OT---Sealing plastic pipe revisited *LINK*
Gary Evans Tallassee, TN
>Hi all,
Week before last I posted about the difficulty I was having sealing plastic fittings to steel on a pre-heater tank from my wood furnace. I received some excellent advise, but now I find myself in a bit of a quandry.
Since I had a couple of comments on the superiority of teflon paste to teflon tape for sealing threaded fittings, I bought some to use, not only for the tank, but also for the new supply valves that I put under the new bathroom sinks. Finally got them installed on Sunday and 2 out of the 4 valves leaked at the threaded 1/2" cpvc fitting.
I took a little more turn on the valve that was leaking the worst with no effect, so I took the two valves back off, sealed them with thread tape and put them back on. No Leaks. I know the valves were originally tight enough, because I returned them to their original orientation when I used the tape.
Now, I don't know if I should use tape or paste when I go back and re-do the fittings on the water heater tank. The difference in application is that I will be working with 3/4" fittings rather than 1/2" and will be screwing the plastic into copper extension pipes as was recommended in the previous thread. Recommendations would be appreciated.
Bear in mind that Murphy was playing a role here as I had initially used the original supply valves when I put in the new sinks. Two of the valves leaked from the stem on the handle, not to mention I had a cracked stainless drain pipe that I didn't see when I installed it and I didn't have one of the drain baskets tight enough in the sink, and the list goes on and on. I was beginning to feel like the project was snake-bit.
Here is a link to the original thread if anybody really cares enough about this silly nonsense to go look. 8^]
Gary
Previous conversation on this topic
Re: OT---Sealing plastic pipe revisited *LINK*
Larry in NW Ohio
>Gary FWIW I give my $.02 worth. When I was unretired we use to seal our steel piping from 3/4" and over with teflon paste and then wrap it with the tape and we never had a leak. I now I`m going to hear about how this is not right. But it worked for us. Larry in Ohio
Didn't see the original, but....
Lee Schierer, McKean, PA
>I didn't see the original post or responses. However you mentioned applying teflon paste to plastic pipe as a sealant. While teflon pastes are superior in their ability to seal, not all are compatible with plastic pipe. The solvents in some will actually attack the plastic pipe and weaken it. Be sure the paste you used can be used on plastic pipe.
Lee
>Hi Larry,
After reading your post, I was thinking about whether you are using the paste on both the fitting and the pipe. Bingo! Suddenly I realized exactly what I'd done wrong.
I only applied paste to the male fitting, not to the female. No wonder they didn't seal. Bound to be early Anheiser's. 8^] I may go with the paste on the tank after all.
Gary
Paste on male threads only is OK *LINK*
Tim Greif - West of Chicago
>Paste should work just fine applied to just the male threads of the plastic fitting. Just be sure to use enough. See the link below and scroll down to the FAQ about "Do you recommend using PTFE thread sealing tape on CPVC threads?". It specifically recommends against the use of too many layers of teflon tape.
Link to CPVC pipe fittings
Try yellow teflon tape
>that's intended for gas lines. It's thicker.
Clint
Re: Paste on male threads only is OK
>Thanks for the link, Tim. Some interesting reading.
I had plenty of paste on the joint. One of the reasons I don't like paste is because of the mess when the fitting is tightened. When I took the valves off, none of the sealant had stuck to the male threads. Perhaps it just doesn't like that chrome plated brass.
I think I will stick with tape for the small fittings and try the paste on the bigger ones.
Gary
Re: Didn't see the original, but....
>Hi Lee,
According to the label, this Rectorseal T plus 2 is made for metal or plastic pipe. I think I would have had better luck if I had applied some paste to the female threads also.
Thanks for the suggestion. At least it made me check the paste to make sure I had the right stuff.
Gary
Re: Try yellow teflon tape
>Hi Clint,
I tried the yellow tape years ago, but didn't like it because of the thickness.
Thanks for the suggestion, though. I think I'll stick with the regular tape on the smaller fittings, particularly those that won't be subjected to huge temperature swings.
Gary
