Cabinet Crown Molding Advice
matt in Richardson, TX
>I am putting the final touches on a kitchen renovation (that I substantially completed a year and a half ago :)) and I have come across a problem with the crown molding. I have designed a detail that is simple, but unique, with a three bead detail and flat crown separated by a frosted glass that I will light up with light rope. This will tie in another design element across the room that utilizes the back lighted frosted glass in our glassware cabinets.
The problem is that the ceiling is not level, and in the 9' run this crown is on, the ceiling is out 5/8". There is only a 6" gap (roughly) between the top of the cabinets and the ceiling, and I originally wanted to run the crown so that it touches the ceiling. However, that will cause the frosted glass to be uneven by 5/8" across the run. Any suggestions on how to make this work? I attached a picture of a rudimenatary mock up so you can see what I'm talking about.
Thanks,
Matt
