I'm baffled, table saw cut problem.
jeff
>Hi all
I have a problem here I can't figure out.
I cut a bunch of cherry today for some boxes.
This is a cross grain cut, on a jig, with the blade set to 45 degrees.
The pieces are between 3" and 5", from different boards.
Everyone of the cuts is not straight, but concave.
When I put a straight edge on the point of the 45, you can see a small gap in the center.
The boards are all flat and straight otherwise.
I've seen this when a board isn't straight and flat, or sits with a cup on it, but these are perfect.
Can anyone shed some light on this and how to correct it.
Jeff
