Probably won't work
>"...I have some imaging software on one computer from an old digital camera that I'd like to copy/transfer to another computer. The installation disk has long ago disappeared..."
Data can be copy/transferred, but software usually can't.
A USB drive, whether a thumb-type memory stick, external hard drive, or an adapter that reads CF (compact-flash) or SD (Secure Digital) or SOny Memory STick, or anoth other memory chip type (like those inside your camera) are great a copying data.
In general, data, like word processing files, spreadsheets, photographs, music files, etc are easliy copied from one computer to another using seveal methods, including a USB drive.
However, programs that have been installed on your computer usually require a "installation program" to be used on the new computer. The installation program, which is usually files and folders constaing a file called setup.exe are copyable, but the resulting files that were installed on the computer during the installation program are not easily copied.
While you can easily copy/transfer data to another comptuer. And you can usually copy software installation files in the same way. You usually can't copy/transfer the software fro the C:\Program Files\ folder on your computer.
Happy Woodworking!
