Cat Urine Stains Hardwood Floor
Steve Bellner
>Does anyone have any experience removing cat urine stains from hardwood flooring? This is spot that had an area rug over the floor, and obviously one of our cats sprayed this area some time ago. We finally found the spot, and when we rolled back the rug, there was a nice brown-to-black stain on the floor.
This is a solid red oak floor, with spar PU as the topcoat. I have no doubt I can color-match the repair with the rest of the room, but I'm not sure what I'm in for as far as getting the stain out. Scraping, sanding, or cutting out the defect and replacing the planks. That's sort of the order I envision. Is there some "magic" solution that might reverse the stain? I know oak it notorious for its tannins reacting with foreign substances, and this looks like what happened here. I'm just surprised it went through the topcoat with so much obvious ease.
Thanks in advance. I hope everyone gets something good from Santa this year!
Steve in East Tennessee
Re: Cat Urine Stains Hardwood Floor
>As a Home Inspector I see pet stains frequently. Between Home Inspections and building, I have over thirty years of experience with hardwood floors and know of no magic solution for this. (If you find one, let me know, please).
My experience is that the stains go so deep that it is impractical to sand them out. You could try scraping or sanding And if the stain is not old or deep, you might get it out, but I would not bet on it. I think the answer is to replace the damaged pieces and refinish the entire floor. You can take a whack at other cures, sort of based on the idea that you can't break something that is already broken. Any bleach strong enough to remove the stain will turn the wood white, which is no better than what you have, just different. You might be able to reduce the stain by sanding and lightly bleaching and stain the entire floor. Or maybe you could have the cat pee on the entire floor and go with that.
George@Colonel's Workshop-Havertown, PA
>Good Afternoon Steve,
The ammonia in the cat urine reacted with the tanin in the red oak, and that caused the stain. Its difficult to imagine how deep the stain goes. As Barry asserted, you probably will have to replace that portion of the floor. I did that at a previous home and matched the floor perfectly. It wasn't a big deal since only two boards were affected. Of course, you do have the option of laying down another area rug.
George
AHA! An alternative to amonia fuming!
Roy Anderson
>O.K. I'm holding the cat over the next project until he fumes the whole thing!
Re: AHA! An alternative to amonia fuming!
Ron Hildreth
>Roy,
You sure your daughter is going to appreciate cat urine all over those nesting tables you're building for her??? What's the cat think about this?? Nice thought, though! LOL
Ron in Iowa
Bart Goldberg
Bart Goldberg
>You can try to get to get rid of the smell by saturating the spot with the urine removal products they sell at pet shops. They contain an enzyme that will break down the urine and eliminate the smell. Nature's Miracle is one such product and works pretty well.
As far as the discoloration - I can't say - are the floors natural or stained?
Hope this helps
Bart
David
>I've tried Nature's Miracle and a couple of other products on hardwood floors to get out old cat and dog urine odors and can tell you that they don't work that well on the odor and didn't touch the stain (they're better on carpet).
I have old Ash floors in my present house. When I peeled back the carpet to restore/refinish two summers ago found several areas that were badly discolored (black stains) from the previous owner's dog and possible cats (they had both). Some very aggressive sanding with a drum sander only lightened one stain, didn't make a dent in the others. If your floors are like mine, you'll be down a quarter inch before it's out. Area rugs work well... Sorry not to be more positive and good luck.
try oxalic acid
Robin Corell in Atascadero Ca
>I used oxalic acid on some urine stains on a white oak floor with excellent results. You mix up the powdered acid with warm water and apply it to the wood, when it dries you apply more.it may take several applications but it will work. and if you don't like the results you can still replace it as others are sugesting.
for tannin stains on my hands I use citric acid but have not tried this on wood.
Robin
