We value your privacy.
Yesterday marked my 47th year since getting on an airplane in Saigon on 4 July 1963 to come home. The 4th always has special meaning.
Today I have a different consideration. My relatively new Jet Hybrid table saw has awful dust collection. There is a 4" port molded in to the detachable plastic real panelat the rear of the saw. Trunions and motor block much of the area within the cabinet and sawdust builds and bridges around these obstructions, thwarting all dust collection. I have to clean it all out by removing the rear panel and inserting a vacuum. Also vacuum through the table top after removing the blade. Its a real PITA.
My previous saw was a Jet contractor saw. Its dust port opened downward from the bottom of the saw. Gravity worked with the DC system to provide a moderate degree of evacuation. Moderate, but not very good overall.
I am thinking of taking my hand held 4 1/2" grinder and cutting a hole in the bottom of my current saw's cabinet to mimic the system found in my previous saw. These is room for a DC hose connection, however, the arrangement will be cumbersome to manage with arthritis.
And better ideas/advice/comments would help, especially from owners of similar saws. Thanks.
I have not seen any hybrid saw let alone yours. So I can't give you specific advice.
Does the build up of sawdust inside your saw interfere with using the saw?
I have a Contractors saw and I built a chute that comes up around the blade and captures most of what goes below the table. It was tedious to do and a real head scratcher. I built two or three out of card board and two out of steel before I got it "right". I say "right" because I am still a little suspicious I could have gotten it better, but I have actually tested it and it gets the vast majority of what goes below the table. One of the the things I wanted was to bring the chute out of the front, because I use the Long Ranger gates that turn the DC on when I open the gate. It might be better at collecting the dust if it went out the rear, but that is not what I wanted. My saw has an open stand and the motor hangs out the rear.
If I had a cabinet saw, I think I would put a sloping floor in the bottom of the saw with a dust port at the bottom of the slope. I might curl the sides of that up so that it sloped toward the dust port from the side also Or I might just let the sawdust find its own angle of repose and sculpt itself, as long as it did not interfere with the operation of the saw.
I looked at doing this with my saw but found that because the cabinet was so "open" that the dust collection would not be effective. Not only was the back of the cabinet on mine completely open to allow for the motor to hang out there and pivot, it had slots on the sides and the cabinet was not sealed to the table. The ribs on the bottom foot table created large openings.
Keep in mind that you need lots of high speed suction to capture the particles. You want to put the port and chute in such a way that the blade flings the particle right at the port. In spite of that, there will be many particles that try to escape and fly in every direction. So, you want the incoming air to turn them around and drag them to the port. But, You need as much "goes into and you have goes out". So you want to seal up as many leaks as you need to to keep the air velocity high through the cabinet.
I need over the blade collection on my saw, but my shop is so small, I don't want another hose or pipe in my way. I do see a huge difference in the saw with and without the DC. If I forget to turn it on, at least twice as much dust comes all the way around and comes of the top of the blade. I have been thinking about using my air compressor to blow across the blade to knock the dust out of the gullets. But, then, I am nuts.
I suspect it was the 4th of July for all of us leaving SEA, on our way home, no matter what month it actually was� I can still remember the thump of the wheels coming up, the smile on my face, and the utter relief flowing through my body.
Chuck Lenz designed a vacuum attachment for his Delta contractor's saw that was innovative enough to be carried by Penn State Industries. Neither Chuck's page nor the Penn State page seem to be active. I've searched WC for the thread in which he describes how he designed it and I can't seem to find either Chuck or the hood. I'll keep looking.
Thankyou Bruce, I e:mailed George a couple hours ago. Here is the link to my first design, which is posted in this site at ShopShots. PSI no longer sells my latest design, but if George would like, he could use one of my existing dimension hoods that fits a 12" X 12" opening, or I could resize the hood for a custom fit to his saw.
I'm not sure what comments you were expecting. Your photobucket picture doesn't exist anymore for some reason so I removed the dead link from your post. The shop shot is very clear and thorough. Nice job.
Your dust hood is perfect for a contractor's saw, which has an open bottom in the cabinet. A hybrid saw doesn't have an open bottom, so George would have to cut out the floor of his saw cabinet in order to install your hood on his saw. That said, it's clear that the dust port on the Jet hybrid isn't getting the job done for George. I don't know if that means it is poorly designed or situated, or if George's dust collection isn't pulling enough air or what. Some kind of modification seems to be necessary, but I wouldn't be able to speculate on it unless I had a closer look at the problem.
Anyhow, you shouldn't take it personally if you don't get a reply to every post. Happens to the best of us.
If I cut out the bottom of the saw cabinet, it may weaken it significantly. Its sheet steel. Maybe I can make a smaller opening, retain structural strength, and still accommodate a ducted DC port. I have to crawl under the saw and measure, but am not ready for gymnastics today. Maybe I can get #3 son down there. I trust his judgment.
I'm more than a little late to this party (been on vacation), but I'm surprised that nobody mentioned the article in Fine Working from June 2009. The main focus was on contractor's saws, but they did a nice sidebar on the Jet Hybrid and a General Cabinet saw. The results looked good, and no hacking of the original sheet metal was needed. It might be worth a look-see.
