I recently took up veneering, am trying to learn a lot about it. Let me plug Joe Woodworker @ veneersupplies.com, my experience has been great.
My MDF question is-bought a sheet of 3/4" MDF and want to go down to 3/8". What's the best way to do this? Anyone have experience making boxes (small) veneered using this thinner MDF as a substrate?
>I don't think Mother Nature intended that MDF be anything other than 3/4. While you may be able to resaw it, the cut faces will be rough and softer than the factory surface. Then there's the mess of dust.
>David, are you saying you want to reduce the thickness of 3/4 MDF to 3/8". As in resaw it or plane it? I have never tried it, but my gut feeling is, don't bother. Not sure, but I think it will fail as in fall apart.
I would go buy some 3/8 to start with. I believe if you look at MDF closely you will find it has denser material on the faces and less dense material in the center. Sort of a skin effect, probably from them pressing it into the proper thickness during manufacture.
If you decide to cut some down, I would anticipate a LOT of dust and I would do a proof of concept practice run first. Cut a small amount down and veneer it (with cheap veneer) and then test it to see if it suits you and remains flat and stable.
>MDF is manufactured in a limited variety of thicknesses and densities. Availability and access to them in your particular area is where the problem often comes.
Keith Newton, LR, Arkansas------WebKitFormBoundary
Guest
Re: MDF------WebKitFormBoundaryMn6k+fGA2yccP8Zl
>You can buy it in lots of thickness, and it is consistently good, but I agree with the others in that you will not be too happy with your efforts to thin it down.
You will dull your planer, and jointer knives with mdf. If you just need small scraps for boxes, I would suggest that you call local cabinet shops and ask about their scraps. They will probably be happy to give you some. Everybody I know hates to throw away usable scrap, but hate be covered up by keeping it even worse.
>One of the big box stores around here sells it in 1/2" thickness. I have used that for several projects. Not 3/8", but it might serve your purposes and be easier than trying to make it thinner.
I've been looking at making some veneered boxes in a similar manner. I'd like to try some marquetry. Someday.
Post us some pictures of whatever you come up with.
>thanks for the input. I had this feeling that "it's not nice to fool Mother Nature". I'm going to investigate the HoganHardwood link. For smaller boxes, I'll just have to use real wood and work around my limitations, and like has been said, experiment with scrap wood and veneers. David
solid wood will certainly work but it seems that part of your goal is to play with veneers.
Why MDF and not plywood? If you want to practice and learn to use veneers, something like Baltic birch comes in all sorts of thicknesses and is a great substrate for veneering.
>Unless you have absolutely super dust protection, don't machine MDF beyond the minimum. MDF dust contains adhesives & when breathed in coats your lungs almost as if they were glazed. The damage is permanent. Plywood substrate is a much better/safer alternative for the hobbyist.
