We value your privacy.
First, I never boil my meat and neither do the pros - extracts all the flavor. The ONLY WAY to get decent ribs is to cook them on a low heat, slowly.
I do the following:
1) The day before I'm gonna cook, I remove the membrane from the ribs, rinse them, pat them dry with a paper towel and apply a dry rub (send me mail if you want my rub recipe) and then wrap them in plastic wrap and let sit/marinate in the fridge overnight.
2) Next day, I remove the ribs from the fridge, remove them from the plastic wrap and place meaty side up in my oven/grill/smoker and cook at 220 degrees for six hours. I DO use a smoker and smoke them with Apple wood for 3 of the 6 hours, but even if I didn't have a smoker, the cooking temp and time would not change.
3) After the ribs have cooked for 6 hours, you can then apply a sauce of your choice and broil them under a high heat (broiler or on your grill) for approx 5 minutes. This is to glaze the sauce onto the ribs.
>My wife covers them with barbecue sauce and bakes them. If it were me I wouldn't even bother cooking them. Right in the trash. So much trouble for so little meat that is greasy, messy and doesn't taste all that good. Gimme a nice filet of fish anyday.
>I use a regular oven. I usually cook 3 racks of baby back ribs at a time. First, remove that membrane of the back. The easiest way I have found is to get it started at the narrow end with a dull knife, and then grab it with a paper towel and rip it off in one strip. I then heavily coat them in 3-5lbs of rub, I think that's more rub than most use. The rub is mostly brown sugar, with a few spices. I throw them on a cookie sheet and cook them for 3 hours at 200-220 degrees. I then take them out, drain the fat, and spray them with a non-stick cooking spray, and then back in the oven for another 2-3 hours. I look for the bones to start sticking out of the ribs, it really depends on how tender you like them. I like it when they will just stay on the bone without sliding off... (getting hungry here) Then I take some cattlemans or equivalent bbq sauce, mix it about 50/50 with some more of the rub, and smear that all over the ribs. Then back in the oven at 375 for 15 minutes to bake the glaze on.
Done, the resulting meat candy is heavenly, but I think even better then next morning cold right out of the fridge.
A friend of mine owns a BBQ catering business down here in Texas, and that's where I learned to cook them. If you are interested, I can point you to a web site where he sells his rub and bbq sauce.
>1. Dry rub, using a very simple rub of salt, black pepper and cayenne.
2. Cook with slow, indirect heat. The best heat is generated by a mixture of charcoal and a good hardwood. Hickory is a standard, but mesquite, maple and apple are very good. Both the charcoal and wood should be well-started outside your grill, then added over time. This keeps the smoke from being oppressive. Don't let the fire get too hot. Slow roll 'em for 4-6 hours. If your grill is too small for full slabs, divide them as needed, but keep the pieces as large as possible while cooking.
3. Keep the cover on, with just a little smoke leaking out, as much as possible. If your grill has no cover, throw it away and get a real grill. If your grill uses gas, throw it away and get a real grill. (Take note of South Carolina's "Truth in Barbeque" law, requiring commercial barbeque joints to use wood if they use the term "barbeque")
4. You'll need copious libation during this delightful process. At least some of it should be beer. Foofoo drinks, like G&T, Tom Collins, etc. are frowned on by tasteful practitioners.
>I like the following for super tender, fall off the bone ribs. I don't care for the smell of bell peppers while cooking but I put it in the maranate.
2 Bell Peppers (Red and Green)
1 Sweet (Vadalia) Onion
1 or 2 Slab Ribs
Lawrey's Seasoning Salt
Julienne the peppers (long thin strips)
Slice onion into thin whole slices
Remove rib membrane. Easiest way is to just grab the membrane at the end with a dry paper towel and pull off. Separate full slab ribs into half slabs.
Use a good amount of Lawreys as a dry rub onto both sides of ribs rub into the meat.
Take a large oven pan and cover bottom with sliced onions.
Lay ribs on the onions
Lay pepper strips on top of ribs.
Cover tightly with aluminum foil and put in refrigerator overnight to marinate.
Remove from fridge and cook in oven (still covered with foil) at 275 for 6 hours. I remove the peppers first but you can try it with cooking them too. About 30 minutes before done, put some BBQ sauce on if you like. They are REALLY tender this way.
>Take the membrane off of the back, otherwise they are tough and will curl. I do not use BBQ sauce but I do heat it up for my guests. I only use salt and pepper. I used to grill or smoke the ribs laying flat. I now use rib holders(racks), I think they provide a better heat flow and also allow for the smoke to penetrate easier. I do the ribs in my oven and the grill, both gas and charcoal. Best of luck, Dave
>I remove the membrane first, then cut the slabs in half and pat them down with my rib rub du jour, wrap them in saran wrap and let 'em sit for several hours to a day. There are many rub recipes. The standard contains kosher salt, pepper, cumin, brown sugar and paprika. Variations might have five spice powder (yum), dried herbs, smoked paprika (I like both the sweet and hot versions), and other specific flavors you might want to have.
Prepare the grill as follows: Use coal separators to keep the coals off to the two sides of the grill bed. Put a heavy-duty tin foil tray in the center with a quart of water in it. Light up a chimney full of coals and dump equal amounts into the two coal compartments, and let them burn for half an hour for the initial heat to subside a little. As mentioned, this should be a slow cooking process. Stand the rib sections on edge in a rib rack in the center of the grill, cover and go away for a couple hours with the intake air shut way down and the exhaust port half open. Put a few new coals on each bed every half hour or so. I also put short sections of green apple limb on the coals every now and then.
To keep the ribs moist as they cook, I baste them with a mop made with the mop du jour recipe. It's just basically a very thin sauce made with water, vinegar, something sweet (maple sugar and agave nectar are faves of mine) and other condiments. (Google for mop recipes.)
>a colored fellow which may or may not know how to do them best But if you have boiled a frount sholder or rib's in a big pot and seen what comes off Old gray slime that didn't look all that good But it is not in the meat anymore I have done this also The barbaque meat that he does is hard to beat Of course it is just my way of doing Everybody has their own way that's what make's every event worth going to and finding out the hidden secret's if you can
>This method and recipe work wonderfully and produce ribs that match any I've had in any rib joint. Best of all there is no special equipment required and heroic extremes are not needed for cleanup.
>And far away on the banks of the Salt River (outside Phoenix). A leg of lamb, larded with garlic, sage, and bay, then spit-roasted over an open mesquite fire. Coupled with mickeies, Depression Salad, and ice cold beer. After a day of tubing the river, nothing could match.
