Air Router recommendations?
Brian in Brighton
>I have a customer that is looking for a machine using an air driven router for fiberglass. Anyone have any recommendations, good or bad?
Brian in Brighton
Re: Air Router recommendations?
What's the "machine" supposed to do?
>If it's a compressor, it better be a big one.
Clint
Phil Joines Krum,Tx
>We use a lot of fiberglass and aluminum composite panels at work. Most of the routers are PC 690's and PC laminate trimmers. A few of the guys have made small router type tools from die grinders.
Re: Air Router recommendations? *LINK*
GalenV in Iowa
>What do you mean? Some NC controlled machine that runs an air router for machining some shape in fiberglass. Is this to trim off a fiberglass molded product? Do you just want a hand held air operated router with carbide bits?
Guess I have seen fiberglass worked for fiberglass RV's bodies part and residential bath fixtures.
We had fiberglass washtrough and aerator housings sections but used electric routers. Tried to get out of making the parts as a fire and health hazard in manufacture.
Galen
Hand held air router
Re: What's the "machine" supposed to do?
Brian in Brighton
>The machine will cut shapes into fiberglass. That's about all I can tell you. Oh, the fiberglass can be up to 1 inch thick.
Brian in Brighton
They have a big enough screw compressor. It can bring the plant up from 0 to 90psi is about 1.5 minutes for a 45000 sq ft building.
Brian in Brighton
>You're getting warmer. They are fiberglass parts that need to be trimmed and have holes put into them.
They have had bad experiences with all the electric tools that they have used, and they buy top notch stuff. So it's air driven tools for this application.
Brian in Brighton
Brian in Brighton
>Oh, and the bits need to be diamond coated. Carbide dulls too quickly.
Brian in Brighton
Robin Corell in Atascadero CA
>sounds like your customer is using G-10. it can be a tough material to work with doe to the density of the glass fibers, particularly in the thicker sizes. The Souix air tools are the go to top of the line with Dotco not too far behind in quality. expect them to be shockingly expensive. An air router is basically a die frinder with a base attached. If it is less the $400 it is likely not a continuous duty industruial quality tool.
I always felt that diamond tooling left a rough edge on G-10 and prefered carbide. Insert carbide tooling is a good compromise and is designed for industrial applications where you get the tool set up and from then on it is just a matter of rotating or replacing the carbide insert rather than having to reset the depth of the cutting tool. I am fortunate in that Her-saff is located about a mile from my shop so I can stop in to pick up what I need. they are expensive but they produce a high quality american made product
carbide insert tooling for routers
Larry in NW Ohio
>Would ceramic tooling do better. I now nothing of it, just read about it once in awhile. There is a place making saw tips out of the ceramic material, so they may be making router bits. Larry
GalenV in Iowa
>Most of the parts we had molded were sprayed up using chopped glass roving in a normal thickness of 3/16" and 1/4". We found we could use our punch press and dies with the right clearance to punch holes. There was some chipping around the hole but not enough to affect our assembly.
If your dealing with a more detailed part you probably cannot use our simplified way to make holes. Some parts were submerged in water and we never had enough deterioration (swelling)around the punch holes to worry about.
Galen
Brian in Brighton
>Good idea Larry. I'll look into it. I have seen ceramic router bits, but I'm not sure how they handle impacts during the plunge part of the cut.
Brian in Brighton
