OT Removing purple pipe primer from Bathtub?
>I am remodeling a house for my cousin. We have a white fiberglass bath tub and I dripped the purple cleaner for PVC pipe on it. Anyone got any idea how to remove it without damaging the tub? I think I am screwed. Help! Thanks.
Re: OT Removing purple pipe primer from Bathtub?
Danny Julian
>Try bleach.
Larry Clinton At Frankfort (Central)., Indiana
>Barry, I think you are in trouble. The purple primer is formulated to both clean and "soften" pvc pipe. It contains a mix of very active solvents including MEK and acetone. I would wager that the solvents have dissolved the surface of the tub. I would try the "Micromesh" disk assortment pack to see if it would polish the surface to acceptable appearance. Link to Woodcraft page http://www.woodcraft.com/family.aspx?FamilyID=5232 I have used this assortment to refurbish the Plexiglas-glass shields of my restored Powermatic lathe. The lathe had been use in a school and was badly scratched, coated with stain and finishes etc. I actually sanded the shield with 320 grit using my ROS, then worked through the various grits of the Micromesh package. The Plexiglas cleaned up well - looked like new material. My only concern would be if the tub has a resin coat over a fiber-filled material. If you cut though the resin you may end up with exposed fiberglass. Guess you don't have a lot to lose at this point though.
Bill Turpin in WNC mountains
>Use some CLEAR cleaner or PVC cement to remove the purple. All the solvents are there. Then use the recommendations to sand and polish above.
>If it's still there after trying all the remedies above, talk your cousin into letting you stain the whole tub purple.
Clint
Larry in NW Ohio
>Barry If all else fails, there are company`s out there that can put a new liner in an old messed up tub. I don`t have any real experiance with them, but it may be worth a look into. Good luck. Larry in Ohio
Re: I never saw a purple tub, I never hope to see
Kneale Brownson Dreaming of the Snow in N. MI
>one. Sounds very uninviting.
I'd go for one of those outfits that refinish fiberglass tubs before I'd go purple.
Robin Corell in Atascadero CA
>If the tub is one of the new types with a surface of vacuformed acrylic backed by fiberglass what I am about to write will not apply. If however the tub in question is the more comon gelcoat surface with fiberglass then you can use acetone on it without damaging it. infact the MEK should not damage it either. These are the solvents while working with fiberglass but once cured it becomes impervious to these solvents. Both of these solvents will remove the residual wax coating from the manufacturing process and make it look a bit dull and this may seem like it is harming the surface. A bit of wax and polish and it should all look the same again. This is not to say that the pigment in the solvent prep isn't capable of staining the gelcoat. there should be plenty of gelcoat to sand and polish a bit as others havs sugested and in a worst case scenario you can grind a bit of it out with a dremel and patch it with a bit of gelcoat. I once got a shower stall given to me because somone had drilled the a hole in the wrong location. I was lucky enough to get the plug from the hole saw so I just glassed it in from the back and patched the gelcoat. a bit of sanding a polishing and you could never tell.
Robin
>Afraid you'll need one of those One-Eyed, One-Horned, Flying Purple Primer Eaters, but it's tough to get them to leave their bands for private jobs so I think you're screwed.
[if the stain has penetrated, you're in tough shape, but try some auto clearcoat rubbing and polishing compounds (like Meguire's)on a machine buffer to see if you can remove it.]
John E in SC
>You can get kits to patch fiberglass gelcoat from a marine supply dealer - I recently bought a kit from West Marine to patch a ding in my boat for about $40, but that included all the necessary colors to match any shade under the sun. White would probably be cheaper. If it's a fiberglass tub w/ gelcoat, and worse comes to worst, just grind away the purple and patch it.
Good luck.
John
Follow up, good news, I ahve good news....
>Bought a can of clear cleaner/primer made by the same comapany and used some Q-tips to clean the spots. Worked perfectly. Does not appear to have damaged the finish at all. I am out of the dog house.
Thanks for all the time an effort every one put into the replies.
And we had already discussed staining the whole tub purple.
Thanks again.
I'll Let The Band Know
>They don't have to do without their horn player.
