Shop Ideas
Shop Ideas
Jim in Burlington Ont.
Shop Ideas
Jim in River Oaks, Ont.
Hi,
Well it looks like if all things work out as I hope, this will be my new shop sometime within a year or so.
Photobucket
Any ideas on what I should think of doing before I move in, it has wooden floors and concrete as well.
Take care,
Jim
Re: Shop Ideas
Re: Shop Ideas
Dave Bair, Eaton Rapids, MI
Heat this one.
Re: Shop Ideas
Re: Shop Ideas
Oh Yeah!! :D :D :D :D
Re: Shop Ideas
Moses Yoder
Re: Shop Ideas
Moses Yoder
If you are still in Ontario, you will probably need to replace those front doors with something that is insulated and seals to the floor. I would take a cad program and lay out all my tools and cabinets, making sure there is enough power near everything to run it. And light it well too.
Re: Shop Ideas
Alan Young
Move it
Alan Young
to Ypsilanti Michigan
Re: Shop Ideas
Re: Shop Ideas
Thanks Moses,
I will plan on that, it needs insulation and power, it has 40 amps now, but that will need to change. I like the over all look of the outside, natural light through the windows, wow...I can hardly wait.
The building is part garage, part shop, it is a T shape with the T across the end of the garage. The shop is 24x 32, the garage part is 20 x35 roughly. There is a second floor over the garage section.
Take care,
Jim
Re: Shop Ideas
Re: Move it
Hmmmmmmmmmmm :) Nah... It's kind of in a good place now, but when the day comes I will send you directions... :D
Re: Shop Ideas
Alan Young
Re: Move it
Alan Young
Looks like a terrific building Jim. Hope it all works out.
Re: Shop Ideas
Wire . . .
steve mackay
outlets, outlets, outlets, lighting, vac system wiring, more outlets. Do it now.
Re: Shop Ideas
Re: Wire . . .
You are so right Steve,
I have found in my 18x18 home garage that even that small space needed a lot of outlets.
The building was constructed in 1967, it's sound and structurally in very good condition. I will have an electrician look at what is there and then decide what wire to replace and where to drop new lines. I have my 5 HP cyclone in mind to be the lungs of the shop as well as a few air cleaners.
I am thinking of some venting in the roof, but the large window over the garage door is an awning window and there are two on the back as well, so cross flow might be there now. The current owner likes to build Muskoka Chairs, the wood of choice is eastern cedar so the shop has a heavenly scent now.
I am making a scaled drawing of the building on my next visit, electrical will be one of those details that I will focus on before it all is insulated.
Heat is another consideration, the house is on a natural gas line, so bringing it to the shop will not be a problem, I remember Joanne's radiant heat floor, it's on a wish list.
Take care
Jim
Re: Shop Ideas
Re: Shop Ideas
Partition it.
I don't know how much finishing you will actually be doing. One of the things that I regret in my shop is that I don't really have a finishing area per se. If you have a "clean area" that is separate from the shop part - that would be a good thing. You've got almost 1500 sq. ft. between the two areas. A 10 x 24 clean area would be good.
Re: Shop Ideas
Rebuild it *LINK*
Stuart Johnson
first using SketchUp. You can add all you equipment, benches, electrical and everything else and see how it will look and function. If you aren't currently using SU here is a great set of tutorials. Start with lesson #1 and by the end you will be able to layout your entire shop.
SketchUp Tutorials
Re: Shop Ideas
Be very, very careful
when you stand near it, because the suction in your vicinity is so great you're likely to pull the trim off.
What a great shop space. I am currently tinged the color of the siding (envy green).
When you wire it, don't skimp on outlet locations: you'll inevitably need some in places you didn't realize you would.
Re: Shop Ideas
Right off the bat I'd look
Gary Smyth
at that gutter and downspout arrangement. In a wooded area with snow and that large and pitched roof I'd think about that. In its present form it appears to be undersized and a leaf catcher. I'd also build up the door threshhold so that critters don't head for the warmth in the fall. Just make it seal enough so that it blocks and redirects damp and still can be swept or blown clean from the inside. A six foot pad of asphalt across that door space might do the job nicely.
Re: Shop Ideas
Sounds like . . .
steve mackay
you've got it go'n on ! Igotta tell ya' too . . . it sure is good look'n. I envy ya' !
Re: Shop Ideas
Is it insulated?
Dale  Lenz
Re: Shop Ideas
Re: Shop Ideas
Jesse Cloud
Is access to the shop through the garage? If so, you might consider opening a door and an access route directly to the shop. It would make lumber delivery much easier!
What a great spot! I too am envious.
Re: Shop Ideas
Absolutely charming!
Joanne in Point Pleasant, PA
Great spot! I agree about the insulated door. If those windows are not insulated, I'd do those, too. And when you put in wall and/or ceiling insulation, put more or a higher R value than you think you need. It's more expensive, but you'll save in heating costs in the long run. If you are doing it yourself, wear long sleeves, gloves, a mask, and eye protection--insulation is nasty stuff. And have tweezers on hand to pull out insulation splinters. Sorry I'm not closer--I'd come help. Take pics of the inside on your next visit.
Re: Shop Ideas
Re: Shop Ideas
Don Orr
That looks great Jim. You have received a lot of good suggestions so far. The only thing I can recommend is a WoodCentral picnic/work party to help you move in. :D ;)
Re: Shop Ideas
First things first
Alan in Little Washington (NC)
Survey the building carefully- now is the time to replace any rotten or undersized structure. Look closely at the sill plates for rot and/or termite damage. Also check out the roof structure and roofing materials- you don't want water leaking on your machines. Inspect the drainage to ensure water flows away from the building.
I would inspect the concrete floor and if it is not too much problem- have it dug up and lay a new level and smooth concrete floor with a good vapor barrier in the entire building and give serious thought to in-floor heating, or lay an insulated wooden floor throughout.
Once you do the inspection and repair, and have a good floor you can do any structural mods- removing wall between garage and shop or walling off one wing of shop for a finishing room.
Unless you want to retain the exterior appearance just as it is, consider adding skylights and maybe windows, for more natural light.
What a great building and opportunity for a great shop!
Re: Shop Ideas
Jesper, Denmark
Re:Stealth Gloat???
Jesper, Denmark
Looks like you sneaked a little stealth gloat in on us, Jim.
Congrtulations. I hope it is not too far from your house, as you will be spending much time there.
You have lots of good suggestions here, so I will only add a little from my recent shop clean-up: All of the various bits and pieces you collect over time have a habit of beeing forgotten, unseen and covered in dust. I have just re-vamped my storage area and put all the small stuff in clear plastic boxes WITH LIDS.
The boxes are labelled with contents on both ends, so you can read the label no m�tter which way they are put on the shelves, as well as see what is in them through the clear plastic.
Re: Shop Ideas
Re: Shop Ideas
mdclor
Jim,
I don't know how you would do it, but I would try to figure out an easy way to get lumber up stairs through the front window using a pulley system of some sort. It would make a great storage area.
IIRC, I saw an article that had a beam that could be extended outward from inside the building with a pulley/block and tackle on it, then once the load was lifted to the proper elevation with the pulley, the beam was pulled back inside the building.
Once you have all the electricity and insulation in place, you will need dry wall and paint that off white to reflect as much light as possible. As we age, we need more lumens to see and white will give you the most bang for the buck or perhaps loonie in your case.
I strongly agree with in-floor radiant heat if you can do that as well. In addition to the comfort factor, there is also the benefit of not having your tools rust since they are warm and aren't as likely to suffer from any condensation that might occur, especially in the Spring.
It looks like a great project. Enjoy!
Re: Shop Ideas
Re: Shop Ideas
Jim Dillon
Jim,
What a neat looking garage! Can't add anything to all the good suggestions you've gotten, but if you don't have it, you might want to check out the last issue of FWW (Tools & Shops - Winter) for an excellent article on redoing a garage. Looking at those uninsulated garage doors, I was reminded of the nice insulated wooden doors that were built for the FWW garage. Might be something to consider in your climate. Lots of other tips in that article as well. I'm envious of all the fun you are going to have getting that gem in shape!
Jim
Re: Shop Ideas
Re: Shop Ideas
Mike Rubes, Apex, NC
Hi Jim,
I cannot add anything that someone else hasn't already suggested, but I just wanted to throw in my congratulations as well! What a GREAT looking place! I am sure you will have fun making into your own personal space.
Congratulations, again! The green even goes with the General Green color of your shop!! :)
Mike
Back to winter?!?! in Apex, NC!
Re: Shop Ideas
Green, Generally
Well the green is not limited to the shop garage structure, there are 5 acres of green and a home included.
Photobucket
Some time will pass till this is finalized, but our doors will always be open to those who would like to visit, you may require a passport. ;)
Photobucket
Thanks for all the great inputs, some of which I had never considered, Thank you for adding to my check list of things to consider.. as always you have given me great ideas.
Take care,
Jim
