What do you use on your "drifting" set screws?
A little bit of CA glue or what?
I've got a set screw that keeps moving with vibration. It's only the one screw - but it is annoying.
Re: What do you use on your "drifting" set screws?
Thomas S Stockton
Use loctite. their are a few different types but the main difference is how permanent the bond is I use the stuff is less permanent. The other type needs to be heated for removal. A little goes a long way
Any auto parts store carries it.
Tom
HD has the "blue" version
Mike Farinella
Loc-tite is your friend
Gary Smyth
Use the blue, I think its 242. If it's good for Boeing and the Auto building guys, it generally works for me. 1.69 oz will run you around $26. Use a drop on the stud and screw it in. The red is more permanent but has been said, once in it takes a torch to break the bond.
Double up on the screws.
Phil Joines
Galen Vetterick
Loc-Tite is great but you can also purchase Nylock or Patch Lock set screws that had a nylon button in the threads. Depending on your application a nylon point set screw can be used that keeps a preload on the set screw.
Just other alternatives. I've used a piece of lead shot under the set screw as well but is harder to remove in the future.
roger lance
Where possible, a longer set screw....manufacturers evidently try to save money by using the shortest set screws they can find....or blue lock-tite.
Steve Strickland
If it's a recessed set screw blue loctite is quite good. If it's a protruding set screw you might use a lock nut.
I concur on the Loctite and, if you can find one, a setscrew with a nylon insert. One of the classic methods, if the threaded portion of the component is long enough, is another setscrew stacked on top of the first one, to serve as a kind of jam nut (jam screw?). But the Loctite's your best bet.
The packages used to have a little chart on the back - it's been a while since I bought any, still using up my current supply - that recommended the grade based on the size of the threaded component, as well as listing the heavy duty stuff*. Pay attention to that chart in making your selection. Any decent auto parts store, and your better hardware stores, will offer the full range.
*They even make a bearing retainer that will hold, for instance, the outer race of a 1973 Volvo rear axle bearing in place after its predecessor spins and makes too much clearance in the casting. Just for instance. You wouldn't want to use that on your setscrew, unless you never want to get the machine apart again.
Will try a little "plain" Loctite.
Larry in NW OHIO
Contraryto what Phil said do not put one on top of the other. We had some people at word do that and we had one he-- of a time getting the bottom screw out because the top screw reallt messed up the place where the allen wrench went into and could not get it out. Other times it broke the bottom screw and the wrench just turned in the hole, we ended up drilling them out. Larry
Try shellac -might work, can't hurt
DizD
Re: HD has the "blue" version
Tom MacGregor
#262 red, for 1/4" & larger diameter fasteners you don't plan to remove.
#242 blue, for 1/4" & larger diameter threads that you want to be able to remove.
#222 purple, for under 1/4" diameter fasteners.
#268 red & 248 blue, thick paste in chapstick type container +/- $15. Favorites of mine as they won't drip or leak. Great to keep in the bottom of the toolbox.
Nylon insert set screws are available through McMaster-Carr, but why not get something that works on anything with threads? Loctite keeps forever on the shelf. The setscrew probably isn't the last fastener you'll ever want to secure. I've done commercial and industrial maintenance for over 30 years and couldn't operate without the stuff. They also make excellent anti-seize products for fasteners that tend to freeze up such as lug nuts.
