need help finding a source for a router bit
Robin Corell in Atascadero CA
I am not overly fond or routers so I don't keep up on the latest offering of bits. I do own a couple of routers and occasionally use them for what they can do best, work horse tasks.
Currently I am filling some shop time finishing up a door for my own home and I find myself turning to my router to chamfer the edges or the rails and stiles. The standard 45* chamfer looks, well, ...standard. The design of my door is inspired by Greene & Greene and I would like to use a 60* chamfer. In the past I have used something close to a 60* chamfer and it looks more like a bevel and adds a degree of elegance to the design. In the past I have added this detail by hand with a spoke shave but in this application I would prefer to use a router due to the amount of linear feet I need to do and the wood I am using does not work well by hand.
I found an Amana bit but it is 2 3/8" in diameter and sells for $99. I was hoping to find a smaller bit that I could use in my trim router and maybe pay a more reasonable price. Does anyone know of a source for what I am looking for? I would like the bit have a bearing and cut � in depth and 7/16 on the face, or something close to that.
Robin
Re: need help finding a source for a router bit
I didn't find anything under 60 degree
Gary Smyth
chamfer bit but there are 60 degree "V" groove bits offered by Whiteside, Freud, Highland Hardware, CMT, Vermont American. These are usually 1/2" deep. Check out "60 degree router bit" on Google and take your choices of what is offered. If you get close after checking out what is posted perhaps some have the availability of a bearing. Ace tool has a 60 degree with a bearing and 1/2 shaft.
You can check out Router Forum too. Sign in/register and find the router bit category. Write your request.
Yonak
Robin, check out birdsmouth bits. Maybe you can get one of them to work for your purposes.
Jim DeLaney, Austintown, Ohio
Re: source for a router bit - MLCS *LINK*
MLCS has relatively inexpensive chamfer bits that'll do what you want. They're pretty good quality, too - maybe not as good as Freud or Amana, but still quite good.
Chamfer bits
Re: I didn't find anything under 60 degree
30� bits are readily available. Use it from the edge, rather than the face, and it'll be a 60� chamfer.
Ron Bauman
No 60', but some others. Maybe two 30's, no that's not right.......
http://www.woodline.com/p-1447-chamfer-bits.aspx
Moses Yoder
Re: 120� bit
Moses Yoder
I am not seeing any router bits that route 120�, which apparently is what you want to do. 1/4" deep and 7/16" on the face. It seems most of the responders are missing that, because they are pointing you to bits that would route 1/4" on the face and 7/16" on the side, although you could probably flip them and route from the face but on end grain it seems like the tearout would be terrible. If I was doing this I would set up to cut the angle on the table saw with feather boards then smooth it with a block plane.
I probably should have been a bit more explicit in describing what I am trying to do and why I need a 60* bit rather than using a 30* bit or cutting the bevel on my table saw. All these suggestions are good and would work in some applications, just not the one I currently facing.
My door has arched rails with cloud lifts which make routing from the edge impossible. The arched rails also make cutting the dado for the panels on the table saw impossible. My solution is to cut the mortise and tennons in the rails and stiles and clamp everything together and rout the dado with a wing cutter bit. I would like to profile the edges of the openings for the panels at the same time. That would leave mitering the corners of the routed chamfer as the only hand work and really speed things up if end up making more doors
The attached pic is of a door I made using the same basic design but different dimensions from the one I am currently working on.
Robin
Leo Cuellar
Leo Cuellar
Another possible option is to put a tapered sub-plate on your router, if you can't find the bit you are looking for. Or your local sharping shop may be able to regrind a bit for you.
Larry in NW OHIO
Robin Looking at you door in the pic, on the right side and at the top of the right panel and right stile there looks to be a strange "seperation on the center cross stile where it connects to the right stile or my eyes are seeing things. Do you see it? What am I seeing? BTW love the look. How did you do the panels? Larry
The door in the pic was made from douglas fir slavaged from large vats used in making marachino cherries. The "gap you are seeing is stain from a spike. There is another stain near the bottom of the rail on that same side. The finish on the door was very dark and the stains were minimized but stil visable. I wanted the doors to look like they might be original to the house which was built in 1918.
The panels in the door have a hand carved texture in the field which was done by hand with a 1" wide #5 sweep gouge. I cutraised panel detail on the edges with my table saw and on the ends by hand with a combination of chisels. planes and spoke shaves.
Robin
