Countertop Out of the Mold
Jennifer Indy.USA
We pulled the countertop out of the mold yesterday. With the help of my brothers and son we got it out and flipped it over with nary a crack or chip. It was a tad nerve wracking and we probably had more than enough help but I was glad to have too much than not enough help on hand. Despite a few pin holes that we can easily squeegee cement into the thing looks amazing! I am so thrilled about this project. Clay did such a great job on this. We'll let it sit inside the shop for about 4-6 weeks and then we'll call the boys back over and move it and the table it sits on outside where we'll polish it and then haul it inside. Today I started painting the walls and trim in the kitchen. I want all that done before we get any farther on the inside.
Jen
Re: Countertop Out of the Mold
Outstanding !
Don Orr
Wow, that came out great. Love the spiral.
Yessum, that looks good.
Keith Newton----Little Rock, Arkansas
That is fun to see. You can take turns cooking and feeding the beast. ha.
Uh, I mean cleaning up.
I know the feeling. My last one was 14' long, and bout 3" thick. I have forgotten how many bags went into it, but I turned it over all by myself. Of course I was using a shop crane for pulling motors out of cars.
Congrats on a job well done.
Clint Searl
Looks fantastic!
Clint Searl
Fabulous!
Joanne in Point Pleasant
Not sure I like the blue trim underneath; I'd rather see something like a sink there. };-> You know I particularly love that spiral. Mazel tov!
Re: Fabulous!
Jennifer Indy.USA
Joanne, you and I both want to see a sink in place of that blue foam! I'm so anxious to have it in place. I can't believe we have to wait 4-6 weeks to polish it. Oh well, we'll probably just be getting thawed out by then anyway.
Jen
I Missed Something
Jen,
What is the stone(?) inclusion on the right side of the sink and what's its purpose? I remember seeing it in the other pix, but didn't connect with it as an inclusion.
Well that sure looks like a concrete solution for a counter alright! Congratulations on a great result.
T.
Re: I Missed Something
Joseph Mulherin, Sr
Mark, somewnere in the earlier discussion on her and Clay's new sink it was mentioned about how the forms were constructed and with what. Where the sink is was a build-up of foam pieces which are going to be replaced with the new sink after the top is polished , etc.
Ambitious
Rod Peterson�Ormond Beach, FL
Wow. I would never attempt a project like that. I'd be a nervous wreck doing it and wouldn't have the patience for the cure to begin finishing it. There was no question we were going to outsource our countertops when we did the kitchen part of our remodel. Wound up with quartz and love it.
Can't wait to see it installed (and the interim steps along the way).
Rod
Moses Yoder
Moses Yoder
In the first post on this Jennifer said the stone to the right of the sink is where dishes will set to dry; the stone angles towards the sink so any water will drain in, kind of hard to see in the pics. A very nice top Jennifer, good job.
Thanks Moses
I suspected that (of course) but the last pix seem to show it higher rather than lower like an inset drainboard.
Question?
Bill Tindall
I had never heard of this means of making a counter top before. Fashions take a long time to reach E-TN if they get here at all. I have been following this project with some curiosity and what I have gleaned so far is that this means of making a counter top is a staggering amount of effort and time. What hasn't been clear is what is the advantage of this kind of top compared to others?
When we were hunting for rock counter tops the distributor/importer of rock (Slabco) steered us away from many attractive rock types because they were porous. The fabricator was selective about choosing slabs even from the same rock type to be less porous. It left me thinking that porosity was a big issue in counter tops.
Cement would seem to have the least favorable properties of a "rock" type of top. I would think it would be softer, more porous and have less tensile strength than the kinds of rock recommended for this application. But it must have some advantages not obvious to someone unfamiliar with this application.
Re: Crete
is the same as terrazzo which is less porous than some stones. Wear depends on the aggregate and mix ratios. For instance I've done castings with "artificial stone", a 1x2 mix of white portland and marble dust; very hard and durable, especially when slowly wet-cured. Every stone needs to be sealed periodically, and crete surfaces will be no different, although there are addments that can reduce the need.
Crete counters are becoming very popular. Their biggest drawback is the fabrication and cure time. You can get a granite top done in a few weeks (depending), but crete will usually have to be preordered several months in advance. This, according to several contractors who I know, can create real problems when SWMBO wants to change things.
On the other hand, with some study and basic skills, crete counters can, as demonstrated by Clay and Jen, be a DIY project. Stonework requires serious machinery and special skills and materials well beyond the reach of homeowners and even contractors.
Re: Question? *LINK*
clay foster
Bill,
The primary attraction of concrete is the ability to make any shape you want, so that the counter top becomes a sculpted architectural element, rather than just a pretty flat spot to role out biscuits. You can include other components such as fossils, broken glass, cross section of a carburetor, coins, a Gumby doll, or that annoying little dog next door.
It is labor intensive, but the materials are cheap. It does have steel rebar in it, so I doubt it is any more fragile than stone.
It probably is more porous than stone, so it will acquire stains more than stone. The concrete will have a sealer, but that doesn't prevent stains, just gives you more time to clean up that spilled glass of red wine. Stain is just another word for lovely patina.
If you haven't done a Google image search for cast concrete counter tops, take a look. There's some way cool stuff being made.
My second choice for counter tops would be hard maple.
If anyone is interested in a class on using cast concrete for furniture components, there will be a class at Marc Adams this summer on the topic taught by Mia Hall.
Mia Hall cast concrete class.
BrianA
Are you going to grind it down with a course 8o grit to expose the aggregate or just polish with 1500-3000 grit to shine it as it is. I have done them both ways. I really like the ones I ground down to show the aggregate then the high polish grind. Good idea to move the tables out side. I left them in the garage where I poured them and had to catch all the water as I did not want the water to stain the brand new driveway we had just put in with the black water from the grind.
Looks great!
Brian
Re: Question?
Bill, you are right abut things catching on slowly, not just in TN, but VA also. Around here if it ain't Colonial it does not exist. (I am a little surprised to find out Jefferson used Formica at Monticello, but it must be so.)
On one of the This Old House seasons (I think) they showed them casting concrete tops in place out in the southwest. They set up VERY flimsy forms right on top of the cabinets and laid wire in place and then poured concrete stained black on it and troweled and troweled and troweled. At some point they stripped the Styrofoam form off the edges and troweled those into submission as well. Cheap materials and forming, but a highly specialized skill set.
In some cases they scatter various colors of stains on the surface and trowel it in, giving a marbled or stone effect. This is a case of taking ancient materials and techniques and turning out something truly classy.
Google them, I think you will be impressed. While you are at it, look up some of the sink basins they are making by slumping/melting two layers of glass with ceramic dye in between. Some of them are stunning.
Question: What is anyone doing on their counters where porosity matters? I realize no one wants grungy tops or anything that harbors germs, but I almost never put my food directly on the counter. What am I missing?
You're Missing . . .
Last week's scungilli as part of the flavoring for this week's Kung Po chicken :D :D
clay foster
Brian,
I don't think we'll do any aggressive grinding on it, just enough to expose they sand and give it some sparkle.
Answer
Bill Tindall
I just asked LOML and she said that today she wiped up raw meat juice, iced tea and red Jello from ours. I will add to her list juice from a dill pickle.
In any case thanks for the information on concrete. I'll watch for it here.
Re: Question?
Larry in NW OHIO
Barry, I tried to google them, but being the duffus I am with computers I get nothing I`m looking for. What do you google for what you are talking about. Thanks Larry
There's another way too...
John in NM
And I think it predates the method Clay and Jennifer used. Basically you form up and pour right on top of your cabinets, paying particular attention to finishing as there's no flipping involved. The advantage of this method is that it is very cheap and relatively easy. The disadvantage is of course the need to be really good at getting smooth and flat with a trowel, and of course the potential for a horrendous mess right on your new or newly refinished cabinets :D
The other big advantage of the method we've been following here is the ease of doing some really neat inlays :D
A friend of mine did a counter top this way about 10 years ago, results seemed good to me. You can always oil concrete or porous stone with any curing oil to help prevent staining by food products. Countertop salesmen and fabricators would be well served to take a very basic interest in geology and forget all the fretting about porosity. Sandstone is about the only rock that is porous enough to be concerned about, though limestones and marbles are reactive enough to need sealing.
Jennifer Indy.USA
Brian we bought a diamond polishing set of discs that range from 300-5000 grit. We have some test samples that we poured before the real countertop, some with the same stones inset so we can test out where we want to start. I want to see it smooth and shiny!
Jen
Larry Try This Link *LINK*
Jennifer Indy.USA
Here is a Google search for "custom concrete countertop" Images.
Click Here
There you go ...You can't make chicken...
salad out of chicken poop, but you can make a countertop out of sand and cement and....
These images WoW me. Obviously some of them are a huge amount of work and would be very expensive to have them done by pros, but the results are fantastic. Seeing the potential in these humble materials is something like Nakashima seeing a conference table in what many of us would have thought of as worthless trees or planks.
