We value your privacy.
I'm looking for a good rip fence for my older 70's early 80's craftsman tablesaw. Cast iron table contractors model. I see alot out there the shop fox, unifence, vega etc and I would like to know if there is anyone out there with a saw similar to this one that has put on a good rip fence on. Am I wasting my time and money? Should I just consider a new tablesaw? I'm not a cabinate maker or anything like that. A hobbiest more or less. Probably what doesn't help my woodworking is that I'm a 30yr Tool & Die maker and I'm just used to machines that do what they are soposto do without so many headaces.
I have an ad for a fence in the classified section here.
Dale The first thing is to ask yourself, how much I like doing woodworking and if I`m going to keep it up for a long time and make things for my family. If so if it were me and had the money I would go for a new cabinent saw, of course I like my Unisaw, of course everyone pretty much likes the saw they use. But if you just want to tinker around I would go on Ebay and look at fences there. Of course you probably can put a Biesemeyer fence on it and when you decide to upgrade, you could sell the saw and keep the fence. But I think most saws you but have there own fence with it. Good luck whatever you decide to do. Larry
If you have the cast iron wings, just about any of the major fences will work on it. There should even be holes in the right place. I had one of those and put an incra fence on it. Worked fine. If the saw is in good shape, I see no real reason to replace it unless you just want a new one. I used mine for many years and the only reason I changed it was that my wife got me a Unisaw for Christmas one year. Cabinet saws have advantages, but the contractor saws work well also and many here on the boards have them and get great results.
I put the Vega Utility fence on my model 113 craftsman saw. Best thing I could have done next to getting a new saw.
The optional finger saver and the stock feeder/hold down are very nice as well.
I've had it for years now and have never had a problem with it, or had to readjust/alighen it. Also it bolted right on the saw with little modifications.
Thanks for your input Scott! That is what I'm kinda looking to find out. Not sure what the 113 model is nor do I know what model mine is I just no my Dad picked it up for me and well I just hate to discard the saw for sentamental reasons. The saw just don't perform the way I think it should. Especially ripping. It don't want to rip straight or parallel. I went thru the tablesaw tune up from one of the websites I was on and honestly I really didn't see any difference.
Yes part of me would to buy a new saw & honestly I problably don't need it but I have ALWAYS wanted a new tablesaw. I know if I do get a new one I won't get rid of this one because my dad got it for me and he really thought he did something for me. I don't want to hurt his feelings so I will keep it if I do.
Thanks for your thoughts. Yes I would like to get a new saw at some point. Maybe I'll fall into something at some point here but I'm not ready to get one just yet. I kinda thought if I had a good fence I might be able to hold out a while longer. Thats why I was considering a replacement fence for it.
After the last responses to my post I thought I would try to post a few pix to give you an idea of the saw. I'm not sure of my model but on the front of the saw it says "100" so I'm guessing that it is a model 100. As for the side extentions to the left is a thick stamped sheet metal extention, to the right of the blade is a cast aluminum NOT cast iron side extention. I tested it with a magnet and a file.
Well I tryed to get a couple of pics uploaded but I can't get it to do it so I'm sorry I can't get any pix!
Thank you DLW! That is actually where I was looking at 1st was Grizzly but then I started kinda reserching the thought and started to get confused with everything that was out there. I'm sure that if I put a new fence on the saw it has got to be better than the original thing that is on it.
I think that the Delta T2 is probably your best bang for the buck when it comes to fences. I've never heard a bad word about one, and they can be had for about $150. There should be a Identification plate probably around the back of the saw. It should have a Model No. and a Serial Number.
I had a top of the line Craftsperson saw purchased in late '70s. Upgraded to a high zoot Jet cabinet saw ca. 2005 (?). I've got lots more to say... but here is the bottom line: I could have saved a lot of money if I had added a top line fence (read: Incra) and some top line thin kerf blades to the Craftsman. I think high horsepower cabinet saws are overrated (and I own one). I used to do beautifully accurate work on the Craftsman. The Incra fence and a good after-market miter gauge would have done everything I now have. Now, many hear will chime in with advice relative to the "contractor" vs. "cabinet" saw. Problem is that "contractor" covers the whole d*&%ed range from trash to just below cabinet. The top line Craftspersons are just at that transition point, and are NOT THAT BAD. When somebody bad-mouths a "contractor saw", I think they are talking mostly about somethin other than what you and I have (had) in a higher end Craftsman.
I almost agree totally with what you said but would make one defense.
I, too, owned a good contractor's saw (Grizzly) that I later equipped with a Vega fence. Adding that fence made the whole saw much more accurate and quicker to set up for a cut. I made many nice projects and money with that saw.
I,too, sold it and purchased a Jet cabinet saw. The level of accuracy was about even between the two. The real difference and main reason for the newer saw was power. It really comes down to what you're doing and what your needs are. Even a 1.5 horse sporting a thin-kerf blade does not handle heavy stock as well or as quick as the 3-horse will. Also, when you're building for pay, time is money! Otherwise that old Grizzly would still be here.
Thanks for the info Chuck. I hate to admit but I havn't heard of the Delta T2 fence but I will look into it. I'll also look around the back of the machine for a tag.
Well now that it went in this direction, I can say that I've had an American made Delta Contractor's saw with the Unifence since I bought in new in 1995 and have no plans of geting rid of it anytime soon. I think where alot of people run into problems with power on these saws is that they don't run them on a dedicated circuit, they just plug them into any outlet in the shop that is probably running other things on that circuit, lights, air filtration machine, dust collector, radio, etc. I wired my saw up to 230 V and with a good blade it will cut just about anything, and if it has a tough go of it, then maybe i'm useing the wrong machine and should be useing the bandsaw.
Nice to see someone else from the Mid Michigan area here. Anyway thanks for the info! Its really funny you bring up the aftermarket miter gauge because that is problaly the next thing I was going to consider. I'll do that on another post at another time. Yes I had looked at the Jet cabinet saw at Woodcraft in Saginaw the other day and it does look very nice. Don't know exacty where you are but I'm in Auburn Michigan, if were close enough might be fun to get together and meet sometime. I'm going to be off work for 12 weeks. I just had back surgery so I'll be around the house for a while.
Dale You got a lot of very good input and things to think about. The first thing you need todo is get your new fence. I don`t really think which one you do get, they probably alot better than the one you got with your saw. Craftsman isn`t known for very good fences. When you get it put on you need to realine the saw again. It sounds like you didn`t get the manual with your saw. Do you have any idea what happened to it? Anyway there should be a serial and model # on the saw somewhere. Like someone said in the back most likely. If you get that then you can go to the Sears site and download one. Good luck with what ever you ndo and most of all keep in touch. You have come to the best site on the net. I`m courious, how did you find WC? Larry
Again thanks for the input! I was up lastnigth till 1:30am tinkering in the shop and I did find a serial number on the machine. Its one of the very same models alot of people talk about. Its a 113.2999. I don't have a date anywhere on the machine but I'm just guessing about the late 70's early 80's vintage. No I never did get a manual for the machine. My dad just picked it up for me on the way out to my house one time and he got it for I think he told me 70.00 but I'm not 100% sure on that.
I did a search on google for the best aftermarket rip fence and one of the reviews/articles come up from this website. After reading that I kinda poked arourd the webiste and decided to post something about it. Your right I did get alot of input and I'm sure no matter what fence I decide to put on it will be a major improvement to it. I'm going to post something else up higher in the thread check it out. I'm not to sure about what I just found out about this table.
I was up lastnight till 1:30am tinkering in the shop and I did find a serial number on the machine. Its one of the very same models alot of people talk about. Its a 113.2999. I don't have a date anywhere on the machine but I'm just guessing about the late 70's early 80's vintage. I never did get a manual for the machine.
Something else I found out accidently working around the machine was I set a 18" scale on my table and noticed a large gap in the middle of the table. I said wow and cleaned off the table and honed it and took another scale and checked it again. I find that if you check it going diagonal one way its fairly flat. .016 or so, but go the opposite way its like nearly 3/32 or .093. I'm a tool & die maker and I'm used to working down to the submicron increment (at times less than .0000397") if something was out like this on anything I ever worked on I'd never make a good part! Forgive me for asking here but what is an acceptable table flatness for a tablesaw???
I agree with most everything that's been said. I have had a Delta Rockwell contractors saw for about 40 years. It came with a 1 1/2hp motor and that died early on. I replace it with a 2 hp. Several years ago some one on WoodCentral (bless them) posted that Lowe's was liquidating Biesemeyer Fences. Normally $400, they sold them for $80. I could not do 400, but for $80 I jumped. It was a MAJOR improvement. Significant improvement in the joy of using the saw. One thing, you have not posted a picture, but my saw had grids for extensions and the Beis fence slides on the table at the far end. It would not have worked well or at all on the grids.
So, I epoxied strips of plywood between the rails on the wings and ran them through my Performax to level the top surface and cover them with Formica. I also covered the extension I had added that included a router table. That was a significant improvement as well. I had not realized how much the grids bothered me. Other than having to cover the wings with plastic laminate, the fence bolted right on. And If you could get one as cheap as I did I would recommend one to every body. Even at $400 I would still recommend it.
I am a hobbyist also. I do "everything" with my TS. I am pretty sure it won't rip 3" think maple all day long as well as a cabinet saw, but I have ripped all the thick stock I ever needed with my saw. I cut tenons with it. I rip long miters to glue up square posts. I can't think of anything I have wanted to do that It would not do. I even ripped 6 x6's by ripping in from one side and turning them over and running them again. You would have had to do the same thing with a cabinet saw, because a ten inch blade only has so much reach.
I would put a better fence on the saw. You obviously want to keep it for sentimental reasons and I perfectly understand that. I think any of the fences mentioned here would be good. I have never used any of the others, but people here have and they like them. You might be wise to pick on that does not slide on the table on the far end, if that's available. I might replace the bearings if you have any doubt about them. And, I would get one or two excellent blades. After all, that's where the rubber meets the road. The finest TS in the world will make poor cuts with a poor blade. This will start a round of whose blade is best but I have a Forrest WWII and like it. I need a good rip blade, but that Forrest blade stays on my saw 90 percent of the time and was a major improvement also. Even if you decide to sell the saw, you can keep the fence and the blade.
Also consider a dedicated 220 circuit if you don't have one and your motor will convert.
Put Sears Craftsman Tablesaw 113.2999 into google and it will send you to the Sears site and the parts list. And they have manuals available. I did not spend much time there, but you might find it a place to start.
Boy I wish I could get one of the Biesemeyer Fences for 80.00! What a steel! Right now I'm tring to figure out whether or not the saw is worth putting the money into it. Don't know if you caught my last post but my table is so out of flattness that I don't know if it would even cut square with a good fence & a Frued blade! At this point I,m thinking that maybe the trunnion bolts under the table are torked down so tight that they are pulling the middle of the table downward giving me the big out of flatness I'm seeing.
I did find a site where I was able to download a PDF of the manual so thanks! Someone posted to search the net as well.
I have a pix of the saw but I wasn't able to get it uploaded to this site. My side extensions are to the left is a stamped heavy sheet metal extension and to the right is a cast aluminum. Neither of them are the grid type you describe. I think I know what your talking about.
You need to set up a profile in order to post pictures directly. (They also have to be 80K or below) You can put as much or as little info in a profile as you like, but having one will enable a bunch of features as well as give you the ability to edit your messages for some period of time and set a password so no one else can post as you. (not a problem on this board, but for some people it is important. Just make sure you spell everything in the profile EXACTLY the way you plan to post because it is very literal. Upper/lower case, spelling, punctuation etc. are all important.Strange that my computer always does what I tell it to do and not necessarily what I want it to do
