splitters what kind do you use and why?
mike from american sycamore
>I need your help. I am doing some research and writing an article about table saw safety and would like some input on what guards, if any, and what splitters you are using?
thanks,
Mike
Re: splitters what kind do you use and why?
>I have a Unisaw. I use a Beisemeyer pop-in splitter. It's well made and I like the ease of removing and putting back in. Tom
Same here
Dan Donaldson
Alan Young
Screwdriver on the back side.
Alan Young
>Just kidding-Really!
Truth is I don't use anything. I don't have a blade guard or a splitter and I doubt I am alone. I have a 1973 Delta Unisaw and a Biesemeyer Fence. I use feather boards on virtually all my rips. I have considered an after market riving knife but just haven't pursued it.
Alan
>I'll be interested in watching this. I have old powermatic contractor saw and removed the splitter almost immediately because it didn't work and got in the way. I've used it that way for the last 12 or so years. I'm now interested in getting one. I've never had problems except with wood that is reaction wood and wants to close up around the blade. I keep a small wedge that I simply stick in the wood beyond the blade to solve this problem. Not the safest method obviously but it's worked for all these years. I actually started doing this 25 years ago when I had the shopsmith. I would like to look at the new splitters so I'll keep my eye on this thread.
Jesse Cloud
>I'm with Tom and Don. The pop in Biese splitter works well. I also have an overarm excalibur guard with dust control. It isn't as awkward as the original equipment guards, but it doesn't help much with the dust.
At school, the saws have riving knives - much better solution than a splitter.
Excalibur Merlin, but...
Don in Northern Arizona
>I am saving to replace my Delta Contractors saw with a saw that has a riving knife. No one purchasing a new saw now should consider one that doesn't have a riving knife if they can afford it. I took the Merlin off my saw for a while because it became bent and was no longer centered on the blade which is a typical condition for splitters. While it was off I managed to fire a small piece of lumber that I was cutting through the back window of the shop and 20 feet into the back yard. Missed me, fortunately.
Don
Neal in San Jose
>Sawstop with factory supplied splitter 99.9 of the time. Don't use the factory guard much, as I added an Excaliber overarm guard.
Jerry Nicholson
>The guard with splitter and pawls that came with my 1964 Craftsman works fine for me and is very easy to remove when necessary. I haven't always used it but I am older and a much bigger "fraidy-cat" now.
Jerry
Modified Delta
>Removable "splitter" on my JET cab that fits under the Excalibur overarm guard. Had to put a slight "S" in the splitter blade for alignment, but it does ok; haven't launched anything.
yet
I also pay close attention to keeping my fence set properly, and I watch the wood being cut for movement of the kerf. I've been known to kick off the table saw in the middle of a cut and take the whole deal over to the band saw for a "safety rip" if I didn't like what I was seeing.
Robert R. Clough - Thorncraft
>I have the original splitter on my '96 Delta Contr. However, it has been cut down and remade, but I think I shall re-do it again as it is still the original height - too tall. I doubt I need more than an inch in height. My blade guard is one I made complete with vacuum pickup. I replaced the original fence with a decent Delta fence.
Randy Johnson Connersville IN
>The same in a Jet 3HP Exacta saw. I also have an Excaliber overarm guard.
Although the Biesmeyer is great as far as being able to remove it and put it back in as the situation dictates, it does have one drawback. You are limited in the variety of blades you can use, with about 90% of the ones available being too thin. Other than that I have no complaints. It will be interesting to see if the price drops any now that most of the newer saws are addressing the guard/splitter problem that was always pretty much universal.
Dave Bair, Eaton Rapids, MI
>I use a splitter that is simply a washer the same thickness as my blade, set and glued into the insert of my Jet contractor. I have a number of inserts, depending on the types of cuts I make. I use no blade guard; the stock guard and splitter were way too cumbersome to remove and reattach.
Rich in Mn
>I have a Bosch contractor saw and use the splitter and guard that came with it.
Pete in Holland, MI
>Jet Contractor's saw. Original cheezey blade guard system was never mounted to the machine. Have many miles of wood thru the saw and rarely had problems with any kick back.
Keep a good firm grip on the piece of wood being pushed thru & make sure the rip fence is parallel or slightly spreading as you pass the blade. Yes, there have been some boards that want to try to heal as you cut. Either keep firmly pushing them thru, or have an assistant push a wood wedge into the kerf a couple feet beyond the saw table.
Is a riving knife a good idea? Sure. If I had a saw that one could be mounted and follow the blade, I'd have one. I do like the idea of table inserts with washers used as a riving knife, only that the inserts cannot be fastened into the top, allowing for it to tip past the available insert tabs in the table top opening. Thus, they may cause more problems.
Pete
Larry in NW Ohio
>I have a delta unisaw about 6 years old and use the original splitter, but redone. I also put a dust pickup on top that is fastened into the ceiling. I can raise the top guard/dust pickup at any time and remove the splitter. Of course I like my setup, because I made it{:-))))But really it does work very well and pretty much sucks all the dust up, and the best thing it keeps my clumsy fingers out of the saw blade. I got the basic setup from an article posted on WC of course.Larry
Tony - Memphis
>I was using a shopmade splitter on my old saw (Delta CS). I made an insert out of baltic birch and inserted a splitter made of masonite with a beveled leading edge.
The new saw (PM2000) has a riving knife - love it!
I have always used them because I learned to when I was starting out in woodworking. I have had stock get stuck between the splitter and the fence, so I am a believer. So, initially, I believed what I read and later I proved it was true!
Tony
Bart Goldberg
Bart Goldberg
Shop made splitter
Bill Earl
>I use a shop-made splitter attached to the Unisaw guard bracket. It is made from a piece of 0.100" steel.
For most ripping, a power-feeder doubles as a guard. (I don't do much cross-cutting on the tablesaw)
Jim Dillon
>Mike,
I have a General 350 10-inch cabinet saw and use the removable Biesemeyer splitter designed for that saw, and the Brett-Guard saw blade guard - the model that fastens to the side of the saw (not the overhead model). They have worked well for 12 years.
Jim
mdclor
>I use the SharkGuard splitter with 4" dust collection on my PM 66. I like the additional safety offered by the splitter and really enjoy the dust collection. I think it gets about 90% of the dust generated. I never used the OEM splitter/guard because it was too difficult to put on or remove with an out feed table attached to the saw.
Ed Mulligan
>I think the safest way to rip wood on a table saw is to use a bandsaw instead. I do all my rough ripping on the bandsaw. If a piece of wood is misbehaving (kerf opening or closing) it's not a problem.
My Dewalt hybrid table saw came with a blade guard and splitter. I tried to use them but they are just too cumbersome. So, no splitter or guard. I do use a push stick for almost all table saw rip cuts.
Bob Lemon , Sacramento CA.
>I have a European slider saw (SCMI) with riving knife and a very large overhead guard. I've also retrofitted a Felder/Hammer guard onto the riving knife. This works great. I also have a Ridgid contractors saw, that usually does not have the guard on. When I need a guard I use the big saw.
Even with the riving knife, one can get in trouble if you don't use a good PUSH SHOE!
Shark Splitter
Robby Wright
>I had the Biesemeyer splitter, but I didn't like the anti-kickback pawls and associated hardware. I replaced the blade with the splitters from the gent that makes the Shark Guard. They are available in several thicknesses and work great. I have the convenience of the Biesemeyer holder and the fit of the Shark splitters. I don't use the Shark guard.
Robby Wright
thanks!Re: splitters what kind do you use and why?
>WOW!!!!thank-you everyone for such great information and tremendous response! thanks for taking the time I truly appreciate your effort.
thank-you,
Mike
