Powermatic 1800 Bandsaw Review
>I recently had the opportunity to use some business income to address some tool needs in the shop. I had a Laguna 16 HD Bandsaw and while it was adequate most of the time I do, from time to time, have needs of a bandsaw with greater capacity. I wish I had a dollar for every time I needed to resaw a board that was 12 1/2" wide. (The Laguna capacity was 12").
I then came to learn of a brand new bandsaw, just released by Powermatic. The PM 1800 bandsaw was just released a few months ago. It is the first of a brand new line of bandsaws that PM is creating. These new saws are serious machines that have been re-designed top to bottom to address the shortcomings of other machines. And from what I have experienced, they have a winning design.
The PM 1800 Bandsaw is an 18" saw. However, it also has an 18" resaw capacity. It is a large machine and weighs over 800 lbs. It is very robustly built. Everything is beefy on this machine.
The riser is very rugged and the euro guides are very sophisticated in how they adjust. There is a nice height gauge for the riser adjustment wheel. Perhaps one of the coolest features is that big arm and handle. By simply turning it one way or another you can put the blade into tension, into relax or into loose for blade change. Whe you wish to use the machine again just turn the handle and you can place your blade back into whatever tension you want it to be. (very nice) With a different wheel you can dial in whatever tension you wish for any given blade. There is an indicator for tension measurement.
The table is really nicely made. Large, ground smooth and flat. The fence is really huge and is attached to a rectangular tube rail....essentially like a table saw fence system...along with a measurement guide. It glides and locks beautifully. There is a large resaw bar guide that is an optional attachment included with the saw.
Below the table is a beefy trunion system. Unlock the trunion and the wheel allows you to crank the table to your desired angle...again, very cool. There is a foot brake, and 2 dust ports. There is a lighted switch with a huge stop button that's easy to see and hit for safety.
The wheels are computer balanced and huge. The machine has a 5hp motor. Advice...make sure you have a 40 or 50 amp circuit. This baby draws some power when it starts up. But it purs like a kitten when its at speed.
Ok, I'm pretty smitten with this new machine. I've done my best to remove the rose colored glasses and yet I still believe that Powermatic has done a fantastic job with this new saw design. I really haven't found a single thing to fuss about. And near as I can tell, this is my last bandsaw purchase. Admittedly, it's perhaps an overkill machine for most shops. But for those who seek a first class bandsaw with lots of capacity and power I would highly recommend the PM 1800.
Tom
Re: Powermatic 1800 Bandsaw Review
Wow
>Good Afternoon Tommy,
That surely is a magnificent tool. I wish one was on my horizon. Good luck with it. Just out of curiosity, what is the widest band you can run with it?
George
Specifications *LINK*
>Good afternoon Colonel,
The saw takes 160" blades from 1/16" wide to 1 1/2" wide. And for those who are interested in the specs....here is a link:
Powermatic PM 1800 Bandsaw
Fred Davis
>If I was were in the market for a new bandsaw , that would be it hands down, I have read some of the pre release notes on it and it is typical PM machinery, done with a thought or two about the user.
Those ground tops like their table saws are a cut above the average.
Lucky you Thomas ;-))
FredD
>I drooled over those at the IWF. I was with a friend who was buying a big bandsaw and we looked at that machine but he decided it was just a little to steep for his budget. I thought it was the best machine we looked at and we looked at them all.
Robin Corell in Atascadero CA
>a beautiful machine for sure. I particularly like the look of the geared trunions, nice touch. I don't understand why they would design such a top of the line industrial quality tool and then not make it direct drive. You mentioned a whole new line up of PM saws, is there a direct drive model in the line up?
So how much do these puppies cost? A media cabnet?
Larry in NW Ohio
>Thomas What a beautiful saw, almost as beautiful as some of the furniture you turn out of your shop. I`m sure this saw will make things even prettier. I also have a tool gloat, I`m a little reluctant to mention it here, I don`t want to make your little tool look bad,but may never get the chance again. I am getting a, are you ready for it, I`m getting a NEW PORTER CABLE 392 Random orbit sander. Take that Tom. Larry
Hey Larry.....
>Thanks for the kind words. But as far as tools go, big or small any new tool is worth a gloat! Enjoy
Tom
>Oddly enough I haven't seen the other new bandsaws that PM has on the horizon. My guess is that they are larger ones. As far as direct drive...haven't heard about that either.
And yes....in fact that saw did cost about one media center. ;-) Good memory my friend!
T.
