them and they will walk into them( DAMHIKT). :(
Fred Davis
On first and second glances the shelves seem massive in appearance, for my own taste , I would lean toward Glass shelves hung any number of ways which let the light through all of the shelves.
Bob has a couple of suggestions along that line. But one never knows , I may be speaking from Clint's view point and you know where that got him.
FredD
I think the shelves look too thick. I recall doing a couple jobs similar to this. One was in a Frank Lloyd Wright house and the shelves were 3" thick like the ones in your drawing. They worked in that room because of the scale of the rest of the furnishings. In your friend's room, the heavy visual weight and monolithic quality of the shelves doesn't complement the finer edges and details of the cabinetry below. They also look pretty shallow.
The other job I mentioned was cantilevered shelving too, but only 1 1/2" thick. I made them out of two thicknesses of 3/4" plywood veneered on the faces and capped with a radiused solid edgebanding. To set up the cantilever, I routed mating pockets 1/2" wide by 1/4" deep in the mating plywood, spaced to match the stud center spacing of the customer's room, before gluing the plywood halves together to form the shelf. Then, to hang the shelves, I made a drilling jig for a 1/2" aircraft drill that kept the bit exactly perpendicular to the wall in both dimensions. I drilled all the way into the wall studs, inserted 1/2" cold-rolled steel rod in the holes, with the ends sticking out into the room. Then all I had to do was slide the shelves onto the rods. There was just enough friction in the fit that I didn't even need to anchor the shelves with set screws or adhesive.
Just a thought, in case you were interested.
