THE WOODRAT IS BACK!
Good quality jig saws
I don't know if you'll remember but a month ago or so I asked if more expensive jig saws are worth the money. I have an old top of the line Craftsman. It was better than my original Black and Decker by a large step but was still lacking. I assumed they all cut like that. Boy was I wrong.
I picked up a Dewalt DW321 at a yard sale for $15. I can't believe the difference. The speed control trigger is so smooth and easy to control. The cuts are very clean and fast. I can't wait to try it on something thicker. I will have to look up and see what these things sold for but it's one heck of a lot better than my Craftsman.
Re: Good quality jig saws
Two of the things that impress me about professional-grade saber saws are:
1. They can cut thick stuff - the consumer grade saws start looking faint and whimpering past about 1/2" plywood, and
2. They keep the blade closer to vertical throughout the cut.
Far more expensive - new, expect to pay $150 - but SO worth it.
FredD
I think Bosch is about as good as you can get and I also think that Bosch blades are better then any of the competition.
Based on owning and using first a B@D ,when I was poor , then a Delta and then two Bosch , which I will never outlive the last one.
FredD
Moses Yoder
Re: Bosch
Moses Yoder
About 20 years ago my wife's grandmother asked me what I wanted for Christmas. They were very wealthy so I asked for a jigsaw, kind of hoping to get a Bosch, thinking that everyone knew what a good jigsaw was. We used Bosch jig saws at work and they are obviously the best. When I opened the package on Christmas morning she had bought me a Craftsman jig saw. I actually used it sometimes.
I, too, went from a Black & Dreck to a better saw. I chose the PC fixed base HD orbital model that takes both PC and straight blades but not those for the Bosch system. Cuts square and, on the most aggressive orbital setting, will chew through 6/4 hardwood without complaint. With its big fixed base, it's useless for upside-down coping cuts, but as I almost never cope joints, I don't miss that ability.
Jim in Burlington Ont.
Jim in River Oaks, Ont.
Hi,
If I could , I'd go for a Fezzz Tool but for now my old Bosch will have to do..
Take care,
Jim
Ditto on Bosch
Tim Greif - West of Chicago
I've had B&D, then Skil, and finally a barrel grip Bosch. Absolutely no comparison. You won't be disappointed with a Bosch. Some folks prefer the top handle but I really like the barrel grip version.
Re: Ditto thge Ditto
Re: Ditto the Ditto
Howard Norman
The Bosch is a great tool!
Re: Me too!
Doug Trembath
I am building a desk out of a walnut crotch slab, >2" finished thickness, and the same saw cut straight, curves, and perpendicular as easily as my bandsaw would. Great saw...
Doug Trembath
ebd
ebd
IMHO the Bosch is better than the Fezzzzzzzzzzzzzzzzzzzzz
I had one of those; great tool
I moved to a Bosch mainly because I occasionally needed to be able to tilt the blade in my remodeling work, but the P-C was my first pro-grade jigsaw, and the one that convinced me there was a difference. One of the first times I used it, I was cutting some 3/4" plywood, and cut right through the end of the 2x4 on which the ply was resting - without realizing I'd added 1-1/2" of wood to the cut.
I have a later model Bosch top handle, and an ancient Bosch barrel grip that I occasionally use when working overhead, where the barrel grip is a lot easier; both from garage sales. If I were buying retail, no question I'd buy a barrel grip. I do have fairly large hands, though; not everyone can wrap a hand properly around these.
I just gave the P-C away to a young woman who's learning how to do woodworking. It's still in great shape, and I hope it will serve her as well as it did me.
Re: Me too!
Larry in NW OHIO
I have a Makita 4324, whatever that # means. I got it at Sears scratch and dent for $20. The only thing it had with it was the allen wrench to change the blades, but well worth it. I had a sears, skil, B&D before all the cheap ones. Of course they can`t come close to the Makita of course. Larry
One more vote for Bosch
Lee Schierer McKean, PA
I had a B&D for years and it struggled in many ways. It finally died and I purchased a Bosch based on the good reviews of owners here and on other forums. What a difference. I can get TS quality cuts with their progressor blades and it breezes through hard woods. It is a joy to use.
Lee
Fezz Makes Great Head Gear
Bosch babe here
Joanne in Point Pleasant, PA
