Concrete Counter Update
Jennifer Indy.USA
Hey Gang,
We�re slowly making progress on our concrete counter top. Everybody in our house has been sick for what seems like weeks so it came to a grinding halt for a few of those. Anyway, we�re back up and running and have things moving in the shop again. We made several test samples and discovered that the Rock Hard Putty we are using to fill the corners and make the edges slightly rounded over was sucking all the water out of the concrete leaving the edges very crumbly and not what we want the finished counter to look like. So we made several more test sample and found that if we seal the Rock Hard Putty with a sealer of polyurethane it takes care of that problem. Yay! I�ve included the first pictures I posted plus a few more new ones. What you see is the cut out where the sink will go and then on the short side of the sink there is a piece of stone that Clay has ground smooth and is set in that brace thing. The brace is holding it up so that it stays at an angle when the concrete is poured. The smooth side is down because that will be the upside when we flip it over. The smooth stone will serve as a built in drain board that will overhang and drain into the sink. The sink is an under counter stainless single tub. It�s really deep. Uninstalled it looks more like a bath tub! On the other side of the sink you see the same stone as the drain board that have been cut and glued to the form in the swirl pattern that will end up at the edge of the sink. Remember everything is upside down and backwards so what you are looking at is the bottom of the countertop. It will end up flipped over and the face of the swirled stones and the drainboard facing down now will be exposed on the finished counter. We�ll install a combination of rebar and smaller wire in the form before pouring the concrete. We�ll mix up outside in a portable mixer that we have and then pour inside the shop where it will cure for a few weeks. We�ll then remove the form and take the counter outside where we will wet diamond polish and prep it for installation. All of the cabinets that will hold it up are done, the new sink, faucet and water filter are waiting patiently in their boxes and I can hardly wait to get this thing done. I just hope it stays in one piece! I have full confidence that the job foreman has all that thought out and under control.
Jen
Re: Concrete Counter Update
Robin Corell in Atascadero CA
Jen,
Everything looks great. One suggestion I have is to do a test of pourimng into the melamine. The reason I suggest this is because melamine is not waterproof. The water will seep through and the particle board will print through. Since you are planing on grinding and polishing it may not be an issue.
I used to make patterns and molds for decorative concrete and plaster casting, collumns, fireplace mantles and the like. We used bondo rather then rock hard putty and just plain particle board, then we sealed everything with polyester resin.
Good luck on the pour.
Robin
That is so cool!
Joanne in Point Pleasant
And a spiral--so near and dear to my heart and view of the world and universe. That thing is huge. My concern would be--is it liftable without a mechanical crane or an elephant? Ungawa!
Re: That is so cool!
Jennifer Indy.USA
Thanks Joanne! I love it too. We talked about what sort of design or pattern we wanted and played around with some of the test samples we made and both agreed on the swirl. I give Clay the credit for the layout. I love the way the swirl's stones gets larger as it makes it's way towards the sink. Yup it will a heavy beast but we've already recruited some help to lift and move it. Heave-ho!
Jennifer Indy.USA
Robin thanks for the tips. We've made a total of seven test samples all of them with the melamine and haven't had an issue yet. All have been left in the molds for at least two weeks. The melamine actually leaves a very slick shiny surface to start out with so hopefully that will cut down on the polishing.
Jen
That is looking good.
Keith Newton----Little Rock, Arkansas
I have done a few of these before, but it has been a while. I like the creative touches that you are adding, but wondering if you have done this before, and are aware of how difficult it is going to be to get the mix to totally fill in between those little blocks.
I guess you know that your friends are going to see the sink as a monkey, or iguana. ha,
Looking forward to seeing the finished product. Good luck with it.
Barb Siddiqui
Barb Siddiqui
What a heavy project! Can't wait to see the end result. You two will Never want to sell this home.
Re: That is looking good.
clay foster
Keith,
This is the second countertop I've done. The first one turned out really nice. I know how the tiniest details (intentional or not) will show up in the final product. I don't do anything without test samples first. You have to vibrate it till the world looks level, but getting small spaces filled can be done.
This is one of the test samples. The rocks are glued to the mold with a thin layer of silicone caulk. The sides are also beveled to lessen the possibility of them popping out when removed from the mold.
Curious
Gary Smyth
What is the procedure for polishing? Are you staining the mix before the pour?
Re: Curious
Jennifer Indy.USA
Gary polishing is done with 5" abrasive diamond discs that are held in an electric polisher buffer etc. I think they go from like 100 grit up to 5000 or something like that? I may be off on the grits. We'll use water while polishing so we've decided to use a pneumatic polisher. We also bought hand held polishing pads from the same company that you can use on the edges and corners. They are similar to a sanding block type of pad.
We thought about staining the concrete and then deicided to leave it natural. We looked at a lot of them and although the color can add a lot of imact and pizzaz we thought the natural color would go well with the stainless appliances and show off the inbedded stone better too.
Jen
Re: Curious
clay foster
Diamond wheels are used in an angle grinder to wet grind and polish the cured concrete. Grinding exposes aggregate, polishing makes it smooth. We're not coloring the concrete. A rich Portland cement mix gives a nice gray color that will compliment our stainless steel appliances very nice.
Jennifer Indy.USA
Posting the same thing....from different locations.
I'm at work laughing!
Small suggestion
Ray - Middletown, IN
I have made several concrete stepping stones for my sister and use a pneumatic vibrator to remove all of the air bubbles. Works really well to get a smooth surface to start with, makes the polishing go faster I would think. If you want to borrow it give me a shout.
Ray
Re: Small suggestion
Jennifer Indy.USA
Hi Ray,
We've used several different methods of vibrating the test samples. From manually vibrating them with rubber mallets to the butt end of an air hammer and other methods. It does make a difference in getting the bubbles out. Seems like they never stop coming to the surface. I was actually going to call around some tool rental shops to see if renting a commercial one is a possibility. If you've got one that we could borrow I would be thrilled to take you up on your offer :) The thought of beating on nine feet of coutertop with rubber mallets is not something I'm looking forward to!
I'll drop you a note well before our pour date and make arrangements to come up and get it. I think we need to let this latest winter blast forcasted for next week come and go before we get into mixing.
Thanks Ray!
Jen :)
Virgil Johnson
Cool stuff. I'm too lazy for a real project like this. Formica is me.
Lacking a conventional vibrator
Galen Vetterick
Make a wooden shoe that extends outside the normal footprint for your random orbital sander and put the edge against the bottom of your form. Wear earplugs!
Jim in Burlington Ont.
There are many sources for vibration
Jim in River Oaks, Ont.
You just have to be creative....
We had a 74 Dodge Dart that had a vibration we never could isolate... Red Green would have found a way to tap into that to get all the Air Out ... LOL
Jim
I don't know Jim...
John in NM
Red might just find a Dart to be too much of a classy ride and opt for a K-car :D
You know you are right about that...
You are right, we want real vibration, hmmm nothing says "Shake" like a 1975 Chevy panel van with a moon window and an airbrushed mural of a wolf howling at the night sky!!
:D
Caulking things in place
BrianA
When I made mine I put in a couple of perforated stainless steel plates next to the stove. I put a couple of small dabs of caulk on the metal to hold them in place during the pour. Problem, when I went to grind the tops I had to grind down the thickness of the caulk to get them to show. Big mistake and PIA
I smashed red rocks and black rocks and scattered them on the bottom of the mold before I poured, Ground it all down to a high shine. LOVE THEM!!!
http://s273.photobucket.com/albums/jj201/Brian-1-2008/Counter%20tops/
Brian
