Dust Collector Modification ????
Ray Carson in Lawrenceville, NJ
>Hello,
I have a 1 hp Grizzly dust collector, 110/220 convertible with one 4 inch main inlet. I currently have a 4 inch "Y" with a blast gate on each attached to the main inlet breaking it into two lines. A 4 inch corrugated flex hose connects to my tablesaw and the spare 4 inch gets moved to whatever machine needs the suction when in use. I'm trying to figure out a simple dust collection system to eliminate the hoses from lying on the floor. My work area is a small 16 x 24 basement setup. That being said......
First question, would I gain suction capacity by switching the motor to 220? My guess would be no.
Second, would I gain anything by cutting off the factory 4 inch inlet and installing a 6 inch inlet and running a 6 inch line as far as I could and then dropping down to the size pipe I need for the individual machines?
Last, leave it as is, run 4 inch to everything, and deal with blast gates. I feel this will drop my CFM down significantly. ????
Thanks in advance,
Ray
Re: Dust Collector Modification ????
Tom MacGregor
>Switching to 220 will drop the amps that the motor draws, but won't change the output. I have a 1hp single 4" inlet system and get acceptable suction across a 12' x 23' shop. I cut the cost by using cheap 4" plastic drain pipe on the long runs, and the smooth interior surfaces helped cut down on CFM loss. I also wrapped electrical tape around joints to make a positive seal and spent the extra money on metal blast gates because they seal better than plastic - make sure you aim them correctly for a tight seal. I also ran some pipe & hose across the ceiling and either have it hung up out of the way or dropped down during use.
Mark Kauder, Phenix City, AL
>Here is what I did, and it has worked for the last 4 years or so. I have a 1.5hp Grizzly, but the principle will work.
1) I place your DC as close to the TS as possible and put as short, smooth and straight a connection to it that is practical. The large inside area of a TS requires a lot of suction to keep it clear.
2) Install a long run the length of your shop (or diaginally if that makes better sense.
3) Use Y connectors to shoot off of that to your other machines.
4) Put your blast gates at the main line, not at the machine if possible (both is OK), because keeping unused branches closed results in less air turbulence in the main run.
5) Use 4" PVC where ever possible, and when you have to use it, use the Gray or Clear smooth 4" hose and not the really stiff rough stuff that is really cheap.
6) If at all possible, place the tools that require less suction (disk sander, 6" planer) and the far end, and the suction hogs (bandsaw, TS) as close as possible. But remember, with a small system you can not do everything. In my instance I had to put my BS at the opposite end of the shop. It works, but not great. My TS is virtually right next to my DC, but it is a contractor TS and I just collect the dust in a stand underneath, and then suck it up with a DC outlet nearby.
I intend to go to a big 5hp cyclone sometime soon.
You could not really do a 6". It would provide suction, but not enough to pull really small particles, and not speed to keep heavier particles suspended in the air stream. 5" might work, but it is a pain to find the parts.
4" PVC will work.
Mark
Lee Brubaker
>Going to 6" pipe will reduce static pressure (resistance) which may slightly increase volume (CFM) however velocity will also go down cancelling for the most part any benefit. The impellor is only capable of delivering "X" CFM at "X" RPM & at the peak of the performance curve demands "X" hp. Manufacturers rate their impellors at sea level & without ducting. After all this gobbly-gook, I would suggest that you stay at 4".
Lee
Ed Mulligan, Cape Cod
>Ray -
I ran a 1 h.p. dc for many years. It clocked 800 cfm at the inlet and 400 cfm at the end of a 10' length of flex hose, measured with an anemometer. This was with the upgrade bags from Oneida. I think you will succeed to the extent you keep your runs as short and as straight as possible.
Ed
Re: Dust Collector Modification Mark K.
Chuck Lenz
>Mark, I don't understand why you don't hookup your table saw to your dust collector.
>Ray, I bought 4" S&D PVC from Lowes. I found that some of it is smooth on the interior and some of it is terrible. Look through any you buy and be sure to buy the smooth pieces. I have no idea if the stuff that was rough would have any affect on the system, but for no additional money you can get the smooth stuff.
Bob Dodge was helping me with my system (A Delta) and pointed out there was a restrictor plate in the inlet. My six inch inlet was reduces to four. He said to remove it and I did. Look in your inlet and see if it is reduced, If so, consider opening it up to full diameter. Improving the bags is also a good idea. I think the industry is concerned that we sill somehow run these machines with little or no back pressure or restriction on them and they will over heat from "free wheeling" or whatever the problem would be. If you have even a short run of pipe or hose I doubt you need to worry about it.
Re: Dust Collector Mod-Thanks everyone.
>A low powered DC does not pull enough from the bottom of a Contractor Saw, to make any difference up at the top where the dust in nearest me. It would just save me from sucking out of the collection box. Instead, I have a fan, that keeps the dust from getting to my lungs. Not an ideal situation, but until I get a better sucking DC, and make a TS stand that will seal up more of the holes, especially where the motor is.
Mark
Chuck Lenz
>I understand what your saying about the top of the saw, but thats a whole different collection line than below. If you hooked up the bottom side, alteast you would get some of the fine dust being blown out the back of the cabinet. I dunno, just my two cents.
