Working With Walnut
Working With Walnut
Working With Walnut
Tom Rex
>I've built quite a bit of furniture but it�s mostly with read oak.
My daughter has asked for a hall table made from walnut.
My questions are
1. How hard is walnut to work with? Sawing? Routing? Etc?
2. When I pick out my lumber what should I be looking for?
3. Are there different types of walnut?
Thanks,
Tom
Re: Working With Walnut
paul in AZ------WebKitFormBoundary+isMX5X2paiDYC5e
>1. wonderful wood to work with. A premium furniture wood. Way nicer than oak.
2. I've only worked with domestic walnut and look for minimal to no sapwood first. From there it is your choice for grain aesthetics.
Kelly Anderson
>I agree Walnut is very nice. I prefer air dried, I think that it has nicer color.
Fred Davis
>1. Walnut is a dream to machine , sand and finish.
2. FAS
3. Juglan Nigra , better known as Black Walnut is the wood commonly associated with Walnut furniture, though several other lesser ones , including ButterNut are used.
My personal opinion is that Black Walnut looks best with a clear finish, no stain.
FredD
Alexander Grigoriev
>Don't breath walnut dust, it's causing allergies. For me, it caused a persistent phantom smell for a week.
Brent Smith in Montreal
>Easy to work with machines or hand tools. If you can, pick through the pile at the dealer for grain.....you'll find everything from straight grained to some boards that are almost psychodelic. For doors or panels I think walnut burl or book matched pieces can't be beat. I find air dried easier to work and usually a deeper color. Try to stay away from anything that's been steamed to darken the sap wood,IMO it takes away the vitality of the color of the whole board.
Thank you all for the advice
Tom Rex in TX
jcousins
>besides black walnut there is also claro walnut - which i think is a bit more subtle - just as nice to work.
my only caution about walnut is to beware of figure. some walnut is so highly figured and beautiful that it can become overwhelming on a piece - like "too many roses on the birthday cake." but used to accentuate the piece and its lines it can't be beat.
my .02
jerry
Re: Amen on the Claro...
Glenn Madsen near San Francisco
>But Claro is a California specialty wood, and in Texas, you'd likely hav eto go looking for it. We like it for the spectacular grain patterns, but a little often goes a long way. That's good, because the logs are seldom long. Most orchard stock is grafted and grown for shorter trunks.
Designed well, you should be able to make some nice pieces for your daughter.
Larry in NW Ohio
>Tom I like to work with it, and you may want to go to www.gobywalnut.com to look at soom. Good luck with your project. Larry
Brian in Brighton
>I love American Black walnut, or usually known as walnut. You can also hunt around on woodfinder to find a spectacular piece of crotchwood or burl for the top that will really showcase the piece.
Brian in Brighton
Robin Corell in Atascadero CA
>Next to mahagany walnut may be the most perfect wood to work with. It saws, routs turns and carves beautifuly. It can be steam beant, it is a tone wood, and it glues well with any type of glue. while it will take any finish I prefer a coat of oil to pop the grain and then follow that with several coats of water based poly acrylic for the shine and the durability.
When picking out the wood look for air dried as it will have better color. Kiln drying walnut can muddy the the color and lower it value.
There are about 20 diferent types of walnut indiginous to the US as well as a few from other countries as wide spread as english(juglans regia- actually native to persia) and peru(the latin name escapes me). I think claro(juglans hindsii) holds its color better than american(juglans nigra) If you are in texas you can sometimes find texas walnut(juglans microcarpa) from small sawyers.
