OT-Tens Unit?
OT-Tens Unit?
OT-Tens Unit?
Thomas Norton
When I was at the chiropractor the other day he mentioned the idea of getting a Tens Unit.
Have any of you folks used one at home? What are your thoughts?
Re: OT-Tens Unit?
That's just shocking!
Joanne in Point Pleasant
Re: OT-Tens Unit?
Galen Vetterick
I tried wearing the TENS unit for a while after spinal injections and wearing morphine patches. I'm not sure if it did much good. I guess I had it turned up so it gave me a good buzz and in frequent intervals. Don't know about the endorphin theory or pain blocker theory but I did get to where I just thought about the next buzz and maybe not the pain from my pinch spinal chord.
The worst pain is gone and replace by my left leg being numb like it is asleep all the time, but that was not a funtion of the TENS just more restriction on lower spinal chord that controls that side.
The morphine patches did the best job but then you pretty well cannot function or you just don't care!
Surgery if done is high risk of not being able to use my left leg at all and not sure what it would do to internal organs on left that the branch controls as well.
Putting those electrode patches on my lower back by myself was interesting feat.
Good luck with resolving any pain issues.
Re: OT-Tens Unit?
Re: OT-Tens Unit?
Dale Warder
Years ago, after an injury, my chiropractor also recommended a tens unit. I was in extreme pain with a back injury at the time. I went with the tens unit, which provided remarkable relief from the pain. I was able to work with no lost time due to the injury, and recovery was quick with no further problems.In a similar circumstance, I would go with a tens without hesitation.
Good luck,
Dale
Re: OT-Tens Unit?
Some people say they work
When I was going through really bad back spasms about 15 years ago, I researched everything I could find on the subject, including Tens units. I wasn't inclined to be tethered to a piece of gear like that, so I clawed my way back to relatively decent health through exercise, stretching and other measures.
When I was looking for answers, I read a couple books by John Sarno, MD, who treated literally tens of thousands of back sufferers at a prestigious New York hospital in the 80's and 90's. He found that only about 5% of back ailments were actually physical problems and the rest were the result of the body tensing itself up because of anger and anxiety issues, so that's a worthwhile place to look for causes of your problem.
Among other things, I visited one of the top back surgeons in the US at the Texas Back Institute in Plano, TX, just to get an authoritative opinion from the medical profession. He advised against surgery unless it's a case where sciatic pain is unbearable, and then the odds of improvement are only about 50/50. Instead, he recommended massage, myofascial release, aquatic exercises and stretching. That worked for me, but, obviously, I can't tell you whether a Tens unit could be a worthwhile approach for you.
Re: OT-Tens Unit?
Re: OT-Tens Unit?
Nick Tuzzolino
It worked for me when I had a full knee cartilage removal in 1975 and again on the other knee in 1980.
Re: OT-Tens Unit?
Re: OT-Tens Unit?
charlie belden
Sounds like a compressed or herniated lumbar disk pressing on the sciatic nerve that comes out at your hip and down the back of your leg to your big toe. Symptons start with a feeling that you have a kink in your hip. Then you get a tingling in the back of your leg that over time progresses down the back of your calf and then your foot may go numb. If left untreated it can paralyze the leg and cause a great deal of pain along the way.
Twenty five years ago I herniated the disk between L3 & L4 (or it could've been L4 & L5?) - from - ready for this? Sitting - for 10 hours a day, 6 days a week, for almost 6 month ("rush" project). This was before "ergonomic chairs". Turns out sitting is 5 times worse on your back than standing.
After "John Wayning It" for a few months I saw a doctor - who told me I had "sciatica". Prescribed an anti inflammatory and a muscle relaxant and told me to lay down as often as possible. As a single parent of a 6 year old, well into a 6 month "crunch project" at work, if I got 6 hours of sleep a day I was ahead of the game. Laying down during the day wasn't an option.
Things got worse. Went back to the doctor and he sent me to "physical therapy" (read: Sado Masacist Sessions). Before the first "session" I could lift my leg about 25 degrees. By the second session it was maybe 20 degrees. When the third session came around and I could barely lift my leg the "physical therapist" called in the neuro surgeon - who put me in the hospital - in traction "for a few days".
Five weeks later they sent me home in an ambulance - where I spent the next 11 weeks in traction, taking muscle relaxants, anti-inflammatories - and valium. Thank god for having a decent relationship with my Ex - and a lot of great friends and neighbors.
The body is a pretty amazing machine - that's fairly good at self repairing - IF you let it - and help it.
Here's what you're playing with - a segmented crain - made up of blocks stacked on blocks - with flexible donuts between them that act like shock absorbers. The whole thing is held upright by "guy wires" (sp?) - that are all slightly in tension. When the blocks get out of alignment one set of "guy wires" shortens on the "slack side" and the others stretch to compensate for the "curve. When you straighten out the "curve" the "stretched" wires tighten up. But the wires on the other side get stretched, increasing their tension. The result is that the "blocks" get squeezed together more - and squish the "shock absorbers". If they get squished enough, one or more, the weakest ones, get squished enough to start pressing on the spinal chord. That pressure on an area of the spinal chord "bruises" some nerves, in my case the left sciatic nerve. Press hard enough on that nerve, for a long enough period - and it dies below the pressure point.
So the first thing you want to do is take the load OFF the blocks - by going horizontal. That takes gravity off the crain.
Now you've still got the "guy wires" in too much tension. Muscles and tendons and ligaments are still trying to squeeze the blocks together. That's were the muscle relaxants come in. Relax them and the "rubber donuts" stop getting squeezed.
That leaves the bruising. And that's where heat/cool and anti-inflammatories come in. Heat/cool increases/decreases blood circulation and the anti-inflammatory reduces - inflammation.
With the pressure caused by gravity reduced significantly - and the "guy wires" loosened - the blocks will realign and the "shock absorbers" can return to their normal size.
Only then can you start retensioning the "quy wires" to have them hold up the crain - without squeezing the crap out of a "shock absorber" or two.
And THEN - you learn some basic "segmented crain" operation and maintenance lessons.
Lesson # 1
Never bend AND twist.
About half your body weight is above your lumbar "blocks". When you bend over, the muscles, tendons and ligaments on the other side of the bend must tighten up - squeezing the blocks together. Twist and they tighten even more - and torque the "shock absorbers".
So when you have to bend over, use an arm or two to take some of your upper body weight.
When bending and rotating are necessary, like getting out of a car - do one movement and then the other - rotate then bend - or the other way around.
Lesson # 2
No sudden moves.
If something's rolling off of a bench top - DO NOT lunge to stop it!
No jumping off of anything. You fall at 32 feet per second. In one second you're falling at about 20 MPH. Think of what happens to the bumper on your car when you back into a post - at 20 MPH.
Lesson # 3
DON'T SWEAT THE SMALL STUFF
They call it "stress" for a reason. When you're "stressed out" you're adding tension to those "guy wires" mentioned earlier. And that squeezes those "blocks" together - and they smoosh the "shock abosrbers" - that caused the pain earlier.
PAY ATTENTION. If you're neck and shoulders are feeling tight, and/or your jaw is clenching, or you're "furrowing your brow" - you're stressed. Take four or five deep breaths, shake your arms - relax. Then figure out what's stressing you and if you can - stop doing that. If you can't - look for the absurd humor in it and have a laugh or two every so often. Whatever you were doing, it can't be as important as being able to get up and move around - without screaming and hollering in pain.
This can be an opportunity! You have an excuse for laying in bed reading wood turning books and magazines, or laying on the couch watching a woodturning DVD.
"I'm not screwing off. This is THERAPY"!
Re: OT-Tens Unit?
Re: What are your thoughts?
Joseph Mulherin, Sr
Back in January 1965 in Indiana I suffered a ruptured disc while waiting to start work on a const project. Took off my boot to stretch my sock out and then tried to refit the boot and then I had a severe POP in my back. Had to sit and wait until someone came around to go get the nurse at the factory I was working on.
Suffered for four years on and off about every three months with these two ruptured discs. In order to sleep I made a girdle out of sail canvas, tied ropes to it and tied gallon milk jugs to the other end which hung over the end of the bed.
Did this for about three years, then had a doctor take out the discs in 1969. Doctor said I had so much scar tissue he did not see how the message got from my brain to my legs to walk.... but I maintained an employment during those years for my family working const. They did not had those 10 units then either.
Re: OT-Tens Unit?
OT-Tens Unit?
bob oswin
Mine worked for me after physio didn't and the pain killers were spoiling my life.
I don't recommend it as a treatment but it is worth a decent investigation if you have unrelkenting pain from your spine or joints.
I paid about $90.00 for mine which is less than any visit I made for professional counciling.
Re: OT-Tens Unit?
William A. Roland
Re: OT-Tens Unit?
William A. Roland
Mine worked great after neck surgery. I still have it and if you are interested in having it let me know.
Re: OT-Tens Unit?
Re: OT-Tens Unit?
Larry in NW OHIO
I had one years ago when they first came out. I was at my Doctors office when the salesman was there telling the Doctor about it, and introduced us and told him that I would be a great person to try it on, in other words "Ginny Pig". So he gave it to me and showed me how to work it and told me to try it and come back in a week and tell him how it worked. It just happened to be winter and we got a pretty good snowfall that week and I had to shovel the drivway, no fancy snowblowers back then. I put on the tens unit and shoveled out the drive and didn`t have any pain in the area of the tens unit, but I was pretty sore most everywhere else. Yes it work very well for the area it was on. Larry
Re: OT-Tens Unit?
Re: OT-Tens Unit?
Paul Leuba
Charlie, those points are excellent advice for back pain sufferers. I also herniated a lumber disk about 40 years ago while picking up a box that I was unaware was loaded with books. Bending from the waist to pick up a heavy load is a serious mistake.
During the first 30 years, or so, after the incident I suffered pain for several weeks at a time a couple times each year. My job was a sedentary one with me at a desk 5 to 6 days a week. As time went on, due to the nature of my job and the normal ageing process, my back and stomach muscles became weaker, aggravating the back pain condition. A few years ago I read about Pilates, an exercise and stretching program that focuses on the core muscles in the truck of the body. After reading the book, I signed up for a 10 session program at the Community College. After the first session, my back felt looser and more flexible than it had in years. I am now a staunch advocate of Pilates as a means to greatly strengthen back and stomach muscles to help align and support the spine. This take much stress off lumber disks, and I have remained virtually pain free since beginning my Pilates exercise almost 5 years ago. I am able to lift fairly heavy objects without pain now that would have caused me two weeks of back pain previously. Of course, a proper lifting posture is essential, but I believe the additional strength in my stomach and back muscles attributed to Pilates exercises have made the difference in my ability to live an active life without pain, even though that herniated disk is still there.
Pilates exercises really helped me alleviate my back pain suffer, however, it is important to first consult a doctor, and then to begin the exercise program only during a period of low, or no, back pain.
Paul in Hunt Valley, MD
