walnut and steel table
Tom Sontag - St. Louis
It has been awhile since I have posted here and even longer since I shared some work, so in order to let you all know I am still lurking and enjoying good 'ol WoodCentral, here is my latest effort.
The design was inspired by a slab of 3/4" (HEAVY) steel and is not complicated. In fact, the only challenge was the 2 1/2" thick miters which are bigger than the table saw cut and shooting board plane I used to make them. Block plane, scraper and square helped get them tight. One coat of walnut dye and two coats of garnet shellac is the finish schedule.
My sister wanted something to put a cable TV box on so I hung a small shelf underneath which disappears when viewed from above. The earlier idea of a lower shelf detracted from the overall look, but she would not let me eliminate it entirely, which the design wanted. Something about the whole purpose of the project or some such twaddle. ;-)
Tom, how much DOES it weigh?
