OT--Walk-behind mower WITH a throttle
Henry Higginbotham
Are these available anywhere? My 15-year-old, simple, 20" mower is really showing its age lately. I'd replace it if I could find one, but no luck so far. I'm aware that most, if not all, manufacturers have abandoned functionality in favor of cheap EPA compliance.
My front yard (north side, with trees) grows more rocks and sticks than grass, and in many areas it needs a slow-turning, very sharp blade.
Alternatively, are there walk-behinds (preferably not self-propelled) that could be modified by someone fairly adept at tinkering but lacking an advanced degree in lawnmowerology?
Re: OT--Walk-behind mower WITH a throttle
Jim Rahbe, Bedford Texas
All My Hondas Have Throttles???
Henry,
As much as I like to blame big government, and conspiracy theories, I don�t think the EPA has anything to do with your problem. In fact, I�m not sure what the problem is. I�ve bought three lawn mowers in the last two years (not all for me) and they all had throttles that would adjust the speed from off, to idle, to full on. Maybe the older mowers had a wider range, but I suspect that most people run their mowers full on 99.9% of the time and manufacturers just made them to run that way.
What is it that your current mower does, that the newer ones will not do?
Jim R.
Lee Brubaker
Yeah.....it's called a scyith...most rural hardwares have them along with a sharpening stone.
Lee
Re: All My Hondas Have Throttles???
Henry Higginbotham
Jim,
I wasn't blaming the EPA, but rather the manufacturers for taking the cheapo route. There are EPA regulations that apply to lawn mowers (see the EPA's web site), although I couldn't tell you what they say, exactly. My local Husqvarna dealer and small engine repairman told me that was why he couldn't sell me a mower with a throttle.
Why I need a throttle: As I said, my front yard is mostly stuff other than grass, and a mower running wide open kicks up lots of dust and throws out lots of small stones and sticks. For the most part, this doesn't happen with the mower running slowly, and with a sharp blade the grass (what little there is) still gets cut. And I burn less gasoline.
I'll check out the Hondas, although I suspect they're self-propelled and thus slower to maneuver. I may yet have to succumb to "progress," but I'm not giving up just yet. Thanks.
Henry Higginbotham
Got one. Three, actually. I suspect they'd get throttled down completely before the yard was even started good, much less done. :D
Stuart Hough
Henry,
Almost all walk-behind mowers sold today have automatic throttles so they can keep the engine running at or near the speed that makes good power and keeps emissions low. This also helps to keep the db level down, too, as most are set to run at approx three fourths of max engine revs. If you can find and disconnect the auto-throttle, you might be able to attach an aftermarket throttle cable so you can adjust the engine speed to suit your needs. I am not suggesting that you do this, as I would never condone anything that sidesteps the EPA or the Federal Governments mandates :D , only supplying readily available info on altenatives. On most of the high-end mowers I have looked at recently, they have the throttle tied to the speed control for the self-propelling gearbox, not really for the engine. Good luck!
David Weaver
I think you're best off finding the cheapest and lightest used mower on craigslist. I have one of the honda self propelled, and I used to live in an area where we had what you describe. The hondas aren't that nimble for quick work as is something like an old lawn boy with no self propelled, and they're a lot heavier.
We had a steep bank we had to mow, probably 15 feet high and more than 45 degrees. There's no way we could've mowed it with the honda. For a while, we were tying a rope to the handle of the lawn boy and letting it go down the hill and then pulling it back up. The bank was at the edge of the road, and I don't think the motorists thought too much of that.
Even the oldest lawn boy we had had a two-setting throttle - like half and full speed. The half was perfect for most stuff we did.
I'll bet there's 30 pounds of difference between that old mower and my honda now, but I have a flat yard now that needs to be push mowed and it's heavy grass.
Larry in NW OHIO
Henry I don`t know how much I can be, but I`ll tell you what I have that sounds about what you want. I have older Toro`s, about 15 plus years old. They are the BBC, Blade-Brake-Clutch, type. You can control the drive, and blade speed with a lever. I have about 8 of them, I really like them. I go to dealers and buy the older ones they don`t want any more and costs to much for them to fix. I usually pay $25 for them. I get all the same ones with interchangable parts, that way I can build up one for mowing. I think it is a very good mower, it may be for you. Good Luck. Larry
