Trademark granted
Trademark granted
Trademark granted
Today I received my first US trademark, for Woodfinder. Make that Woodfinder�. I was put on the Supplemental Register two years ago, but finally made the Principal Register in January. It only took about nine years and a fair chunk of change, lawyer fees, etc., but it's a good feeling when you get the payoff.
I hope you will all continue to use Woodfinder� as a resource. Without it, WoodCentral wouldn't exist. Hmm, I wonder if I could trademark WoodCentral? Nah.
Happy day,
Re: Trademark granted
Tom Pilsbury (Chicago)
>Cool! Now you have to make a real nice frame for it.
WAY cool !
steve mackay
Congrats Ellis!
Stuart Hough
Congrats Ellis
Larry in NW Ohio
Re: Congrats Ellis
Chuck in ND
Alan in Little Washington (NC)
>Dealing with the USPTO is not an easy nor inexpensive venture. I read somewhere that the Patent office is one of the few if not the only office in the government that is self-supporting. It can cost $1000 dollars or more in fees alone to file a patent, and that doesn't include the $5000 - $20,000 or more you might spend on a patent attorney for a search and to prepare you application!! If a patent is not granted, there are no refunds!
Cool beans! Congrats!
Joanne in Pt. Pleasant, PA
Jim Shaver - Oakville, Ont
>Cool, Can I get it on a T shirt now?
Jim
Del Williams
>Great news and well deserved.
Kneale Brownson..Awaiting return to CO snows
>Now we all need to know how to add the trademark sign to stuff.
Glad you got it.
Re: Inserting Trademark symbols
Carol - 1 week to graduation!
>In a typical document the keystrokes are:
For the "R" in the circle, Ctl+Alt+R.
For the "TM" in superscript, Ctl+Alt+T.
But in this text editor, they don't work.
However, the ASCII works, so...
For the "R" in the circle, ALT +0174 �
For the "TM in superscript. ALT +0153 �
Source of information is the "Insert" command in MSWord.
HTH.
If posting and need
Dan Donaldson
>If you are doing something that uses html, you can use the html entity ® to get the r in a circle. So, for example, in your post, you would write Woodfinder as "Woodfinder®" and it would be expressed as Woodfinder®
Hint, if you use any entities, do not do a preview or it will mess them up.
Re: If posting and need
Don Evans
>Like this test?
Woodfinder®
Lesson learned long ago…
Rod Peterson -- Ormond Beach
>…courtesy of my good friend, Dave Arbuckle:
It's okay to do a Preview Message, but don't Post Message from that screen, always hit the back button and post from the edit screen. Something about the software does a conversion of all the entities to the actual character when you hit Preview Message. Posting from that screen gives mixed results (including making most of your hard work with entities disappear). If you back up to the edit screen where your entities appear intact, then hit Post Message, the entities will be rendered properly.
This "feature" came to light a few years ago when I had posted a tutorial highlighting lots of HTML, which looked great in preview but had disappeared when posting from that screen. How he had learned it, I don't know, but Dave came to the rescue and taught me the proper technique. I use lots of HTML in my posts—both entities and actual HTML commands, and I've learned to never post without verifying (with Preview Message) that I've closed all commands and that I coded what I intended to code. Then I "back button" to the final edit and Post Message from there.
Dan has rightly pointed out in previous posts to use caution with HTML code and entities to ensure that everything is properly closed out. Failure to do so can cause rendering problems with subsequent entries. If in doubt about your HTML prowess, don't exercise it.
Rod
yup ;-)
Dan Donaldson
Craig Frasa
>Congratulations Ellis!
Bill White
>I may have been sleeping, but what will Woodfinder do? Is it a procurement medium?
Bill
It's a locator *LINK*
>... for any species or specialty you're looking for. We've been going strong since 1999 and are still serving up more referrals every year.
http://www.woodfinder.com
BarbS
Wow..Big News! Congratulations
BarbS
Outstanding !
Don Orr
>Congratulations Ellis. Strong work, keep it up.
Excellent Ellis
HC Sakman --- Victoria,BC. CANADA
>"Woodfinder" is sure a catchy name. CONGRADULATIONS! Well done Ellis.
Chico...
