>I have acquired a chainsaw mill, and a chainsaw that could power a small motorcycle. My plan is not to make 1/2" boards but to mill some cherry trees (I have many including 2 that fell on their own last year) into 4" thick planks to then take to my bandsaw for chair parts. I've been doing a lot of cherry work this year and find that splitting it is not the way to go, huge waste. So as I head out to my woods with a sucker, I mean voluteer, I could use some tips.
I have done this as an assistant with a friend of mine. It is a slow, painstaking process, or perhaps he just needs a better chainsaw. We were milling up a large oak tree, and it was taking 20-30 minutes to get through one slab. I keep trying to get him to buy a bandsaw mill, but he does not mill enough lumber to justify it.
Make sure you allow a little extra thickness, as the board will be rougher than what you get from a regular sawmill.
The coolest part is when you lift the slab off to reveal the cool figure in the wood.
Keep a sharp chain, carry a spare or two. watch for nails, bolts, tractor implements etc embedded in the wood if the tree grew anywhere near a building. you need lots of oil on the chain. Keep a close eye on it. You may have to supplement the saw's oiler or let it run free to add additional oil.
the forst cut should be very strait for the others will follow it. i carry a scrub and jack to take off the obvious high points after first cut is made. I made a kind of ladder from straight 2X4's for a guide. Rails are 2x4 on edge. Steps are in side. Make up a few shims and screw it to the log straight as you can.
i file my chains to 10 degrees with normal height guage depth and 066 stihl and granberg.
Seal the cross cuts within an hour of cut in dry weather.
Let the saw idle occassionally so you and it can get a breath of fresh/cool air!
The job isn't done till the wood is protected from drying too fast and from warpage and endgrain is sealed.
Wear ear protection too so everybody won't have to yell at you to compliment you work.
Rewarding discovering the amazing sights of trees and knowing you took it from the first steps, but very hard work! Think very carefully of how to gain the greatest benefit from the opportunity of beatiful wood before you cut. That's a great part of the experience for me or I wouldn't bother.
>I've bought a rip chain and a 32" bar. The guy at the Stihl dealership said that he'd refused to sell a bar that size to a guy from the city. The guy said he had some big trees (28") and said he needed a big bar! My goal is to just make about 3 slabs per tree. The good news is that I can then crosscut them at about 24" for chair parts.
>It is hard sweaty work that requires a large chainsaw and I love it!
If you have a 32 bar you will lose 6-7 inches off of it depending on the brand of mill. On my Alaskan MkIII mile with my MS660 Stihl with a 28 inch bar the max I can cut is about 22 inches.
I use a ladder for the first cut fastened to the log with end boards that are fastened to the ladder with fender washers.
I have use both regular chains and the ripping chain available from baileys-online.
You need to have wedges to keep the cuts from pinching the sawblade.
Make sure that you have your oiler turned up full and I plan on adding an auxillary oiler to my setup.
>I have been milling all my wood for over 10 year. I make the first cut by screwing a 2x10 on the top of the log. sometimes I have to make a few trim cuts to get a levelish area to set the board. I also try to make my initial set up so that eventually I will make a cut that will split the pith or capture it in one board so that I have approximatly even amounts of grain runout over the whole log. In your case with the cherry you will want to box the pith. I carry a supply of large wedges (about 10" long by 2" wide and 1 1/2 inches thick) I use these to take any twist out of the 2x10 and to take any sag out. every place I use a wedge I shoot a screw through the board to secure the wedge so the vibration of the saw dosen't dislodge it. don't forget to set your mill to allow for the screws and a bit more, these things will kill a chain in a blink of an eye.
I also use the wedges to keep the board from binding the chain at the end of the cut. it is tempting to use them along the entire cut but really isn't necessary and they tend to get in the way.
Perhaps my mill is quirky but I have to apply downward presure on the leading edge just past the middle of the board. the extrusions of the mill are very uncomfortable to hold/push for extended periods so I have added some padding to make things more comfortable. On long cuts with my big saw I sometimes throw a chunk of firewood on the mill for weight to help hold the mill down. it is comon for it to drift up as the chain becomes dull.
I cary a spare chain or two but it is often faster to touch up a dull chain with a 3 or 4 quick strokes with a file than it is to swap out a new chain. which reminds me, you should warm up your saw real well befor starting to mill, not so much for the sake of the saw but to warm up your chain to streatch it so you can adjust it. I tend to start the day with a rather tight chain so as it heats up in the log I don't have a lose chain. tensioning your chain with the bar buried in a log and a mill bolted to it is not easy. A loose chain will effect the quallity of cut much more than the style of chain you chose to use.
You won't remember half of what you have read untill after you do what someone has advised against. it is that Will Rodgers thing about a rare man being able to learn from reading something in a book and a few who can learn from watching someone else do something and the rest of us have to just pee on the electric fence for ourselves. Don't worry it will all work out in the end, it is just wood.
>Peter, I hope your tree was back in the woods, I have been sawing some urban trees that were growing near houses, and I am finding so much spiral grain that the wood would be worthless for chairs, because of the grain-runout.
I am just guessing that the problem is worse for a tree that gets twisted by wind deflected off of building more than trees in the woods that have to grow tall to get to the light. Those trees would only get a gentle bend and sway from the same winds, so the grain may be straighter under those conditions.
Take a hammer, and knock some bark off, to give the wood close scrutiny. This work is too hard to waste the effort on unsuitable wood. This is not as easy to see in this even texture wood as it is in coarse grain wood.
I hope you are young and stout, and have a good back. Just handleing the wet wood is hard enough, but using a chainsaw to rip is back-wrecking work. Good Luck. K
>Here's where I get to gloat! I live on a mostly wooded 50 acres and the woods have a high canopy that forces them to grow tall and straight. Great advice about the twist, I'll avoid anything on the edge of the woods. About the young and stout part, we'll see!
