Impact Driver/Battery life question.
>I have a 12 volt Makita Impact driver. I had my batteries rebuilt by PrimeCo (PrimeCell?). They are now NiMH. Today, I charged one from very low to full in about 45 minutes. Then, in another 45 minutes I drove 105 2 1/2" coarse thread screws through 5/8" OSB & 1/2" plywood, into pine joists. Does this seem good? Does leaving the battery in the charger longer, after it indicates full charge help?
Re: Impact Driver/Battery life question.
Yes & No
Joe Shelton
>Barry, that does seem to me to be good performance. Of course, impact drivers are far better than drill/drivers at running screws.
As far as charging goes, I'm personally convinced that leaving batteries on for (reasonable) longer periods helps a lot. I recently returned to two long-neglected tools, a 14.4v PC and a 7.2v DeWalt, and the chargers for both indicated that the batteries were bad. I keep alternating batteries and charging, and after a period of about 2 days of intermittent charging, all four batteries have now accepted good charges.
My 12v Hitachi batteries love trickle charges to get good and full.
BTW, do I remember from an earlier post that you're from South Carolina? (I am, hope I haven't mistaken you for someone else. If so, sorry.)
JS
Me too
John E. in SC
>From SC, that is.
Where are y'all located? I'm in Greenwood.
Thanks, and
>No, not SC, I live in Chester, VA. Right off I 95 south of Richmond.
After I thought about it, I decided that running 260" of screws into pine seemed like plenty of work for a battery. That Impact drvier is a great tool.
Miles
>I have the 14.4 Makita impact driver, and it is indeed awesome at driving screws - so awesome that most of the posidrive bits I try shatter if I happen to disengage during driving, or even just during normal use if they are the 'normal' grade.
The best so far has been a Bosch type, but apparently it is very difficult to get bits that are specifically engineered for impact driving, with a thinner shank that twists a little & reduces the destructive capability.
Some 'Posisquare' bits that came with a box of 2" * 10 self-drilling flooring screws (intended to go into 3/4" chipboard flooring) were much better, and also held onto the screws really well, bit like a hybrid Robertson/Posidrive. This was a novelty to me, but they worked really well. Robertson are not generally available here, but I have seen them used (and highly praised) for decking.
Have you guys got better impact-specific Posidrive drive bits available in the US, or is Posi as rare there as Robertson is here?
Maybe I need to grind down some bit shanks... that could be fun (not) and I wouldn't expect it to work well.
cheers
Miles
Try square drive screws
Lots
>of Robertson / "square-drive" screws in use here. No info on your "posisquare" which seems like a local brand maybe in your area. Impact drivers don't (yet) have clutch adjustments so you have to watch your screw depth. You breaking bits or screw shafts. I've snapped my share of screws, but never a driver bit.
mm
Re: Lots
Larry in NW Ohio
>Mark Do you have a web address for the Robertson screws. Thank You Larry in Ohio
Re: Robertson
>http://www.robertsonscrew.com/
Square drive (samo) - http://www.mcfeelys.com
Larry, just to avoid confusion, "Robertson" invented the square drive screw. They are the same thing, excepting for grade and quality of course. I happen to buy all my square drive stuff from McFeelys, but HD and Lowes also carry lots of square drive stock.
mm
Re: Barry, read this *LINK*
Dave Mount
>Hey Barry--
If you read the fine print at the Primecell site, they mention that on NiMH rebuilds a few charging cycles will be needed to bring the battery up to full charge. Read the info at the link below -- info you want is a little ways down the page.
Best,
Dave
Primecell on charging NiMH rebuilds
Posidrive info...
Joe Rogers, Northern Virginia
>Posidrive type bits and screws are very similar to Phillips and Reed & Prince "cross point" screws. The difference is the point of the bit has parallel flanks rather than tapered from the shank to the tip. If you look at the screw head there are little notches at the intersections of the cross. The bits have a corresponding rib at the base of the cross. These are my favorite cross point screws. The lack of taper in the drive flanks makes for a very secure fit between the bit and screw. Reduces cam out a bunch. They were engineered by the Phillips corp to have a propriotary (sp)screw after Phillips screws became public domain. Heavily used in the automotive industry.JR
Re: Me too
Joe Shelton
>Hey, John. I'm in Huntsville, Alabama now. But early on, growing up in Greenville, I thought the center of the civilized world was Lake Greenwood.
JS
Re: Thanks, and
Joe Shelton
>Barry, sorry for the mistake. I don't know where that came from. And I'm very glad you got that info out about Primecell. That seems like a very good option, and I'll file that away.
JS
