drill press advice needed
Bruce, a MN Galoot
It's time for a serious upgrade in the drill press department of my shop. For the last 30 years or so, I've gotten by (just barely) with a 6" Craftsman benchtop model that just barely has enough room above the table for a 1/4" bit drilling through 3/4" material. Any more and it simply won't work.
My question is whether I need a floor model or will a decent benchtop version work as well? I have no intention of buying new, so I'm on a constant vigil on Craigslist for one.
Re: drill press advice needed
The following thoughts.
How much quill length (spindle travel) do you need/want?
Do you desire a radial drill press or will a tilting table work for you?
Round table or "square"?
What sort of "depth" do you desire (10", 15", 17")?
Do you want the laser guides?
My Jet 17" is a floor drill press with a 4+" quill travel. Theoretically, I could drill through 4+" without stopping. Do I need a floor drill press? Probably not. A good bench mounted drill press would work just fine - I could mount it so the head was sticking out beside the mounting bench. I really need the multiple speeds and at least 3/4 hp for the times I use large bits. I've got a round table - I would have preferred a square one - but I put a top on mine, so it works well for me.
So if you want longer spindle or quill travel - you should look at floor models.
If you want more hp - then you should look at floor models.
If you want a radial - then you probably should look at bench.
If space is an issue - then look at bench.
If you need 17" then floor - 15" or less distance from the column then bench.
JMOHNIKE
I have a floor mod. and a radial bench mod. very seldom use the bench mod. One suggestion that I would make is no matter which one you decide on put a foot switch on it makes life so much easier.
Joe
Jim Dillon
Bruce,
I have had a floor-model JET for some sixteen years and it has worked very well. One advantage to those JL mentioned is that a tool cabinet can be constructed that will reside directly under the drill press table. I put mine on wheels and it is elevated enough to slide over the base of the drill press so it can be slid out of the way very easily if you need to lower the table beyond a certain point. This cabinet holds all my drill press stuff (an amazing amount of junk!), plus a drawer for hammers. This cabinet has proven very functional. Anyway, just an added thought.
I have not kept up on current floor-model brands, so I can offer no advice along those lines.
Jim
George Colonel's Workshop-Havertown PA
Good Afternoon Bruce,
I recall the frustration when I outgrew my first drill press. Its replacement was a 12 speed floor model. Eventually, I acquired its replacement, a 5 speed radial press from Grizzly. I like the radial's versitility. My #1 son has a small shop, and I bought him a used Delta 12" counter/table top press. Its plenty big for his needs, and would also do the greater majority of my current work. It cost me about $125, and looked new when I gave it to him. I see them occasionally on Craigs list. I'd consider both floor and table models and either radial or standard configuration. You'd be satisfied no matter which one "appeared" on your Craigs list door step. If you like it, buy it.
George
Steve Strickland
Re: say no to drill press
Steve Strickland
I went through the same decision a number of years ago and found a machine that is superior in all respects. Less quill flexure, larger size, a LOT more quill travel, micro-adjustable X-Y table, geared transmission plus continuously variable speed (no belts). Uses both chucks and collets. I will never waste floor space again with a drill press after having one of these.
And it costs the same as a mid-level drill press.
It's called a benchtop vertical mill.
I have an old (40yrs) Delta Rockwell floor model. It is and 8" (I think) meaning it will drill to the center of a 16" circle. It does not have the rack and pinion gear that raises and lowers the table. The table does not tilt and the head is stationary. It does have 6" quill travel. It has step pulleys and is 1/2hp. Square-ish table.
I like the floor model. Once in a while it really pays off.
I like the 6" stroke. Once in a while....
Hard to think outside the box and know what I would really enjoy, but I think I would like the rack and pinion thing a lot. What I would like even more is some sort of indexing set up so I could make a set up, change it and then come back.
The tilt table seems like a winner.
Radial head, Maybe.
I use mine for mortising and like it well enough, but then I have a small shop and no room for a standalone mortiser and would probably like that better, but one more machine means I just get to look in the door, there would be no room for me.
Been thinking about one of the aftermarket tables but have not gotten to it.
Also been trying to figure a way to make a vertical "table" to allow for it to function like a horizontal boring machine.
bench space more valuable than floor space.
Bill Tindall
If this is the case then the floor model is preferred.
PLEASE make sure . . .
steve mackay
there is more steel than plastic. NO plastic is best. Be sure to, at least, lay a square against the quil and look at any run-out through the travel. My 8" "C-word" (pawn shop special) is all steel & I love it. Throw a 3/4 chuck on it and there ain't nuth'n I can't drill !
Hal
I also have a Griz radial benchtop. Like its versatility. About 3-1/4" quill travel. Enough for most jobs. It's a little sloppy in some adjustments, but that can be overcome with a little fine tuning. Hal
Get thee behind me!!
Bruce, a MN Galoot
That's just TOOOOO much temptation!
I'd love to get a mill. A machinist friend of mine watched me do a complicated set-up for routing out a gun stock and told me I had the makings of a good machinist. Those were words I didn't need to hear. It requires an entirely new set of tools.
Not that that's a bad thing :D
I do know what you're saying, though.
Re: bench space more valuable than floor space.
Bruce, a MN Galoot
Both floor and bench space are concerns for me. Ultimately, though, there is more floor space, a consideration for sure.
Thanks, Bill.
Re: PLEASE make sure . . .
Bruce, a MN Galoot
I do believe the one I'm considering is old enough to have NO plastic. My buddy Bill Houghton says he thinks it's an old industrial model.
It's important, for sure.
That's a really good checklist JL.
Bruce, a MN Galoot
There have been only a couple times (<5) in the last 30 years where I would have benefited from a radial head. It's not so much a matter of quill travel as space between an extended bit, like a Forstner or Stanley speedbore, and the work piece that matters to me. I need to have the room on the column to move the table enough to get the work in there someplace.
Thanks for the hints.
Bruce, a MN Galoot
I like the idea of a cabinet covering the base. I have more floor space than bench space, but even so, floor space is at a premium. That sort of cabinet would be a very good use of that limited space.
Thanks, Colonel and Hal,
Bruce, a MN Galoot
I don't need much in a DP, just more than I have, just a longer column and greater quill travel. Oh, that and a table that will lock without having to put a C-clamp on it to hold it.
Thanks for your reply.
Bruce, a MN Galoot
It sounds like you have what I need, Barry, and for exactly the same reasons. Thanks for your reply.
roger lance
Bruce...I have and recommend a floor standing DP....mine is a Delta 16 1/2"....a 17-900 I think....what I find remarkable is the amount of use this thing gets....its involved in nearly every project....use it all the time....I think DPs are under rated for their importance/value....its really a major part of the shop....so I recommend getting a good one....make a wood working table for it....get a table that pivots (just used mine to drill recesses for levelers in the bottom of a cabinets legs)....and even consider mounting it on a mobile base as you might have to move it as I do from time to time (to accommodate some large/long work piece for example)....good luck.
Larry in NW Ohio
Bruce If I were in need of a drill press I would do as Steve said, get a drill press mill. It can be a drill press or a mill, and it would be more solid and accreate. Larry
carl civitella
Good idea
Snatch that sucker !
not all radials are created equal
Robin Corell in Atassadero CA
I own a Delta Unidrill. They are a 60's vintage tool and a bit rare but worth the search. They sold in several ways, as a kit to convert your existing drill to a radial or as a compleate unit including table and legs. The later option is what I have. The legs weigh 90 lbs and the table weighs 150lbs the column and drill head add a bit over 200lbs for a total weight of just over 350. Definatle not a bench top tool!
the reason I like the Unidrill over other radial drills is because the arm articulates rather then slides like a typical radial arm saw. this means I can place my drill against a wall and still have full use of it. I can articulate the arm so that I can drill at any spot on the 24" square table or swing the drill head to the side and have a very sturdy 24" square steel top work table.
I rarely use the tilting head but I do find that I use the radial all the time. It is really nice to be able to do a set up and then if I am of by a fraction of an inch rather than redoing my Rube Goldburg clamping arrangement I can just loosen the radial clamp and nudge the head which ever what I am off.
I have a VERY small shop so I have to be very critical of any new tool and it has to earn its keep to justify floor space or bench top space. The large table of my radial makes it serve double duty and more than earn its keep.
I forgot to mention that the drill capacity is something like 27". It is a bear to crank the drill arm higher on the collumn but it can be done and I have taken it up to about 15" before. Just thought I would share another option in the used drill press arena
Robin
Leo Cuellar
Leo Cuellar
If you buy a floor model, you might consider putting it on a mobile base. I have an older Griz' 12 speed that this has worked well with, having the option of rolling the drill to where the space is is or easily rolling it out of the way when not needed. Bolting it to the base makes it way more stable.
