Re: OT Cell Phone and Europe
Jesper, Denmark
You need a tri-band GSM telephone. USA uses 1900 Mhz and in Europe 900 or 1800.
As far as I know, only ATT in USA uses GSM, but when I lived there, my ATT phone with international activated worked fine in Europe, but not in Japan.
You have to be a little careful and select manual choice of operator, as otherwise, the phone will select the best signal and switch between different operators, costing you extra roaming charges. You then have to select an operator each time you cross a border.
Coverage is universally very good, including 3G networks and some 4G networks active in the larger cities and along major highways. Cell phone coverage is also usually available in most trains on major routes.
Emergency calls are 112 in most of Europe, but 999 in the UK. The US 911 also works some places, such as here in Denmark.
Wireless LAN is usually available in most hotels, free in the less expensive ones and at extra cost in the high priced ones - go figure! Broadband is normal, nobody has dial up anymore.
