>I'm picking up the plans for my 25' x 25' garage shop. I'm having it built with tji's that are 14" deep so no need for laly columns, should be the 560 series. I've never used these before, and I am not sure what I can hang down from them. At the least, I will probably hang 6 8' long flourescent light units(the ones with two bulbs). My architect turned out to be a bit of a jerk, so I want to get objective opinions. They told me the live and dead load per foot(20 and 40 lbs repsectively) but I want to convert that to something that's real. Appreciate whatever help you can provide.
A lot's going to depend on your o.c. spacing. What are you thinking about "hanging" from the ceiling? A friend clear spanned his garage addition (3-car with 3 bedrooms and 1-1/2 baths above), but he went with 16" joists, 12oc, and cross bracing at 16oc. Remember too, top loading these things is very different from hanging stuff underneath where you would actually loose most of the unit's strength.
>Florescent lights don't weigh very much, even 8 footers. I'm not an expert but truss joists, aka wooden I-beam joints, can hold a good amount of weight with minimal deflection. (I've put in a link to Weyerhauser's product lit page just in case you haven't seen it).
On a slightly different note, you may want to go with 8 foot florescents that use 4-4 foot bulbs instead of 2-8s. I use this configuration with T8s which are a bit more efficient than T12s. I was also told that 8 foot T12s are being phased out. In a basically unheated shop I can tell you that the T8s and an electronic ballast have no problems at 5 below (Fahrenheit).
I've been working for a structural engineering outfit for almost 16 yrs. I'm not an Engineer but I would like to add my 2 cents on this one.
First, I'm glad you have the wisdom to ask opinions because there are those people that think TJI's are wonder beams. They are a truly wonderful thing that have done wonders for the building industry. However, they are not inferior or worry free.
I compliment David on finding the design tables and literature from Weyerheuser (spelling) BUT unless you know how to use them properly and understand "loading" a structural member than it's better left up to someone who is familar with TJI's, etc. Maybe even an Engineer. I do understand that that costs money though so I'm not preaching for you to run to an Engineer.
Simple comment, not all wood is treated alike. Whether it be solid dimensional lumber or engineered wood products (TJI's, paralams - PL, glulams - LVL). There is more than one company that make "I-beam" looking TJI's. So....the tables that David provided may or may not apply to your TJI's. Just something to think about.
Okay, you questioned about loading the TJI's. Great question. Mark Mandell made some great comments in his post.
Aside from his friends garage size, size of TJI and spacing, Mark was dead on about "bottom loading" the TJI's. I will explain in a minute.
Without knowing some additional information on your particular application, the types of things you intend to hang below or from the "bottom chord" (the bottom horizontal) it's hard to tell you exactly what and what you can't hang or mount from the TJI's.
It's true, TJI's weren't meant to have a whole lot of point loads attached to the bottom chord.
In most cases you need to transfer the loads from the bottom chord to the "top chord" (the top horizontal solid piece of wood). This is not an easy thing to do with lumber, especially OSB. To clarify, the OSB is acting much like the web of a steel beam.
I just realized that I may be telling you things that you may or may not be understand so I'm going to wrap up my response.
Here are some basic things to thiink about:
1. DO pay attention to the manufacturer's (your TJI's) "specs" on cutting and notching. Also, on where holes can be drilled through the OSB.
2. Most manufacturers will not allow cutting, drilling & notching of the top and bottom chords.
3. Plan your "hangings" so that the loads are distributed across several TJI's. This is called a uniform load.
4. Avoid point or concentrated loads unless you know EXACTLY what your dealing with. (EXAMPLE: Don't hang a hoist off the bottom chord in the middle of just one TJI.) This can be bad.
5) If possible, read up on how to transfer loads from the bottom chord to the top chord. Again, with dimensional lumber (1x's, 2x's) this is easier.
There's more I could add but it would take up too much space on WC.
Feel safe in knowing that a few flourescant light fixtures shouldn't be a big worry.
My friend actually put a 1,000 hoist on a track in his garage. The track was mounted with 24" 9/16" thread rods that up and through the doubled footplate of the upper hallway partition wall. The upstairs wall hides the bolts and we had an effective 4x4 spreading the weight over the tops of the TJI's. The bolt/rods were centered in the bays every 24", and any load was transferred to the top of the joists. He incorporated the whole thing in the plans and got it pre-approved, and I seem to remember that the building department got the township engineer involved in the review process to calculate the loads.
The only things we attached to the bottom of the joists was the rock and the lights.
What your describing is a very well thought out UNIFORM LOAD. I wouldn't mind seeing that setup. Sounds like it was done right. I commend the local town officials for helping out. There are a lot of...(I'll be nice) unwilling people that just want to make things harder for the average homeowner.
>I work in a building centre that sells engineered flooring systems, and I have built two houses for myself using these systems. My concern in a garage would be the typical humidity and temperature ravages to wafer board. If your shop is not constantly heated and the doors are left open and rain blows in I would fear that in time the OSB web in the I joist would deteriorate. John, also not an engineer.
>I'm not sure how to calculate the loading, I had 30' roof trusses built for my shop (designed the shop myself). I have them on 24" centers - the trusses are designed so that I have a 10' wide, 8' tall room 30' long over my shop. The floor loading was calculated at over 20 lb /sq ft. although the truss designer said it would easily hold twice that amount.
I wouldn't be concerned in your design about hanging lights - the weight of the drywall probably varies more than the lighting load. I would not add a hoist or heavy loads to the ceiling without a complete analysis of the load bearing including methods of attachment etc. I would contact the vendor of the TJI's and question them - Do know they are going to err on the VERY conservative side due to legal issues.
>The live load is you walking on top. The dead load is every thing that you hang or attach to the bottom or set on the top, Sheetrock, boxes,insulation, lights etc. Did they get the size calculated for the clear span from Truss Joist or a span table. If so there is a great deal of safety factor built into these tables that provide safety. You can believe that the people making the TJ's have taken into consideration us folks and what we might hang or put on top. The safety factor is around 100%. But you probably shouldn't hang a hoist from them as you could do some harm.
>Just a note for safety, do not drill any holes in the TJI and cut any notches in the bottom chords. Holes can be drilled but there are specific rules governoring their placement. Refer to the manufactures recommendation for holes, but it is best to not do it.
