I broke a junk tool - ideas for fixing?
Joe in a Cleveland suburb
>Hi folks.
Last weekend I was using my PIECE OF JUNK CRAPSMAN mortising attachment on my drill press. I know better than to try using it (cutting mortises in cherry table legs). Normally I do it by hand or by router. But I saw it on the shelf, hadn't tried using it for several years, and gave it a go.
The mortising bit is semi-sharp and it actually was cutting into the cherry pretty good. Then the do-dad that holds the work piece broke. It's shaped kinda like two fingers, or a 'U' and slides over a metal dowel thingy and is held in place by a little thumb screw. It's made out of cheap white metal. It looks kinda like a tuning fork.
Any ideas on what I could use to replace it? Not gonna bother calling Sears. I tried clamping the piece down but that didn't work too well. There aren't any good clamping points. I'm amazed at how much upward force there is on the up stroke.
I took a quick look at getting a dedicated mortise machine but spending a couple hundred plus bucks is not an option right now.
So I'm just looking for some quick-fix ideas.
Thanks for any ideas,
Joe
Re: I broke a junk tool - ideas for fixing?
Pete LaBelle
>White metal is probably either zinc or aluminum. Zinc doesn't weld well. Aluminum does though. Cost to have it professionally welded will not be cheap though. Spare parts from Sears will probably shock you. Suggest fabricating a new one out of a shaft collar and steel rod, or come up with some wood gizmo.
A few clamps and a block of wood
Dustmaker Mike
>I would hold the piece down with a few clamps and a block of wood. I then would put a small tapered wedge to hold it in place while morticeing then pull it move the piece and replace it.
Keith Newton
>Joe, If I understand, you are looking for something to hold the wood down while extracting the bit.
I had the same problem on an old Rockwell. I made a little leg that was forked on the bottom, so that it jammed under the head, behind the quill, and the legs of the fork held the work on each side of the bit.
It worked pretty good, actually better than the other hold-downs, because there was some flexing in the table, and column, on the way down, and in the opposite direction on the way out that caused the bit to bind which made it harder than it would have been on a more rigid machine.
I was glad to move away from that tool to a chain mortiser. It only takes about 2 seconds to cut a mortise 1/2" x 2" x however deep you want it to be.
Ernie Miller
>Chisel and mallet? quick and dirty fix. it shouldn't take to long to chop them out by hand.
I agree with Ernie
Mike in Paradise
>I have one of those drill attachments that I found a PITA to use and ended up doing them with a bit on the drill press and then clean up with a mallet and chisel.
I now have a dedicated mortiser although I don't use it much.
Never use mine!
Lee Schierer, McKean, PA
>I have a similar piece for my Delta morticing jig. I never use it. I use a quick grip clamp to hold the piece to the table if I can't hold it down by hand.
Lee
Steven Antonucci
Try gluing it?
steve antonucci
>I have successfully CA glued white metal on a broken bandsaw part. may work well enough to finish the mortises.
Good luck.
Steve
Larry in NW Ohio
>Joe Since your only about 170 miles away I`ll make you a deal. I have a, now don`t laugh to hard, harbor freight mortiser I bought a couple years ago, and just don`t really use. If you come and get it you can have it just to get it out of my way. IT does work and has a few bits with it. Larry in Ohio
Larry in NW Ohio
>I forgot, it also has a X-Y vise Larry
170 miles. That put's me in Angola IN.
Joe in a Clevland suburb
>Whoa Larry. That's a generous offer. Hmmm.... Let me think...
