Sharpening jointer blades.... while running
Pat Evans
>I came across a jig in my father's stuff for sharpening jointer blades... while the jointer is running. The jig is a metal arm with a stone on one end and a height adjustment knob in the center. Directions tell how to set the height, then slide the stone back and forth across the knives while they are running. Anyone ever done this? I'm a little hesitant.
Re: Sharpening jointer blades.... while running
Fred Davis
>You would be better off by far and still have all of your fingers if you forgot you ever saw that jig.
FreD
Lee Brubaker
>I'm with Fred on this one. Considering local sharpening costs (reasonable) I keep a spare set of sharp blades on hand & when the ones in the jointer get dull I change them out & take them in to be sharpened & they then become the spare set.
Lee
Larry in NW Ohio
>Pat When , in another life before retirment, I did this on Mattison machines. It wasn`t so much for sharpening as much as to get all the blades to the exact height, so ALL the blades would cut. Actually the blades would be sharpened first and then this contraption would be run over the blades to get them perfect height. Yes it can be very dangerous if your not very careful. Larry in Ohio
and...it deosn't work
Bill Tindall, E.TN
>The operation is called "jointing" the cutter head. If you draw what happens you discover that after this operation the knife lacks any clearance behind the edge. Maybe not a problem if one takes off a few thousandths of an inch, but if enough metal is removed to actually sharpen, the knives hammer the wood as the jointed flat spot hits the wood surface.
I used to joint the cutter head on a big planer before I installed an in-place knife grinding attachment. If much metal was removed the noise was unbearable and it didn't cut well. I abandoned the practice.
PS
Bill Tindall, E.TN
>you don't turn on the power to do this operation. Yikes, can you imagine a stone braking in the cutter head! The cutterhead is spun by hand.
That's what I was going to say...
John in New Mexico
>But Bill did a much better job on the description!
Dave Bair, Eaton Rapids, MI
>I do it, but not often. It can be scary, but it's an effective way to perfectly level new or resharpened blades and to get a few more passes out of dull ones. I put a layer of wide painter's tape on the out-feed table and run a stone on top of the tape, using the table-height adjustment to take a very, very light pass on the blade. Do not run your DC during this operation; it creates sparks that could ignite dust in your DC or ductwork.
suggestion
Bill Tindall, E.TN
>next time spin the cutter head by pulling on the belt by hand. A very few passes of the knives over the stone does the job.
A good rule of thumb- If its scary its unsafe. Find another way, what ever it is one is doing.
If You are Just Honing, Could You...
George (Oxford, NC)
>use a flap-wheel (of 120-150 grit) on a handheld drill and run the flap-wheel over the knives while they are spinning?
George
that sounds like a disaster
JRutter
>I would not take a flap wheel anywhere near a jointer head, running or not.
Jointing the knives with a stone fine tunes the height of each knife so that top dead center is exactly the same for each. Every printed description I have seen mentions doing this under power. The advantage of a jointed cutterhead is that each knife is working equally. As Bill mentioned, you don't want to remove much at all or the clearance angle disappears. So if you set the knives as accurately as you can, then jointing is the icing on the cake. The sound goes from a buzz to more of a hum as the frequency rises.
Sharpening is something else all together. I used to use Tage Frid's method of a small grinding stone in a router to touch up the bevel right on the machine. Now I just use a Shelix head...
Garrett in Victoria
>The machinists in my father's factory used to sharpen jointer and planer knives on a tablesaw with a fine grinding wheel on the arbor. A simple jig that looked like a cross-cut table was used. It was clamped in position and the knives slid back and forth, removing as little metal as possible on each pass.
Cheers, Garrett
